F13 whirlpool resetting doesn't work and unplugging doesn't help
  • 37 Answers
F/13--Dispenser Circuit Error
Posted on Nov 18, 2013
What is error code f13?
The F13 fault code on this type of range indicates that the EEPROM (Electrically Erasable Programmable Read-Only Memory) on the control board is bad. This can be caused by a power surge or glitch through the electrical lines. You can try to reset the control board by completely unplugging the range (or shutting off the breaker) for 5 minutes. If the error code returns after plugging the range back in, then the control board for the range will need to be replaced.
Feb 05, 2015 | Thermador C301U Electric Single Oven
Washer was just moved to a new house and doesn't work. It has F-13 code.
F13 Dispenser circuit error
Possible causes/procedure:
1. Unplug washer or disconnect power.
2. Check mechanical linkage from dispenser motor to the top of
the dispenser.
3. Check wire harness connections to the dispenser motor and
Central Control Unit (CCU).
4. Check dispenser motor for powered rotations.
Jul 02, 2011 | Washing Machines
Hi, the Whirlpool 6 sense, after 800 rpm spin-dryer signalling F13 erroe code. Emptied, doesn't work anymore. Also display is off. What happened?
I change my facebook security code at 5 time for any problemme is called sarrawunded by changed of location.my security name is murattuu oromoo
ADDITIONAL INFORMATION CONTECT TO MY FACE BOOK TO FACEBOOK CAMPANY FOR SELECTED ATILIST ROBINAD FOR BROSERIN
Jun 23, 2011 | Acer Aspire One PC Notebook
I have the f13 error, on whirlpool duet ht, 9150. I have removed the top and I'm trying to run a drain and spin. The motor seems to work fine as it cycles through all four steps, but never seems to...
F13 codeindicates that the dispenser motor is not able to be driven to it's properposition.
*Check mechanical linkage from the dispenser motor to the top of thedispenser.
*Check wire harness connections to the dispenser motor and CentralControl Unit (CCU).
*Check the Dispenser Motor.
Toremove the error display, press Pause/Cancel twice. IfPause/Cancel does not work: *Unplug washer or disconnect power for oneminute.
*Plug in washer or reconnect power.
*Re-select the cycle and press Start. Hopethis helps.. Good luck! :)
Jun 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F13 and door not opening washing stuck ith cage .
Hi
F13 is a door lock error which means that the door lock is bad and should be replaced. To unlock the door you can leave it unplugged for around 10 minutes and the door will unlock. Hope this helps...please post back for further assistance.
Daniel
May 10, 2011 | Whirlpool AWOE8748 Front Load Washer
Im getting F13 on my oven display when trying to use it?
Sabrina I do not see an F13 Error Code for Whirlpool, Try unplugging oven for a few minutes and then plug or switch power back on from breaker and it should reset. Also send the exact model number located inside your bottom drawer door or oven door. Here are all the codes listed for Whirlpool=> Whirlpool Fault Codes You also can find your user manual here=> Whirlpool User Manuals and model number Locator's here=> Model Number Locator's I have spent a lot of time trying to help and will be happy to assist you if you have more questions, Thanks, Sea Breeze
May 01, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Cant reset my f13 fault and wen i power on it takes its take to lite front panel up
Hi again,
Whirlpool AWO 'F13' decodes as 'dispenser circuit failure'. If you have tried switching off and back on again and it is still there I suspect it means that you will have to call an engineer. Sorry ;-0(
Good luck,
John C
Mar 29, 2011 | Washing Machines
I have a F13 fault that wont reset on a AWOE9759. I do not know what a F13 fault is but i have tried what it says to do in the manual. Please help.
F13 Error = Dispenser circuit error
If the dispenser motor is not able to be driven to it's proper position.
Potential Causes
• Check mechanical linkage from dispenser motor to the top of the dispenser.
• Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
• Check Dispenser Motor
Replace failed component.
Dec 26, 2010 | Whirlpool Washing Machines
THE F13 CODE IS SHOWN AND THE MACHINE DOOR WOULD NOT OPEN UP
F13 is a door lock issue. Firstly push the door hard towards the frame and then pull imediately back towards you it may take several attempts but the door will open, it may seem harsh to do this but i have done it a few times and it works. This should reset your door lock if the problem persists then replace the actual pin that is on the door (should have 2 screws holding it in place) that enters the cabinet. Not the door lock that is inside the cabinet.
Hope this helps
Nov 06, 2010 | Whirlpool Washing Machines
Frigidaire CPL-EF398DCK
If unplugging doesn't reset it, then EOC electronic oven control is most likely defective
Nov 15, 2017 | Frigidaire fes365e Electric Kitchen Range
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
