Question about Vehicle Parts & Accessories
How do i change the run time on my Astro start
1996 Chevy Astro V6 67K wont start when cold, needs engine starter fluid, ok when warmed up. Runs smooth. What is wrong?
I would say that the choke sensor (or whatever it is called) went bad & isn't telling the computer that it's cold & requires more fuel. Instead of starter fluid, did you try to push the foot feed 1 or 2 times?
Mar 07, 2015 | 1996 Chevrolet Astro
WHAT CAUSES ASTRO VAN FUEL PUMP NOT PRIMING BUT DOES SOME TIMES
check if the problem is when the petrol level is low in the tank.( possible intake problem rust problem.) Run fault codes to check for venting problems.
Aug 10, 2014 | 1997 Chevrolet Astro
95 Astro van is taking many times to start. Had the fuel filter changed, tried cleaner, oil changed, oil cleaner. Any advice?
hook up fuel pressure gauge see what it reads,could be low,or u can try spraying starting fluid in it take off air cleaner make sure starting fluid is getting in intake,if it starts quicker id say low fuel pressure is problem
Feb 02, 2013 | 1995 Chevrolet Astro
93 chevy astro will not start
You need to check fuel pressure. Fuel pump may be working but weak.
Mar 14, 2010 | 1993 Chevrolet Astro
4.3 Astro hard starting. will flood time to time.once it starts runs great
it could be your mass air flow sensor or a bad fuel pressure regulator.. hope this helps!!!!!
Nov 01, 2009 | 1999 Chevrolet Astro
1996 astro van stopped running
Sounds like dirty gas and the fuel filter is clogged...try changing the fuel filter...some are under the car, but most are mounted against the firewall in the engine compartment.
Apr 19, 2009 | 2005 Chevrolet Astro
Timing on an astro van
No it can not it is run by the cars computer. If the distrubitor cap is on wrong than that can cause multiple misfire
Apr 14, 2009 | Chevrolet Astro Cars & Trucks
Astro vans that won't start if it's damp/raining outside
I have a 2000 Astro had the same troubles.I saw that the sides of the coil were burned looking.In between the bar that goes around it. This started around 110K It would run badly when wet or high humidity.Then throw up the check engine lite.Put on a new coil so far the problem has no reocured.
Feb 03, 2009 | 2000 Chevrolet Astro
Astro starting problems
your battery is about to die....
May 20, 2008 | 1996 Chevrolet Astro
Vehicle Parts & Accessories Logo
60 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
