Question about Frigidaire PLCS389DC Dual Fuel (Electric and Gas) Kitchen Range
How do I clean my Caloric Prestige gas range oven? The clocks for starting and stopping don't work. Is it okay to lock the door of the oven, turn the right knob (that says Bake, Broil, Clean, and Off) to CLEAN? What do I set the left knob (which has temperatures and BROIL on it) to? Do I have to turn the CLEAN knob off after a certain amount of time since the clock-timers don't work? Is it safe to do this?
  • Frigidaire Master
  • 2,005 Answers
If you lock the oven to clean it you will not be able to get it open again;
call a serviceman to repair your range; they will show you the correct procedure for setting the clean cycle.
Posted on Nov 18, 2013
4 Suggested Answers
  • 184 Answers
SOURCE: frigidaire oven door locked
SOME RANGES ARE DESIGNED TO LOCK IF THE CONTROL SENSES A TEMPERATURE EXTREME. IF THERE IS A FAILURE OF THE SENSOR THAT MAKES THE CONTROL THINK THE TEMP IS UP, IT WILL LOCK THE DOOR TO PREVENT INJURY. REMOVE THE BACK PANEL AND FIND THE OVEN SENSOR LEADS COMING OUT THE BACK OF THE OVEN. DISCONNECT THE SENSOR AND CHECK THE RESISTANCE. AT ROOM TEMP IT SHOULD BE SOMEWHERE AROUND 1084 OHMS. IF IT IS NOT CLOSE,
THE SENSOR IS BAD. PLUG IN A NEW SENSOR AT THAT CONNECTOR AND THE DOOR SHOULD UNLOCK. THEN GET INSIDE THE OVEN, REMOVE THE OLD SENSOR, AND REPLACE IT WITH THE ONE PLUGGED IN.
Posted on Apr 04, 2008
docjohn174
  • 943 Answers
SOURCE: Frigidaire oven not working in bake setting
Hi Thanks For The Question. I Would Check The Bake Element. Replace The Bake Element .Thanks The Appliance Doc
Posted on Oct 06, 2008
duby1990
  • 370 Answers
SOURCE: I have a frigidaire gallery stove. The bake not working
Your oven ignitor has gone out. This is located under the pan in the bottom of the oven. This is held in with 2 screws in the back portion of the pan. This will expose the ignitor and then 2 screws take it out. Replace this and this will fix it. very common problem
Posted on Feb 11, 2009
I have a Caloric Prestige series gas range. I don't have the manual and the clocks on the oven which allows you to set a start and end time for oven cleaning (I think that's what the clocks are for) do...
best thing you can do is to search for the manual of the unit either on the net or on the website of the merchant that sells of manufactures these units. Doing anything improperly might render the unit useless or if overdone, it might clog the heads and cause not to work, or worse, to clog and cause a build up and possibly an explosion. Don't mess with gas, do it properly and safely.
Nov 18, 2013 | GE Kitchen Ranges
Door locked
Your door lock mechanism failed. Needs to be replaced
Apr 11, 2013 | Thermador RDFS30 Dual Fuel (Electric and...
Help! I am renting an apt (and the owner is overseas) and the oven/range which came with it is an older Caloric Prestige series (gas range and oven) with self-clean feature. It has been cleaned so often...
Hello!
can you find information (sticker / label)in the body of the oven. It will be easy giving you information if you can provide the brand and model number of the oven.
Please post back!
Apr 10, 2011 | Ovens
I'm looking for a Caloric Prestige Self Cleaning Gas Range Timer Knob. Please reply to josephwilson@comcast.net. Than ks
Hello
I am sorry but here fixya.com we have no parts connections for any type of appliance, we can provide technical assistance when things go wrong, but no parts. Sorry
Dec 29, 2010 | General Electric Stove/Oven/Range Chrome...
I just moved into an apartment that has an older Caloric Prestige oven and range and cannot find the Pilot light--Please help
Hi, The caloric ranges use diferent types of pilot igniters, to avoid any further delays, I suggest geting the model number off the stove usually located under the stove's top, you don't need any tools just lift the range top(like when you are going to clean it) the model number is located usually on a metal plate in between the burners, or if it's not there , it will be inside the oven around the door liner or the oven liner. When you do locate the model, just go to the repair clinic.com website and type in the model number, follow instruction after that. see the following figure it might help in locating the model number: small_13_4.jpg
Apr 13, 2010 | Ovens
Broiler coil is on when bake is turned on...is this normal?
