Question about Sportcraft Voyager Foosball Table
Sportcraft - hartford foosball table assembly
Instructions
Which Foosball table would be the best for my office? Where I would get it?
There are lots of Foosball table you can get online as you will be having lots of option there. You should buy the Foosball table weighing not less than 200 pounds with a recommended rail thickness of 1 ½ inches.
I ave also purchased the Foosball Table from the "mancavemaster". Here you will get the table under $1000 and there are many varieties for the Foosball table.
Oct 26, 2016 | Sport & Outdoor - Others
How do I order a replacement part for a sportcraft foosball table? I cannot find a contact number for the company
You may not find it, however an epoxy may be suitable to repair the broken pieces. Or you may be able to screw a support plate to the side piece, inside where it will not show.
Jan 17, 2015 | Sport & Outdoor - Others
Sportcraft foosball table parts
I found parts on amazon, click here and take a look: new Spin on Foosball Real Teams Players. I hope this was helpful. Cheers
Nov 29, 2012 | Sport & Outdoor - Others
What's the difference between traditional foosball (table) players and modern foosball players?
Traditional foosball balls are cheap balls that came about during the 1970's. Today, they are found in low quality foosball tables. The annoying thing about them is the inset lines that make the balls constantly roll even when the table is leveled.
Aug 12, 2012 | Sport & Outdoor - Others
What features should I look for when buying a foosball table?
When buying a foosball table, make sure the rods are light and can be moved easily, the surface of the foosball table is even, handles are easy to grip, and the foosball players are capable of catching a pass and pinning down the ball.
What's the dimension of a foosball table?
Football tables can vary in size, but a typical table is about 120 cm (4 ft.) long and 61 cm (2 ft.) wide. My own foosball table is 120 on 74 centimeters and it fits right for a normal sized room and very comfortable to play with, I suggest you to get the adjustable when you buy your table.
Jul 29, 2012 | Sport & Outdoor - Others
What's better standard foosball table into an adjustable one?
My advice is to buy an adjustable foosball table because the regular one stays at the same height level and can't be changed in case it's too high or too low making the foosball experience not very comfortable.
Sportcraft  Voyager Foosball Table Logo
149 people viewed this question
Top Sportcraft Toys Experts
ray gallant
Are you a Sportcraft Toy Expert? Answer questions, earn points and help others
