Question about Konus Titanium-evo 8x42 Binocular
Left eyepiece came out of socket, unfortunately went in crooked and now I can't get it off
How do I get the eyepiece out without forcing it and how to reattach it properly
Need to know who usually view my profile on facebook
Posted on Nov 18, 2013
Hamilton Beack Kettle Switch Won't Stay On
the funny looking screw is a security screw designed to prevent the average user from taking it apart.
this device was designed to force you to send it back for repair or take it to an authorized repair tech.
the switch has failed crooked due to the toggle axel breaking or pulling out of its socket
Sep 13, 2013 | Kitchen Appliances - Others
My left eyepiece on my Zhumell 20X80 will not turn to allow me to focus it. The right one works just fine. I don't want to force the left eye piece. Is there a locking mechanism I'm not aware of? Is this...
Typically the left eye piece is not adjustable. You focus the left eye with the center adjustment and then focus the right eye with the eye piece adjuster. I hope this helps.
Dec 12, 2010 | Zhumell SuperGiant Astronomical Binocular
Where can i get the eye piece for my Orbitor Land & Sky Telescope ?
This scope uses .965 eyepieces. The best place to find them would be on Ebay. Unfortunately, you can not get great selection (look for Konig or Kelner format)
If you are really interested, buy a .965 to 1.25 eyepiece adapter. There are many 1.25 eyepieces out there.
Nov 14, 2010 | Citiwell International Orbitor 7036...
I have a Swift SM80 microscope and we are seeing double images. I can't seem to adjust
Sometimes the eyepiece tubes get out of alignment. To check for this, look through the microscope. As you are looking through the scope hold the eyepiece tubes and see slightly "flexing" these tubes with your hands has an affect on the image. If your head is the problem you will be able to flex the tubes until the image is clear. You won't need alot of force. Do not use enough force to bend or break the weak metal. If this works your eyetubes and or head are misaligned. Unfortunately, once a head has been misaligned like this it is not practically repairable.
Nov 01, 2010 | Swift SM95-90HF Stereoscopic Dissecting...
I have to hold my 8 x 42 bioncuklars about 2 inches from my eyes to see thru them
Here are some instructions for setting up binoculars for your own eyestrength..
This is more common than you would think.. Any good binocular will be able to do this and the reason is to allow you to adjust them for the difference in strenght between your two eyes. I wear glasses myself and sometimes contact lenses so it's good to be able to quickly adjust them.
1. turn the binoculars over so you are looking at the underside.
2. on the eyepieces can you see on one eye(usually the right eye) a little plus - minus marking. The eyepiece should be able to rotate a little to each side of this marking.
3. Set the rotating eyepiece to the middle setting.
4. Look through the binoculars as normal and bring the two sides together until you form the two circles that you see into one.
5. Pick an object app 10 meters away.
6 Presuming that the adjustable eyepiece is on the right hand side then close your right eye, look at the middle distance object you chose with your left eye and use the central focusing knob/wheel in the middle to bring your left eyepiece into focus.
7. Now, close your left eye and adjust the rotating right hand eyepiece while looking at the same object until your right eyepiece is in focus.
8. The binoculars should now be set for the differences in strenght of your eyes and you can use the middle focus control as normal.
Most binoculars have a soft rubber eyepiece that can be folded back for people who wear glasses but I, like most people I know who wear glasses, find it horribly uncomfortable.
This method allows you to set them for yourself and if someone else uses your binoculars you can quickly reset them for you.
Hope this helps...
- Oh yeah, sorry, forgot to mention.. This set up is so you can use them without wearing your glasses.. Much more comfortable!!
Oct 12, 2009 | Equinox Optics
I see 2 planes of vision on my 8x24 weaver binocular
This is more common than you would think.. Here's how to set up a pair of binoculars to suit yourself.
Hope this helps...
Sep 28, 2009 | Weaver 849433 (8x24) Binocular
Each eye is clear, but they aren't lined up right...it is like being crosseyed.
Hope this helps...
Sep 26, 2009 | Nikon Travelite V Binocular
Double vision in minolta binoculars
Hope this helps...
Aug 30, 2009 | Minolta Activa Standard Zoom Binocular
Cannot get them into clear focus
Hope this helps...
Aug 17, 2009 | Swarovski Optik Optics
Leupold Windriver Cascade 10x42 eyepiece jammed
Sounds like one of the eyepiece screws underneath the eyecup has come loose. The rotating eyecup is threaded underneath so it can rotate into up or down position on the eyepiece. If this is the case your Cascades are under warranty and it sounds like you should send them to Leupold to examine them. They are a very reputable company and I doubt they would put it down to user misuse if that isn't the case. Bear in mind that if you have been using them in the field and have had muck on them a small foreign object may have worked its way into the eyecup thread.
May 16, 2009 | Leupold CASCADES 10X42 CAMO
Konus Titanium-evo 8x42 Binocular Logo
50 people viewed this question
Top Konus Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Schmit
Mark Schmit
Are you a Konus Optic Expert? Answer questions, earn points and help others
