Question about Coleman Garden
Pressure washer engine does not statt
It does not start, I have changed the spark plug, clean the carburetor and add new gasoline. It seems the gas is not flowing but I do not know what else to do.
  • Official Brand Answer
  • 4 Answers
Sounds like an engine problem. Consulting Colemen they should be able to help you directly.
Posted on Nov 19, 2013
  • 313 Answers
SOURCE: pressure washer wont idle and run
check the pressure replace valve or a bypass valve
Posted on Jun 08, 2008
  • 1383 Answers
SOURCE: pressure washer stalls
Pressure washers work under very dirty conditions, no wonder they encounter engine problems. Here are a few pointers from a former pressure pump tech. The unloader is a source of engine overloading however this can easily be checked with a pressure guage attached to the gun with a tee fitting having the guage and the normal tip used for the unit. The pressure should never rise over rated pressure. The pressure should drop considrably when trigger is released. The life of the pump and engine can be increased by setting max pressure to 75% of rating. Most engine problems are from following conditions:
Leaking or misadjusted valves; clogged muffer /spark arrester; weak spark coil that is about to fail completely; kill switch/oil sensor wiring and or sensor mal function; gas cap not venting properly causing vacuum in tank and wet or dirty air filter.
All these problems easy to check, fastest repair is to disconnect oil sensor wire to check oil safety system. Then temp replace coil with known good coil. Loosen muffer bolts to check for clogged muffler. Temp run engine without gas cap to check for vacuum. Finally if everything fails, run the engine with carb cleaner spraying directly into the intake. If the engine continues to run with carb cleaner then the problem is fuel delivey and faulty carb. enjoy
Posted on Dec 01, 2008
  • 174 Answers
SOURCE: Honda Pressure Washer HP 5 not starting
You can try spraying some carburetor cleaner into the carb. If it starts for a minute, your carburetor need cleaning. When you added new gas did you remove the old gas first? Is the air filter clean?
Posted on Jul 19, 2009
  • 583 Answers
SOURCE: excell vr2500 pressure washer ,no pressure
check the water filter ---high pressurehose must have bbackpressure to develop pressure so disconecting it wont acheive ,much ,if you have agood water supply ,oil in the pump--- adjust pressure by srewing the brass fitting that the pressure hose attachesto, down that is clock wise a couple of turns or so and see if that makes a difference if not seals in the pumpmay be gone tha t should show by water in the oil
Posted on Jul 30, 2009
  • 3 Answers
SOURCE: Karcher pressure washer with Honda GC160 engine only runs on chok
You need to remove the carb bowl, then with a small flat screwdriver remove the jet. ( on the side, at the bottom of stem.) take a small wire or toothpick and clean the gunk out of the jet, reassemble and open fuel valve, start, and pat yourself on your back.
Posted on Aug 04, 2009
I have DeWalt3750 psi pressure washer, its been long time since I used it, now that I wanted to use it, I can not start it. I already changed the oil and filled it up with new oil but still can not start,...
Here is the long answer with everything we learned while using a power washer twice a day for years::
This assumes you did not turn power washer over or on its side to drain oil, or dirty oil will flow into carburetor requiring complete carburetor cleaning.
It sounds like could be one of the problems listed below or a combination of those things.
1) The exhaust is partially blocked. Check the screen covering exhaust port for carbon and dirt build-up. High-speed exhaust air must pass freely. We finally broke the exhaust screen out with a screwdriver to get our machine going one day.
2) Gas is not flowing freely to carburetor > under gas tank, find the rubber hose connected to carburetor. Pull off rubber hose and make sure gas flows freely. You can use this hose to drain gas tank of old gas ... and then put in fresh gas.
3) Carburetor is partially gummed up and engine cuts off when gas flow slows down. Buy some gum out, and then don't store power washer with gasoline in the tank. Or put additive in gas when storing machine.
4) The choke is letting in too much gas or not enough gas. Try different adjustments. The choke-lever on our power washer got so bad that we could not set throttle at full open or the machine would die. We still use the machine at 2/3 throttle, and then start it each time using WD-40 as described below.
5) Dirty air filter that won't let engine breath enough air to keep up with combustion. Take off air filter and see if problem persists.
6) The spark coil is going bad?? Change spark plug to see if problem persists. Is spark plug wire pushed all the way onto the spark plug?
Now the nitty gritty: we're gonna start that thing right now
7) Take off air filter. Spray WD-40 directly into carburetor. Yes, we use WD-40 every time to start my power washer, and we use the washer twice a week.
Spray in the WD-40, Pull the engine cord. The engine will fire on WD-40. Guaranteed.
Once it starts, keep spraying WD-40 directly into carburetor to keep engine going.
If engine will not fire and keep going on WD-40, then your spark is suspect.
If your engine fires and runs on WD-40 but dies without it, then your gas supply or carburetor are suspect
8) Carburetor problem >>> try Gum out >>> and then take machine to small engine repair shop
9) Spark ... take out spark plug. Put spark wire back on. Hold spark plug by spark wire. Touch metal threads of spark plug to metal opening where plug came out. Metal to metal. Pull back start cord and look for spark between the metal.
