Honeywell emm 3
Not working on auto - only on. I read a bunch of articles and learned it might be a poorly wrapped coil, fan speed controller, a misplaced wire (I found 2 that were open and i fixed) or most probably the emm3 control board just fried. Before I buy a new board is there any way to test the board with a volt meter?
SOURCE: Lennox G26 gas heater Elite 90 Q2-50
need new ignition probe
Posted on Dec 17, 2007
  • 1314 Answers
SOURCE: Frigidaire GLTF2940ES0
remove the bottom panel will find a tech sheet there with more specific instructions and the speed control bd is under the tub on the left hand side unplugged the unit before checking and the door lock is part of the com system turn the washer and see if the door lock light comes on try to open the door with the light on if you can that's where the problem is
Posted on Jan 16, 2008
  • 36 Answers
SOURCE: speed control switch
I saved this text I found when I was researching this a while ago.
Let us know how you do.
Wiring a three speed fan switch
My daughter called me the other day and said Dad the ceiling fan in the kitchen is not working only the light works. I went over and removed the three screws that hold the light and pull chain for the fan down and found that the fan control switch had snapped open and all 4 wires had popped out. The snap clips on each side of the switch had broken off. I went down to Home Depot in the ceiling department and found the switch I was looking for. It said for a four wire ceiling fan. OK, know lets put it back together. First of all if you look at the new switch you should see four holds were the wires will be pushed into. The black wire in the fan is the hot or load wire, this wire is hot whenever the wall switch to the fan is turned on. Put this wire in the hole that is marked “L” this stands for load. Now with this switch in the off position the fan will not work until you pull the chain. The other three holes are marked #1, #2 and #3. On most fans #1 is usually high speed. # 2 medium and #3 low speed. What you now have to determine is what wires are high medium and low. The easiest way to do this is before you put any of the wires back into the new switch is to FIRST MAKE SURE NO POWER IS GOING TO THE FAN. Then simply take one of the colored wires at a time and twist it together with the black hot wire.
Turn the power back on to the fan and knot the fans speed. Do this with all three wires one at a time until you can determine which wire is high speed. Note the color of the wire and mark it down on paper.(Example; blue wire high speed.) Do this with the other two wires to determine there speed. Once you have the speed of each wire you can reassemble the new switch.
Black wire (Load) goes in hole marked L. High speed wire goes in hole marked # 1. Medium speed goes in hole marked #2 and low speed goes in hole # 3. MAKE SURE THE POWER TO THE FAN IS TURNED OFF WHILE YOU ASSEMBLE THE NEW SWITCH.
For those of you that have all these wired hooked up right and still the fan won't work I would then look for an open neutral wire. It should be a white wire. Check to see if all the wires are securly attached.
Good luck. One more word of advice. If you're not sure on what you are doing when it comes to electrical wiring then please do not attempt to do this or any other electrial work yourself. Call a licensed electrian. Any mistakes on your part could void your home owners insurance in case of a fire.
Posted on Aug 23, 2008
  • 11 Answers
SOURCE: Heater/ac switch speeds 1 and 2 don not work in 99 Silverado
you need a resister found under your air duct by the passenger floor under dash board auto zone sells these for about 25.00 you may as well buy cabin air filters while your at it . 1 of the screws will be a pain to install back into the duct work I left mine out didn,t make a difference . you might have to order it as they are a comman item oh you will need a vacuum to clean up mess from cabin air filters .this is not a hard job .
Posted on Feb 28, 2009
  • 234 Answers
SOURCE: AC Control Transformer keeps failing.
well it has blown the fuse on the transformer, then you have coil switch bad.It could be the coil on the contath in for cooling.But can check by taking the yellow wire a loose and see if the don't blow. The red wire is one side of the transformer and the com could be any color.But look at the red wire because it is the main wire that travel the voltage throuhg the unit.
Posted on Mar 26, 2009
My Honeywell EMM-3 zone controller system LED is flashing orange, indicating DAT fault. However I do not have any sensors hooked up.
Check to make sure your compressor is running fir the zone in question. DAT is a discharge air temperature reading that the unit uses to monitor itself. If you're sure you never had one, check the parameters and programming of your unit to make sure something didn't glitch and enable your DAT sensor
Aug 16, 2016 | Honeywell Heating & Cooling
Honeywell emm-3 goes to high heat when thermostat does not call for heat
Replace it (thermostat), but first make sure its in a good location to read the space temperature.
Nov 29, 2013 | Heating & Cooling
I need the manual for the Honeywell Mini Zone control module. The only numbers I could read are as follows; 06161, EMM-3u, 32003618-006. Does that help? Thanks.
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Apr 22, 2010 | Heating & Cooling
Only blowing air when i program for heat
Generallyif gas, the heat speed is low and routed through a normally closed switch in the fan relay, the fan relay has another inverseley proportional switch to the normallyclosed m a normally open one that sends power to high speed for AC or fan on position rather than fan auto. In auto the normally closed has power passed through to a temperature or time delay, that controls the heat or low speed.
