Question about RTO 47cc / 49cc Pocket Dirt Bike Atv Ignition Coil 2-stroke
How to hot wire a pocket bike
I can not start my pocket bike it has a 49cc engine but i dont have a key and there is four wires coming out of the key slot underneath so one black wire one black/white strip one green one red wires making it four in total i dont know how to hotwire it. I have already checked spark plug mixed oil and gas and it has a pull start engine friend said its also electric start but did not specify
How to install an electrical wiring to 49cc atv
I think you want to put a light on it??? you will need to install a battery to do it right. BUT you can run a LED light right off the magnito. connect to the wire to the wire on the mag that goes to the kill button, Start the engine and check the voltage, if it is more than 14 Volts you need to install a rectifier to drop the voltage down. You can do it with a good resistor if its not too high. Remember... the engine is designed to make enough power to run the engine only. A LED light uses 1/5 the power of a incandescent light so that might work for you.
Apr 20, 2012 | Quad 47 cc / 49 cc Pocket Mini Bike...
Does the coil have to grounded to the engine block or just the engine bolted to frame ok for 47 cc pocket bike
coil needs to be grounded and make sure theres no paint at mounting points of motor to frame
Feb 22, 2011 | RTO 47cc / 49cc Pocket Dirt Bike Atv...
I have a black wire from a ignition coil not plugged in where does it go?
on the spark plug.if that is not it then it might be a earth cable that just gets bolted to the frame of your bike
Oct 12, 2010 | RTO 47cc / 49cc Pocket Dirt Bike Atv...
How to fix a 49cc pocketbike forks?
some times its better to get new forks, as they can be stressed when straightening them, you dont need them snapping off while your riding
Apr 12, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
How to start 49cc, 2 stroke mini Harley motorcycle
hi i have just brought a mini harley 49cc bike
in red and black and dont have all the light the kill switch wire has been cut and on the brake leves not the brake wires have been cut for the lights or something there is no battrey on it ent got a key
how could i get it started
Mar 09, 2010 | RTO Mini Quads
Pocket bike prblems
Get some engine starting fluid and spray a small amount in the air intake. If that doesn't work take out the spark plug and see if it sparks when you pull the cord and make sure it is not fouled. If it is wet with fuel dry out the plug and pull the cord a few times to clear the cylinder. Fresh premium fuel always works best on temperamental engines.
Sep 06, 2009 | Quad 47 cc / 49 cc Pocket Mini Bike...
RTO 47cc / 49cc Pocket Dirt Bike Atv Ignition Coil 2-stroke Logo
104 people viewed this question
Top RTO Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a RTO Cycling Expert? Answer questions, earn points and help others
