Question about HP Pavilion dv6000 dv6100 dv6200 dv6300 dv6400 Motherboard - 434722-001
Space bar keeps running
Spacebar of my laptop is pressing itself while typing.
2 Suggested Answers
mofasony
  • 7 Answers
SOURCE: hp dv8000 keybpoard problem
Hello! am Fabian,
problem.
every time i press a letter another letter shows up the space bar ...
solution.
first, be show to check if any other key is down, if not, dust your keyboard/pad to make sure the keys are free. if you problem remains, its likely your keyboard may be moist. you have to dry it by opening/ exposing it internal circuitry's to a dry air for some hours then close it up and test. if this did not work, it means you will need to replace your keyboard/pad.
when drying do not expose to direct sun light. if you have to replace the keyboard/pad buy an exart from your system manufacturer if you can.
i hope this information will be helpful.
Thanks.
Posted on Sep 21, 2008
Logitec K120 spacebar skips runs wild. How to remedy problem
I'd bet that if you pulled the space bar off the keyboard that you'll find a bunch of gunk around either the spring bar, keyswitch or both.
Either that or someone set a keyboard macro for "sticky key" on your space bar when you weren't looking.
For hints on pulling keycaps, check youtube. Getting them off is easy. Getting them back on is the hard part.
Mar 03, 2015 | Computers & Internet
The spacebar on my Sony laptop is not leaving spaces be tween words when e-mailing.Hw can I fix his as i's verynnoying
The space-bar can be lifted off using a small screw driver , this will reveal whats underneath , as it clips onto a wire structure that acts like a spring as well as pushing on the electronic button to send the signal , this can be faulty due to dirt getting lodged under the space-bar or a misalignment problem with the mechanism its self and can usually be fixed once the plastic space-bar is removed , but take note when removing the plastic space-bar key in regards to how it is attached and the position of the wire spring system so that after fixing replacement is easy .
Jul 06, 2014 | Sony Computers & Internet
The spacebar on my laptop doesn't always leave spaces between words, what is wrong with it?
Inside the key, there is a metal bar the makes the spacebar key depress from anywhere you press it. Either this bar as unclipped from its hinges or they have broken.
Jul 06, 2014 | Toshiba Satellite A100-S8111TD Notebook
Space bar sticking keyboard
There is something under the space bar you can pry it up carefully and remove the debris it should snap right back in.
Oct 31, 2013 | HEWLETT-PACKARD Computers & Internet
Space bar keeps going but not pressed
might be dirty, get a can of air, from like home depot, office max, etc. turn off laptop, take out battery, turn upside down and blow the air underneath the spacebar, this should fix your problem. If not you need a new space bar.
Chad
Apr 12, 2013 | Toshiba Satellite Computers & Internet
My Dell Latitude D630 spacebar came off. Nothing looks broken, but I can't get it back on.
If the hinge parts are not broken and are still in place then place the space bar over these parts, align it so it is in the correct position then press the space bar down until the hinges click into the space bar.
Dec 15, 2012 | Dell Latitude D630 Notebook
The spacebar on my type writer is stiff. It doesn"t press.
It is probably jammed by something undernieth. You can try to take the screwdriver and carefully remove the spacebar button (just pull the button up, but please be carefull :) ) and then check is there something under that is jamming the space bar.
May 23, 2011 | Computers & Internet
Space bar is sticky du to liquid accident ( soft
Get a Electrical/Electronic solvent spray from RS, give it a good spray (with Power Off!) and operate it lots of times. The spray will evaporate naturally and may remove the gunk! Ian.
Sep 17, 2009 | Acer TravelMate 5530-5207 Notebook
Acer laptop spacebar fell off
The space bar key is connected tothe keyboard a little bit differently then any other key.
There is a metal retainer connectedto the space bar key (on some keyboard models). Separate the retainer from thespace bar key with a flathead screwdriver.
Install the retainer back inplace as it shown on the picture. You have to engage the retainer with thesmall hooks on the keyboard.
Put the space bar key back inplace and gently press on it with fingers until it snaps back in place.
That’s it. The space bar key isinstalled back in place and should work as before. If you still cannot fix yourkeyboard, then you’ll have to find a new oneand replace it.
Pleas rate my solution on fixya if you are done.
Dec 28, 2008 | Acer Aspire 1360 Notebook
Sidekick lx spacebar
Go to:
http://www.fixmysidekick.com/sidekick-lx-or-sidekick-2008-space-bar-not-working/164/
Or just read this...:
sidekick2008spacebarpicture.jpgIs the space bar on your Sidekick LX not working when you are trying to text or in AIM? Do you have thesame space bar button problem on your T-mobile Sidekick 2008? Does the Sidekick spacebar work in other apps though?
If so then this fix is for you.
1. Open the AutoText & Spelling screen. From the Jump screen, press the MENU button, then select Settings > AutoText & Spelling.
2. Uncheck the following settings:
    • Highlight misspelled words
    • Auto correct spelling
3. Exit out of the settings screen and try it out.
Hopefully, this will have solved your issue.
How to check for misspelled words with these two options unchecked?
Run a manual spell check on T-mobile Sidekick: To run a spell check while in a text field from any Edit Text submenu, or by using the keyboard shortcut by pressing MENU +S.
Dec 19, 2008 | Sharp Sidekick LX Smartphone
HP Pavilion dv6000 dv6100 dv6200 dv6300 dv6400 Motherboard - 434722-001 Logo
15 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
