Question about Minka Aire Ceiling Fan
My fan and light do not work if weather goes under 50 degrees or so, UC7067 outdoor fan rhine electric
Not sure make of fan really, thats the part number/company on sticker when i open it up..
  • mike oslo Nov 18, 2013
    double posted dont know how to delete..
    Genius:
  • Minka Master
  • 1,617 Answers
Doesn't look like a Minka Aire fan. If it has wood blades, it probably isn't an outdoor fan.
Posted on Nov 18, 2013
Testimonial: "its not wood blades, it is outdoor fan. i just don't know exact make/model can't seem to find a picture online to match."
Need part rhine uc7067 revb
Greetings Jefferson,
UC7067 is a very generic number. It means you have a flat pack receiver but there are many different versions. Here's a store that sells them and has several questions to see if the receivers they sell is compatible with your fan. http://fanmanlighting.com/shop/pc/viewCategories.asp?idCategory=74
- Jack
Jun 28, 2015 | Dryers
My remote controlled Hampton Bay ceiling fan light partially works. The fan works but the light does not. The remote control is a Rhine UC7076. Any ideas in making the light work? Also where can I buy a...
That's a low-end store brand for Home Depot only. Sounds like you need a new receiver. Make sure if you have a pull chain on the light that you pull the chain to the on position.
Dec 07, 2014 | Hampton Bay Dryers
Rhine uc7067
You probably have to do the reverse manually as you have a Hunter remote on a Emerson. Why do you want it to go in reverse?
Jul 18, 2014 | Emerson Fans Dryers
Fan and Light will not work in cold weather (under 45 degrees or so)
Cold weather may be making the lubricant too thick and impeding the motor from turning. On a cold day see how easy it is to spin the fan.
It could also be the switch is worn to the point that the cold weather causes the metal to contract then it does not have enough strength to snap into the closed position. Cold weather can also cause failures in electronic circuits or even a wire connection that is not quite tight enough.
Nov 17, 2013 | Minka Aire Ceiling Fan
Where can I get a rhine uc7067 b?
I have one like that. The capacitor connects to the motor; it has nothing to do with the light. You can try to "reset" the receiver in your fan by turning off power at the source, not at the fan, removing the remote battery power, pushing all buttons to eliminate a stuck one, reinstalling battery power, turning on power at the source, and testing operation. If that doesn't solve the problem, the light control part of the receiver may have failed.
Nov 09, 2013 | Emerson (33416-78414) Fan
Starting
Yes, I have had the same problem, only 50 years ago. Here are 3 solutions for you.
If you put a fan heater under the bonnet, you must then have electricity available to run electric things to the van.
There are 2 main things that prevent it starting in such weather. First is the motor oil.
When It gets so cold, it almost turns motor oil to jell or jelly and prevents the engine from turning over.
Car dealers and car parts stores in Northern climes sell an "engine block heater" that you plug in when the temperature is cold at night.
I have gone places in the Northern US and Canada and seen almost all vehicles with the electric cord and plug hanging out of the front grille to be plugged in in cold weather. Those are affixed to the engine to heat it.
An alternative good thing to do is take a heat lamp or even an old electric blanket, and put (or point it) at the bottom of the crankcase pan. (That's the pan where you change the motor oil.)
Also, be certain you are using 5W-20 or 5W-30 motor oil, as it is made for that temperature.
Second problem is your battery, A heat lamp or small electric blanket wrapped even partly around the battery will warm it to start better,.
Lastly, I lived in such temperature, and since I once worked at a service station, I added another battery to the original under the hood, and ran two extra battery cables, which made the car start wonderfully at 30 below 0. ( -30 F )
Be Blessed.
May 16, 2013 | 2002 Renault Sportwagon
Air Conditioning question
Let's do the overheat first.
Your van should have 2 electric fans or maybe 3, under the hood and directly mounted to the radiator.
There are usually two behind the radiator, and one in front, or visa-versa.
One of these fans is supposed to kick on immediately when you start your AC. It is probably not doing so.
The 2 things that usually cause it to fail are a bad relay or a bad fan motor.
While you are checking all this, be sure to check the other fan and fan switch (screwed in to the bock) and make sure it is working right.
The second part is much harder.
Here in Florida, where it is nearly always AC weather, I've noticed that when the van gets hot, it can take 1/2 hour to cool it. ( 100 degrees).
I have found some cars just never really cool down, so I make a real effort to always park in a shady spot and/or under a tree, and that makes a big difference in the passenger comfort.
Some car pats stores sell a dash-mounted electric fan, the kind people used 70 years ago.
Be blessed.
May 16, 2013 | 1997 Plymouth Voyager
Fan speed control electrical box burned up in less than 60 days need to replace it. Model: UC7067RK
Most the time when I hear of a UC7067 "burning up" it usually means the person has a dimmer switch on the wall that is supplying power. You will need to replace the dimmer with a standard on/off toggle switch or add an in-wall remote where the dimmer switch currently is. Both the UC7067 and WC-210 Wall controllers can be found at http://www.fanmanlighting.com/default.asp
Hope this helps!
Jan 24, 2011 | Hampton Bay Dryers
The fan/light will not come on with the remote. Yes remote batteries are new. The light fixture have power. I think the model # is JY97381. receiver # is UC7067RC. Unsure how to fix this problem. Can u...
Hello Susan,
If the indicator light on your hand-held transmitter lights up when you press the buttons, it normally means it's working. The problem is probably with the UC7067 receiver in the fan. One sure way to destroy the UC7067 is to have the power going to it controlled by a dimmer switch on the wall. If this is the case, replace the dimmer switch with a standard on/off toggle or an in-wall transmitter. You can find both a replacement UC7067 receiver and either another hand-held transmitter RC-210 or an in wall transmitter WC-210 at this address: http://www.fanmanlighting.com/shop/pc/viewCategories.asp?idCategory=57
Hope this helps!
Dec 11, 2010 | Minka Aire Ceiling Fan
Minka Aire Ceiling Fan Logo
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