Apr 07, 2010 | Honeywell Programmable Thermostat Heater
I have an intertherm electric furnace FEH-A020, with multispeed blower installed when A/C added. My problem is blower operation. at the end of the cooling season with fan set to auto operation the fan ran...
The model of T-stat you gave comes up as a discontinued model on Honeywell's web site, but it looks to be a manual stat that type of stat would have to be wired with a summer winter switch with electric heat, allowing it to turn on the fan with a call for heat. If yours is a programmable T-stat you would need to select electric heat or in the installers set up change the default setting for fan from unit controls fan in heat to thermostat controls fan.
Oct 17, 2009 | Intertherm P3RA-048K Air Conditioner
Wiring for zone valves
here is a site for your system but not sure what you need to know, if you need more hwlp post here and I will help you. http://dticorp.com/catalog/honeywell-emm3uk-conventional-zoning-p-4341.html#
Oct 05, 2009 | Honeywell International Honeywell EMM-3UK...
My Honeywell EMM-3 zone controller system LED is flashing orange, indicating DAT fault. How do I verify the DAT is faulty?
Hi
Thanks for using FixYa. Perofrm this test--
Connect DATS Sensor to EMM-3 (optional).
a. Reconnect power to EMM-3.
b. If system is in Purge mode, press PURGE OVERRIDE on EMM3.
c. Verify SYSTEM LED is no longer flashing. This confirms proper DATS operation. (Flashing occurs in Idle and Fan modes only.)
Also see page# 9 & 10 from this link--
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 28, 2009 | Heating & Cooling
Codes for 1995 Mitsubishi eclipse
Engine-light-help.com
P1100 Induction Control Motor Position Sensor Fault
P1101 Traction Control Vacuum Solenoid Circuit Fault - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1102 Traction Control Ventilation Solenoid Circuit Fault - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1103 Turbocharger Wastegate Actuator
P1104 Turbocharger Wastegate Solenoid
P1105 Fuel Pressure Solenoid
P1294 Target Idle Speed Not Reached
P1295 No 5 Volt Supply To TP Sensor
P1296 No 5 Volt Supply To MAP Sensor
P1297 No Charge In MAP From Start To Run
P1300 Ignition Timing Adjustment Circuit - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1390 Timing Belt Skipped One Tooth Or More
P1391 Intermittent Loss Of CMP Or CKP Sensor Signals - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1400 Manifold Differential Pressure Sensor Circuit - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1443 EVAP Purge Control Solenoid '2' Circuit Fault
P1486 EVAP Leak Monitor Pinched Hose Detected
P1487 High Speed Radiator Fan Control Relay Circuit Fault - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1489 High Speed Condenser Fan Control Relay Fault - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1490 Low Speed Fan Control Relay Fault
P1492 Battery Temperature Sensor High Voltage
P1494 EVAP Ventilation Switch Or Mechanical Fault
P1495 EVAP Ventilation Solenoid Circuit Fault
P1496 5 Volt Supply Output Too Low
P1500 Alternator FR Terminal Circuit - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1600 Serial Communication Link
P1696 PCM Failure EEPROM Write Denied
P1698 No CCD Messages From TCM
P1715 Pulse Generator Assembly
P1750 Solenoid Assembly
P1791 PCM ECT Level Signal To TCM Circuit Fault
P1899 P/N Position/Transaxle Range Switch Circuit Fault - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1751 A/T Control Relay
P1791 Engine Coolant Temperature Level Input Circuit - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
P1795 Throttle Position Input Circuit To TCM - Read Our Article On Automotive Circuit Testing For Help With This Mitsubishi Check Engine Light Code
Mar 21, 2009 | 1995 Mitsubishi Eclipse
Fan stopped working
Hi and welcome to FixYa,
Offhand, moving the fan from one room to another should not cause it to cease operating. A couple of ideas you may want to consider/try:
  • with the multimeter set to X1, check the resistance of the 2 prongs of the AC plug;
  • selecting each of the speed other than OFF should show a reading;
  • if there is a reading on any speed selection and yet the fan will not turn, with the fan unplug, turn the blades manually. it should rotate freely/easily. If not, then possible dirt accumulation on the bearings or a stuck up;
  • if there is a reading, the blades turn easily and selecting any speed, the motor only hums but not turn, then the start up capacitor is faulty;
  • if no reading at all, then the unit has to be opened up to expose the rear of the switch and the wirings inside;
  • check for the continuity of the AC cord from the plug to where it enters the body of the fan;
  • if everything checks out, then suspect the motor. To check motor, there would normally be 6 wires from the coils; 2 for the starter capacitor, 1 for the common and three for the different speeds. Check their continuity.
Good luck and thank you for using FixYa.
Feb 14, 2009 | Honeywell HS-300 16'' Stand (Pedestal) Fan
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
