Question about Dishwashers
Where can I get washing soda to buy - Dishwashers
  • 1,869 Answers
You can buy arm and hammer baking soda or, the arm and hammer soap has it in it as baking soda is washiing soda
Posted on Nov 18, 2013
Where to buy lectric soda cristals?
There are numerous web sites that carry the Lectric Soda Crystals. Just do a web search for "lectric soda crystals" .
Jun 05, 2014 | Washing Machines
Can I put baking soda in my whirlpool front load washer to wash new sheets?
Hi Ursula B,
You can put baking soda in your washer safely with no harmful effects.
Another good use in your front loader for baking soda.put 1/2 cup of vinegar in your washer soap dispenser,and 2 or 3 tablespoons of baking soda in the fabric softner dispenser and run a hot wash to clean and refresh your washer.
May 02, 2014 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Washing not getting clean
ok, try this before you consider removing the bowl. 1st-- buy 2 pkts of bicarb of soda. 2nd---make sure machine has no clothes in it. 3rd-- empty the 2 pkts of bicarb of soda into the bowl. 4th-- select traditional wash mode , high water level, hot water fill. 5th-- push start. 6th-- let it fill and wash for about 5 to 10 min, then turn the machine off. DO NOT LET THE WASH CYCLE GET TO THE DRAIN OUT STAGE. ok now the machine is full water and bicarb of soda and turned off, LEAVE IT TILL THE NEXT MORNING.-- In the morning select traditional wash mode, high water level, hot fill , then push the start button. let it go thru the complete cycle and all the lint and dirt should be removed from the bowl. by the way once it has started to wash lift the lid and see if the agitator is working. good luck and please reply to tell me how you got on.
May 27, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
My lg Washing Machine WF-T853A is putting black rubbery chunks and flakes through every wash.. This has been happening for about 12 mths and is getting worse to the point where half the lint bags are full...
sorry to ask you this but are you sure the flakes are rubber? usually the black flakes are lint from the clothes. to help combat this problem try this.1- buy 2 pkts of bicarb of soda or baking soda, 2- select high water fill. 3- select hot water fill.4- pour soda into an empty machine. 5- shut the lid and push the start button. 6- let it fill and wash, let it wash for about 5 to 10 min"s , do not let the water drain.7- turn machine off after letting it wash for 5 to 10 min"s , and leave the water sit in the bowl overnight . 8- in the morning start cycle again and let it go thru complete cycle. this should get rid of most of the lint. you might have to do this twice depending on how dirty the plastic tank is. please reply 4 more help and good luck.
May 12, 2010 | Washing Machines
My dark clothes has lint all over it after it has been washed, Is there something like a lint trap to clean?
need brand and model. on top loader washing machines i"ve used bicarb soda to fix problem. -2 pkts soda ___ select high or large water fill______ select hot water fill_______have no clothes in unit____ put soda into machine____ shut lid __ select wash cycle----- let it fill and wash for about 10 min"s------ turn unit off------ do not let wash water drain----- leave over nite--- in the morning restart cycle, unit will just continue to wash it will not refill----let it go thru complete cycle and that should fix problem.please reply with brand and model.
Apr 08, 2010 | Washing Machines
I was given a kenmore quei pack 2 washing machine.
best thing to do is put it on a boil wsh with castic soda in no clothes 90degrees wash ok good luck you can buy castic soda from any good diy outlet or even a chemist phamasy
Mar 26, 2010 | Kenmore Elite 45986 Front Load Washer
Moldy door ring Maytag Neptune Frontloader & poor cleaning
This is an extremely annoying problem and a very effective solution is baking soda! You should place around 200 grams of baking soda into the empty drum and then run a full cycle hot or boil wash.
This is a very effective method of reducing and preventing mold in a w/machine. I would recommend you run this "maintenance" wash once per month to prevent further build up of mold in the machine.
You can purchase a replacement door ring if the mold is extremely stubborn. However the Baking Soda also has the effect of neutralising any residue and odour that may be associated with it.
Hope this helps. Please remember to rate my answer. Thank You.
Jul 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
How clean oven??
  1. Buy an empty spray bottle and some baking soda.
    You'll find that baking soda is cheap -- especially if you buy in bulk.
  2. Using a funnel, place 3 heaping teaspoons of baking soda into the spray bottle.
    If the baking soda clogs the funnel, unclog it with water.
  3. Wash the baking soda into the spray bottle by running water into the funnel.
    Fill the bottle with water. After the bottle fills, you'll notice undissolved baking soda that has settled at the bottom of the bottle.
  4. Shake the spray bottle so that all the baking soda dissolves in the water.
    Unless all the baking soda is fully dissolved, some of it gets left behind in the bottom of the bottle as a residue.
  5. When the oven is cold, spray the baking soda and water solution on to the black stuff. Do this one or more times a day.
    It is important to work on a cold oven for two reasons:
    • Safety. You can't burn your hands if the oven is cold.
    • Containment. You'll get baking soda all over the house if you start with a hot oven. I know. I've done it.
      Starting with a cold oven solves the problem.
  6. Use your oven as you normally would. Keep spraying wet baking soda on to the top and sides of the interior of the oven between meals.
    Wet baking soda will break up the carbon sticking to the sides of the oven. Keep spraying baking soda on to the black stuff between meals until it is all gone.
    Don't worry about getting baking soda in your food. Baking soda is one of the prime ingredients of many recipes such as corn bread. It is safe to add it to your food should you do so inadvertently.
    Using this technique, the black carbon that was stuck to the sides of your oven will flow to the floor of your oven and settle there as a black carbon powder that can be wiped away.
    Your oven will look like a mess while this is in process. Choose a good time to do this.
  7. At your convenience, when the oven is cold, wipe your oven with a damp cloth.
    Eventually, you will have to wipe down your whole oven with a damp cloth. The black carbon and baking soda will will settle together on the bottom of your oven. Both are easily removed with a damp cloth.
    In theory, you will have to apply the spray bottle many times but you should only have to wipe down your oven once. Try not to wipe down the oven prematurely as this removes the active ingredient that makes the whole thing work -- the baking soda.
    Important! Let the baking soda accumulate so that it can do its job.
  8. Repeat, repeat, repeat until all the black carbon is gone.
Nov 10, 2008 | GE Kitchen Ranges
LG washing machine smelly drum
try the hotest wash not on a quick wash and put a hand full of soda crystas in the drum. you can buy these at most supermarkets.
Feb 15, 2008 | LG WM-1480FHD Front Load Washer
Dishwashers Logo
107 people viewed this question
Top Dishwashers Experts
Owen Barnes
