Question about Honeywell Furnace Gas Valve Sv9501h2409
When the heat cycle calls for gas there is no ignition is my gas valve bad?
I am getting 24 volts from the control vale to my gas valve constantly. should there be a standing pilot light present on this model?
    Sergeant:
    Novelist:
  • 185 Answers
I don't know what kind of furnace you have. But most furnaces have some sort of pilot first than after it is proven than the main gas will come on. Either a standing Pilot with a thermocouple. A hot surface ignition or Spark ignition with a flame sensor. Or a direct fire system where hot surface or spark ignitor start first than all the burners send a 1 sec blast of gas which is proven by the flame sensor if it proves the gas valve stays on.....
In what you have said you have 24 volts to the gas valve and it has not lite. then does the gas valve have a pilot tube???Does it have a thermocouple?? Do you smell gas?? If you don't smell gas then the main part of the valve has not opened. The Pilot valve has to open first and prove before the main gas will come on. I hope this helps. If you still need help repost with the name and model # of the furnace.
Posted on Nov 18, 2013
Testimonial: "there is a pilot tube and the hot surface ignitor lites up, I don't smell gas. So should I replace the gas valve or the pilot valve or both. What should I charge for a job like that?"
  • 3 more comments
  • Joe A H. Nov 18, 2013
    I didn't see that you had said what model of valve you had... that valve has an Intermittent Hot Surface Pilot Ignition. So make sure you are getting voltage to the ingitor.
    The hot surface ignitor is more than likely burned out.so it would have to be replaced. You can OHM it out should get some kind of reading if it is ok.
  • Jermaine James
    Jermaine James Nov 18, 2013
    but the ignitor lites up
    Then you will need to replace the gas valve.The ignition is built into the gas valve. The controls provide intermittent pilot gas ignition sequencing, pilot flame sensing, and both pilot and main gas control functions in a single control. The gas valve is pretty expensive and it should take about an hour to change it out.
  • Jermaine James
    thank you this information was really helpful and has pointed me in the right direction.
Gas not going to burner
check the gas valve is open , check the control gas valve and 24 V is going to it.
Mar 25, 2014 | Honeywell V800A1070 24 Vac Standing Pilot...
I have a Lennox furnace Model G19 and the pilot will not light.e You get the normal clicking sound and the ignitor lights but it seems to be a very small flame and the pilot does not light. The ignit
probably need a new control board. so it sparks but gas not coming on? usually you will hear a click then hear gas coming out. if you have a voltage meter check voltave going to gas valve while ignighter is clicking if you have voltage bad gas valve. you should read about 24 volts at gas valve.
Mar 09, 2014 | Heating & Cooling
Does this valve have a standing pilot? if not, if my hot surface ignitor lights up and the furnace fails to light would you consider it to be a faulty gas valve? I am getting a constant 24 volts fro
If your getting 24 Volts to the gas Valve and the gas Valve is not opening replace your gas valve If your not getting a full 24 volts check your Transformer and the ground to the gas valve.If the gas valve still does not open change the Gas valve.
Nov 18, 2013 | Honeywell Furnace Gas Valve Sv9501h2409
How to light pilot
Assuming it is not an electric spark, but is really the type with a real pilot light:
Move the gas control on the water heater to PILOT
Push the valve handle on the gas controller down to start the gas flowing to the pilot.
Using a match, light the gas at the pilot while holding the gas controller valve handle down.
Keep the gas valve handle depressed for 30 seconds after lighting.
Release the gas controller vale handle - the pilot should remain lit. If not, repeat lighting one more time
Once the pilot remains lit, turn the gas controller valve to On - this should cause the main flame to come on.
NOTE: DO NOT LIGHT A MATCH IF YOU SMELL A HEAVY CONCENTRATION OF GAS - CALL A SERVICEMAN AND VACATE THE AREA
Dec 03, 2012 | American Standard Water Heaters
Frigidaire furnace wont light pilot. we have replaced igniter and pressure switch
Gas valve solenoid have continuity? No continuity replace the valve
Getting 24 volts to the gas valve? No voltage from control board check fuse on control board.