On some kitchen ranges, the broiler comes on during the preheat cycle to speed up the process of warming up the oven and reduce the wait time. This is intended as an energy saving feature as well by reducing the amount gas used on a gas range and the amount of electricity with an electric range.
If the broiler comes on and STAYS on while you are baking, this is NOT normal and is probably an indicaiton that you have a problem with the Electronic Oven Control (EOC) board. This is your timer/clock assembly on the operator console. The EOC controls all the oven features.
If you have any questions, please post back and let me know. Please post your MODEL NUMBER when submitting questions, so I can determine how your range is configured. I hope this helps you.
Mar 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I need an owner manuel for Caloric Range Model # EST 345 I can'g figure out how to run the self cleaning oven cycle.
you might try the following, although it is the instructions for an old model, it may be relevant;
"The actual self-cleaning process is initiated by a simple 5 step procedure: 1. Set the range clock to time of day. Note: on models not equipped with an automatic oven timer, the self-cleaning cycle is preprogrammed for a 21/2 hour cycle. Use Steps 3, 4 and 5 only. 2.Establish the length of cleaning time by:
A. Setting the start time. Press and turn the start dial of the automatic oven timer clockwise to the desired starting time. B. Set the stop time. Press and turn the stop dial of the automatic oven timer clockwise to the desired stop time. Max time is 3 hours miniumum 1/12 hours. 3. Set the oven selector dial on the control panel to "Clean" 4. Set the temperature control dial to "off". If you temperature control dial has a "Clean" position, then set the dial to "Clean" instead of "Off". 5. Remove oven racks, broiler pan and broiler grid from lower oven. Close and lock the oven door by moving the latch lever as far right as it will go - into the locked position. If the lever is accidently dislodged restore it to the locked position. Otherwise, the self-cleaning process will not take place. Shortly after the cleaning cycle has begun, the oven temperatur reaches a degree in excess of the normal broiling temperature. The red "Clean" light will come on and the clean cycle will start. In a few minutes the door lock lever, which you have placed in the locked position, will automatically be secured to prevent the oven door from beging opened during the cleaning cycle. This latch remains locked until the clean cycle is complete and the oven temperature reduces to normal baking and broiling temperaturs. NOTE: Prior to self cleaning cycle operation, the oven and surface lights must be turned offed. The upper oven can be used."
I found this here; http://www.appliance411.com/archive/21155_caloric_oven_lost_cleaning_manual.shtml
Nov 18, 2009 | Ovens
Fault code f90, door lock light keeps flashing and then the oven beep continuosly.
maximum oven door unlock time exceeded. Check wiring between eoc & door lock micro switch. more likely you need to replace the EOC
May 19, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Maytag Oven Door is locked
Suggestion from => http://www.fixya.com/support/t135369-oven_door_unlock
The first step I would recommend you to do is to turn the circuitbreaker on, then set up the oven clock. Start the self clean for anyamount of time, wait about 30 seconds and push the cancel button. Mostof the time it helps to eliminate the problem.
I've read other places that turning the fan off will unlock the oven.
Dec 31, 2008 | Maytag MGR5751AD Gas Kitchen Range
Caloric gas stove prestige series
to jenna 12 Does your stove have a stop and start timer? When you set your clock you may have inadvertantly moved the stop or start time on that timer. Check them, if they have knobs for setting the stop and start time, make sure the pointer is pointing to the current time and that the knob is popped out and not stuck in. when you have it right both the stop and the start knob should be out, not pushed in. They will pop out when you turn them to the current time.
These timers allow you to start something cookin at a time delayed several hours. this means they will not allow the oven to come on until it hits that time that you may have set in error.
If your stove has a digital stop and start timer check each one so that both show the current time, then your oven should light.
Oct 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Frigidaire PLCS389DC Dual Fuel (Electric and Gas) Kitchen Range Logo
107 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
