Question about Star Elite Bionaire Steam Mop
Star elite steam mop sm12 supplies - Star Elite Bionaire Steam Mop
Where can i buy mop pads for star elite model sm-05 item 400041
It looks like they may be someone "generic" as I found lots of similar "triangle shaped" pads for many different brands on ebay and amazon (.com)
Jun 16, 2014 | Star Elite Bionaire Steam Mop
Steam will not come out of star elite steam mop
There is a small, screw-on, black CAP - on the back. If it is missing, it will not build up steam pressure. Shark, has that problem. No cap = No Pressure. Try to get a replacement. It is called: STAR ELITE INC.( Depending on the size, maybe a pill bottle or soda bottle cap will work. But be very careful using a cap that is NOT original. STEAM burns are terrible !)
Mar 15, 2014 | Star Elite Bionaire Steam Mop
X5 H2O Steam Mop dripping water from small hole at bottom and not producing much steam
john, I would try cleaning the mechanism with vinegar or CLR to dissolve any buildups you can't see. Rinse, fill up with fresh water and powerup. good luck
Mar 13, 2014 | As Seen On TV H2o Mop X5 5-In-1 Steam...
How to turn it on
To switch the appliance on, press the ON/OFF button. It takes approximately 15 seconds for the steam mop to heat up. When the steam mop is first turned on, the water reservoir will glow red. Once the steam mop is ready to use the water reservoir will glow blue.
Jan 29, 2014 | Black and Decker USA BLACK & DECKER SM1620...
X5 steam mop, turns on but produces no st eam
Its likely that the tube that supplies the steam to the mop is clogged. you will need to disassemble the mop part and find that tube then push a wire up there to clear it out. Then turn the unit on and keep trying to clear with wire, you may want to wear a glove in case a sudden puff of steam comes out. This problem is common it happens because when you evaporate the water, any dissolved solids drop out onto surfaces inside the unit and make the clogs. The 'Motor' is real hot because the unit is making steam but it can't get out!
Nov 10, 2013 | As Seen On TV H2o Mop X5 5-In-1 Steam...
Need manual for star elite steam mop SM-05
None of the answers answeed my question. Just random
blah blah blah blah blah
May 21, 2012 | Vacuums
Where do you find a screw driver for the Shark Steam mop? It appears that the philips screw on the steam mop is a 'bit unique'.
I found that picking p a cheap set of small drive tools (like would go in a Battery Operated Drill motor?)-- often times these kits will have just the part you need-- It might not be a phillips, but a special star shaped bit that works?
Mack B
Jan 27, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My steam mop will not steam. the light comes on and it seems to heat up, but no steam comes out
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Oct 13, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Star Elite Bionaire Steam Mop Logo
100 people viewed this question
Top Star Elite Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Star Elite Tool and Hardware - Other Expert? Answer questions, earn points and help others
