Question about Garden
Snowblower attatchment not working
I am trying to instal a snow blower attachment that was previously installed on my riding lawn tractor. i have it mounted underneath the tractor now but when i install the belt around the pulleys i cannot get it lose enough to make it work properly. as soon as i start up the tractor the snow blower runs constantly and i cannot disengage it. the tractor is a craftsman dls 3500. pls help
  • 1,869 Answers
You must get a longer belt and, install an idler pulley
your craftsman dealer has the conversion kit parts
Posted on Nov 18, 2013
Testimonial: "that does make sense, although this blower was installed on this tractor when i bough it and it worked fine, i took it off earlier this year to install my mower. im using all the same parts and i know im not missing anything. did i possibly miss a step during installation or something like that?"
  • 49 Answers
SOURCE: mounting snow blade to lawn tractor
It attaches the the front of the tractor. Similar to a plow to a truck. If you don't have the brackets, you will need those, or make your own. You can see a picture of the brackets if you go to sears.com. Click on the PartsDirect link at the top, and enter the blade model number.
Posted on Feb 05, 2009
  • 148 Answers
SOURCE: How to remove snow blower from Craftsman YS4500 garden tractor
Go to www.managemyhome.com to download the manual for free. Just type in the model # 944606950.
Posted on May 21, 2009
backwoodsctr
  • 169 Answers
SOURCE: I need a picture of asnow plow installation
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0603016.pdf
here is a craftsman 42 inch snow plow instruction sheet
Posted on Nov 28, 2009
  • 52 Answers
SOURCE: Sears Craftsman riding mower V belt getting chewed
I believe you may have the belt over one or more of the belt retainers next to the pulleys. They are 5 or 6 inches long and about a 1/4 inch in diameter. You have to loosen them when you put the belt on then adjust them to where they are just barely touching the back of the belt. They keep the belt from jumping off.
Posted on May 02, 2010
SOURCE: Bolens model 3012H lawn tractor attachment install instructions
I don't know the answer to this question but I wouldn't mind getting one of those tillers for my tractor. If you ever decide to part with it let me know! j e s s e m e r s o n @ m y m a c m a i l dot com
Posted on Aug 12, 2011
Will snowblower attachment 190-832 fit a 2006 yard machine lawn tractor
Most of the Yard Machine lawn tractors have a welded tube front axle and they are not strong enough to handle the weight of a snow thrower.
The snow thrower is generic but you will need the correct mounting brackets and center frame for your tractor. Go to the agrifab website, call the help number and ask them if they have a mounting kit for your tractor. You will need the model number off the nameplate on your tractor frame for them to help you.
Nov 01, 2013 | Agri-Fab Agri - Fab Snow Blower - 42"
What snowblower attachment will fit on a 1992 Mtd tadesman gt 1846 lawn tractor.
don't put one on all snow blower on riding mower don't do very well and you will aways see the for sale for that reason
May 27, 2012 | Mtd Garden
I'm trying to attach a Model# LST42 snowblower to a 26hp Craftsman riding mower. Was wondering if you had a manual for the installation & where i could get it
Here is the manual for the snowblower; http://www.odref.com/agri-fab/SnowThrowers/LST42.pdf
You may want to call Agri-Fab at (800) 448-9282 first to make sure your snowblower has the correct brackets to fit the Craftsman tractor.
Have the numbers off the snowblower nameplate and the model number of your tractor (it's under the seat)
Oct 13, 2010 | Agri-Fab Agri - Fab Snow Blower - 42"
My craftsman snow blower gets a white foam in
Unless you snowblower sits outside, I would run a straight 30 weight, Valvoline.
The "white foam" You see is any mosityre that gets into the crankcase.
Feb 11, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How do I attatch the heavy spring that helps lift my snowblower to my 416-8 toro snowblower
lift the snow blower up as far as it will go and block it there, attach one end of the heavy spring to the place it attaches on the tractor now attach a come-a-long to the free end of the spring and using the come-a-long stretch out the spring until it is longer then you need it to attach to the other spot it fits on the tractor, pry it over to the spot on the tractor that it goes and slowly let off the tension on the come-a-long until the spring is firmly in its correct position on the tractor. One tip when you attach the spring to the come-a-long use a piece of rope or wire between the come-a-long hook and the end of the spring, so that you have room to attach the spring to the tractor and just remove the rope or wire when in place and you are done. Hope This Helps Don
Dec 05, 2009 | Garden
Have an older tractor and snow blower attachment.
Go to sears.com and lookup in the parts listings for the tractors model number and the snowblowers model number and they will show all the attachments and brackets needed to run it. Hope This Helps Don
Nov 09, 2009 | Craftsman Garden
Nov 04, 2009 | Garden
Will a snowblower attachment model number 842-240743 fit on my riding mower
i have a snow blower attachment mod# 842.240530 sears and a sears 18 hp tractor mod # 917.258492 with no instructions on how to install them together? i dont know where all the parts go.
Oct 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Is there a GENERIC Snow thrower for John Deere 110?
Two Stage - Snowblower - Snow thrower - Bercomac All of the Bercomac attachments are interchangeable on the same quick hitch mounting. Bolts on in minutes. What a great idea for people who have more than one tractor or buy a new one. No more having to go and buy all new attachments for the new small tractor, just buy a different model hitch kit if it doesn't use the same one. The resale value is preserved when you can sell your attachments to be used on another size or model lawn and garden tractor.
camcorder-pic.jpg Snowblower video clip
Snowblower-Snowthower Q&A's
If you are ready to buy or want more details give us a call: 1-800-618-8738 or e-mail jim@jimsrepairjimstractors.com
Sep 10, 2009 | Garden
Garden Logo
109 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