Replace control board.
Any rollout switchs that are open and you won't get 24 volts to the gas valve.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 27, 2011 | Goodman GMS90703BXA Heater
GDS80703ANA Open Flame Mid-Size Heater: have brand new heater got gas was running first t...
Hi, It says this problem is still not solved, but its been 4 months ago? Anyway, when this happens, the inducer motor will start on a call for heat, close the pressure switch and then the glow plug will turn orange or a ignitor module will turn on for a few seconds and then the gas valve should be energized by the control module to open and start the heater. So, on your heater you will have what is called a flame sensor that lays along side of pilot tubing and is porcelin with a metal tip and a wire coming out the back that plugs into the module. It senses heat by pilot flame or direct heat and will send a signal back to module to open main gas valve. If you have no pilot at all, you need to check to see if you have gas to the unit first. Get a good sized adjustable wrench and loosen the gas flex coming to the valve to see if you smell and hear natural gas. Bleed it off to get any air it may have. Tighten back down and make sure you have no leaks. You need to get a cheap digital meter. They are very inexpensive. Go to Sears tools and get one for around $19.99 a craftsman.Set the dial to ac voltage the lowest setting above 24 volts what ever the scale reads, such as 200 vac.Now start you furnace, but be for you do take the red and black leads of the meter and put the red lead on one of the connections that reads MV and other to C. Now start the heater and let it go through the sequence of operation. When the ignitor starts to click to light the pilot, the meter should read 24 volts at the valve. If the vale has more then 2- wires, see if it is marked PV and put your red lead to this the pilot valve. As it is clicking there should be 24 volts ac there to open pilot valve. If not, the control module is faulty, only if there is 24 volts to it and you had gas at the flex line. If you have no voltage to this gas valve when the control module or board is clicking, this module will be faulty as it is not putting out 24 volts to the gas valve if you have gas to it. This is a simple check. If you can see a pilot light back there and the gas valve will not open, you will need to check this flame sensor. Carefully remove it. Take a light piece of sanding cloth and clean up the metal tip on it. Now install it and make sure the tip is in the pilot flame. Start it back up and it should fire the MGV to open right away. This should have taken care of your problem. let me know the out come.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
May 16, 2010 | Goodman GDS80703ANA Open Flame Mid-Size...
No blinks normal running igniter glows gas comes on wont run
Check for 24 volts across the gas valve when Ignitor is glowing. If no, bad board. If yes, bad gas valve or blockage.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Mar 05, 2010 | Goodman GMS90703BXA Heater
80% ducane furnace makes several attempts to ignite then shuts down. glow stick lights but no ignition to main burners. any ideas?
Check for 24 volts across the gas valve terminals!
Mar 04, 2010 | Heating & Cooling
My York Stellar PLUS furnace (Model P2UDD12N07601C) will not stay on; The ventilator fan runs, the main blower runs, the igniter comes on for approximately ten (10) seconds and you can hear the gas valve...
Check gas pressure, inspect manifold & make sure there is not a blockage.Make sure gas is present and main gas shut off valve to furnace is on also check the knob on the 24 volt gas valve and see if it is in the on position , check the MV terminal on the gas valve to 24 volt common with a volt tester to see if you have 24 volts present, if you do have 24 volts at gas valve, replace valve. if you do not have 24 volts at gas valve check high limit control & roll out limits for a open circuit, Good luck.
Feb 20, 2010 | York Furnace Draft Inducer Blower Fasco #...
Just replaced idnitor and flame sensor on a bryant model 376c and its still not kicking on. blower kicks on fans kick on and then cycles off. no heat need help
Make sure all wires are connected and the gas is on. Follow the sequence of operation for this model and a few tips on what could be the issue.
Jan 27, 2010 | Heating & Cooling
Honeywell Furnace Gas Valve Sv9501h2409 Logo
207 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