If you have no spark, then spark coil is bad >>> take machine to small engine repair shop
Add a comment if you need more help
Nov 28, 2010 | Dewalt 3800 PSI Pressure Washer
I have a pressure washer at work that has good spark and starts when I put gas in the carburetor.But it wont stay running. I have the gas turned on but it doesn't seem to be getting to the carb. It's...
Here is the long answer with everything we learned while using a power washer twice a day for years:: It covers the things you already tested, but doesn't hurt to repeat. Your problem is actually #8 on list below.
4) The choke is letting in too much gas or not enough gas. Try different adjustments. The choke-lever on our power washer got so bad that we could not set throttle at full open or machine would die. We still use machine at 2/3 throttle, and then start each time using WD-40 as described below.
If engine will not fire on WD-40, then your spark is suspect.
Nov 22, 2010 | Honda Pressure Washer PSI 3000
Motor has been sitting for a while changed out old gas put new in drained carb bowl put new spark plug wont stay running
Here is the long answer with everything we learned while using a power washer twice a week for years::
Nov 21, 2010 | Garden
It starts but it shuts off immedially.
Nov 01, 2010 | Karcher 2500 PSI Pressure Washer
Can not start the engine
Nov 01, 2010 | Karcher G3025OH Pressure Washer
My pressure washer is 3 years old, never had a problem with it until now. It runs for 2 seconds only on choke. It will not start or turnover at all with out the choke on. Please help, I miss my...
Now the nitty gritty of starting that bad boy and making you happy again!!!!
7) Take off air filter. Spray WD-40 directly into carburetor. Yes, we use WD-40 every time to start my power washer, and we use the washer twice a week. Spray in the WD-40, Pull the engine cord. The engine will fire on WD-40. Guaranteed.
9) Spark ... take out spark plug. Put spark wire back on. Hold spark plug by spark wire. Touch metal threads of spark plug to metal opening where plug came out. Metal to metal. Pull back start cord and look for spark between the metal. If you have no spark, then spark coil is bad >>> take machine to small engine repair shop
Let us know how it comes out!!
Oct 15, 2010 | Honda Black Max 2600 PSI Pressure Washer
Bought unit new last summer. Used it once last summer and once this year. It started fine both times. Today, it will not crank. I have replaced the spark plug, checked the air filter (it is clean), gas...
Unable to crank? Do you mean unable to start?
If you leave gasoline inside tank over long period of time, that will 'gum-up' and ruin carburetor.
To prevent problem, put additive in gasoline or empty gas from tank:: under gas tank should be a hex bolt that holds up gas filter > loosen bolt and drain gas.
Starting the engine:
Take off air filter and spray WD-40 directly into carburetor.
Start engine, engine should fire on the WD-40 accelerant.
If engine fires but does not keep running, try spraying WD-40 into carburetor continuously to see if you can keep engine going.
If engine stops each time after it no longer gets WD-40, then carburetor is bad or gasoline not getting to carburetor or gasoline is bad.
Try fresh gasoline.
Do not turn small engine on side or upside down or oil will get into carburetor.
Check gas supply: Go to gas filter under gas tank. Pull loose rubber hose that connects to carburetor and see if gas comes out rubber hose.
If gas is flowing to carburetor, then carburetor is gummed up.
Small engine repair might suggest 'gum out' or have other suggestions ... but you may need a new carburetor
If engine will not fire on WD-40 at all, then spark coil may be bad or exhaust port is clogged
Check screen that covers exhaust >> is it covered with carbon and dirt or can air pass through it easily?
Check spark
Remove spark plug
Put spark wire back on spark plug
Hold spark plug by rubber spark cap so hands don't touch metal part of spark plug
Touch spark plug threads against hole where spark plug was removed >>> metal to metal so it conducts electricity
Pull start cord and look for sparking between spark plug threads and metal of engine (don't look at the spark gap ... look where metal meets metal
If you have no spark, the spark coil is bad >> time for estimate from small engine repair shop or get your part number and order replacement
Oct 13, 2010 | Craftsman Garden
Jul 18, 2009 | Honda 8 HP Engine
Will crank but runs rought them cuts off
Sounds like water in the fuel, or old gas. Drain the tank into a suitable waste container. Drain the carburetor float bowl, and the fuel line. Reattach the fuel line, and clean the float bowl out. (BE careful of the float bowl gasket!)
Replace the float bowl, and add fresh gasoline. I would use at least 91 octane. (NO gasohol!)
You may have to run it for a while to straighten it out.
Also remove the spark plug, and see if deposits have built up on the center and side electrode.
Todays gasoline has all kinds of additives in it. Some are designed to keep deposits from building up so much. (In truth, all gasoline is the same)
These small engines, usually require changing the spark plug at regular intervals.
Jun 06, 2009 | Garden
4 cycle snowblower wont start
clean the carb's insides. It's probably gooped up with gummy gas. I like B-12 Chem Tool. Its a spray cleaner from Auto Zone about $4. Others kinds are ok but this is good stuff.
Dec 24, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
64 people viewed this question
Top Coleman Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Coleman Garden Expert? Answer questions, earn points and help others
