Question about Dymo Labelmanager Lm 160 Handheld
Enlarge font dymo handheld labeler
Want to make the letters larger on my label. Keep coming up as 12pt. Want 20pt.?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 99 Answers
Please make sure the width of the tape is sufficient. You can select it every time you insert the cassette. If you would like step-by-step instructions, feel free to ring us (see dymo.com for numbers).
^CM
Posted on Mar 31, 2014
How to increase the size of the label on dymo labelmanger 350d
The manual for the 350D can be found here :
http://global.dymo.com/img/compel/32XmrxeX3QjgeRO_zF2Vp2-tPwM6g8Uz.pdf ) Page 8 of the manual shows how to alter font characteristics including some aspects of font size. Page 11 shows you how to make a label of a specific width (default is to make the label long enough for the text and then cut). Between those, you should be able to make adjustments.
Good Luck!
Sep 25, 2015 | Dymo Office Equipment & Supplies
How do I make the font larger on Dymo labelmanager 150
Changing the Font
Six font are available for your labels:
Arial Narrow, Arial Normal, Arial Wide, Times
New Roman, One Stroke and Frankfurter.
When you specify a font size, that size applies
to all characters on current page.
To set the font
1. Press the Font key.
2. Use the arrow keys to move to the desired
font and then press OK.
Also here the link to the manual for further instructions.
http://global.dymo.com/img/compel/Q5S_A-MZSgeJZGJ73tJmbPunig_yx_v1.pdf
Apr 30, 2012 | Dymo Office Equipment & Supplies
How do you increase/change font size on labeler?
To set the font size
1. Press Format
2. Select Font Size and press }.OK
3. Select the desired font size and press }.OK
The font size indicator on the display changes as you select font sizes.
Jun 22, 2011 | Dymo LabelMANAGER 210D - Labelmaker - B/W...
I have a QX50 How do I make the font and print larger?
Please see page 8 of the user guide: http://global.dymo.com/img/compel/MXvsURUAF8BtnMPX_BSn-qw6SBoEowNy.pdf
Jun 17, 2011 | Dymo LetraTag QX50 Thermal Label Printer
How do I change the size of the print on the label
Using the software that came with it modify the font settings.
Changing the Default Font Settings in DYMO Label Software Answer 299 ' Applies To DYMO ' Published 07/20/2005 10:16 AM EDT ' Updated 08/31/2010 05:05 PM EDTHow do I change the default font settings in the DYMO Label Software (DLS)?
Font settings can be adjusted for individual label templates and for the DLS application. Please note, changing the font settings for the DLS application will only affect the creation of new label templates. It does not change the font settings of any previously created and saved label templates.
Changing the Default Font Settings for Individual Label Templates in DLS
  1. Open DLS.
  2. In DLS, click and highlight the text on the label template.
  3. The tool bar above the label template allows you to change various font and justification settings. To change font type and font size you must click on the Font Settings icon: f_f.jpg
  4. Make the necessary changes to the font settings. The Sample field indicates how the text will appear on the label. Please note, the text will automatically shrink to fit if you select a font size that is too large for the address or text object on the label to accommodate.
  5. Click OK after making the necessary changes.
  6. Save the label template. Click on the File menu in DLS and select either Save or Save As. Selecting Save will save the label template with its existing name. Selecting Save As will allow you to enter a new name and create a new label template.
Mar 01, 2011 | Dymo LetraTag QX50 Thermal Label Printer
My dymo letratag prints only bottom half of a name
Your cassette tape has probably become unthread. Take the cassette out of your handheld printer. Make sure that the tape is fed under both claws on each side of the tape. If the tape is only under one claw, your label will not be flat and will only print the bottom half of the letter on your label.
Jan 03, 2011 | Dymo LetraTAG Thermal Label Printer
How do I change the font size on a Dymo Letra Tag?
For the Dymo LetraTag Plus LT-100T, Personal Label Maker (SKU: 1733013)
Before trying to change the FONT you must make sure that the labelmaker is configured to print only 1 line of text. You cannot sellect to print larger fonts when label maker is configured for multi-lines. In order to make sure you are printing only 1 line do the following
1)While pressing down on the Shift key (may be show by an up arrow on some machines), press the Del/Clear key. This will clear all text and reset the label maker to print on 1 line.
You must also make sure that there are no other print options enabled, such as: italic, bold, vertical, underline, mirrored-print, outline, etc; these will all prevent you from changing the font. Also ensure that the take will accomodate the font.
My response will depond on the exact model you have...
1) Press the FORMAT key.
2) Use the up or down arrows keys to select the Size and press OK
3) Use the up or down arrow keys to selected the desired font size then press OK
To set the font
1)Press FORMAT
2)Use the up or down arrow key to select the font style and press OK.
If this does not work, please include the exact model/name.
Sep 23, 2010 | Office Equipment & Supplies
I have a LabelMaker 450D and I do not know how to make the font a smaller size. I want to print a label that has a name in a larger size and a line underneath with the job title that is in a smaller size...
Hello. Here is a free downloadable manual for your labelmaker. http://www.dymo.com/media/UserGuides/LM450D_US_931764.pdf
Turn to pages 9-12 to learn how to change fonts and how to do multiple fonts and underlining all at once.
The label maker remembers the last feature
selection made so that each time you enter one of the
feature menus described in this section, you are
positioned at the last item selected from that menu. J.
Aug 07, 2010 | Office Equipment & Supplies
I don't know how to change the size of the font.
All support for the LP300 is on this site:
http://global.dymo.com/enGB/HowTo/LabelPoint_300.html
Manual for LP300 label printer, in pdf format (readable with Adobe Reader):
http://global.dymo.com/img/compel/MyeIYTQEI_AljQQbCRfrhqMzS5y_q9r_.pdf
Look on page 4 and 5 how to adjust TEXT SIZE, according to the label height.
When you cannot open the pdf file, Adobe Reader should be installed. The reader is freeware. Get a download from this site:
http://get.adobe.com/uk/reader/ and install the reader to be able to open the manual.
You can use the zoom function to enlarge the text view on your computer's screen.
Jun 03, 2010 | Dymo LetraTAG Thermal Label Printer
Dymo Labelmanager Lm 160 Handheld Logo
651 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
