Question about Craftsman 20568N 85 Amp 120 Volt Gasless Wire Feed MIG Welder
Fan runs but nothing else
Plugged in fan runs but nothing else does
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,095 Answers
Check small wire on opposite end of Gun. May not be connected well
Posted on Nov 21, 2013
Fridge not running at all!
did the fridge work before you started to work on it? why did you replace the fan?
Sep 03, 2015 | Refrigerators
Should rear fan run all of the time or only when needed?
Depending on if the fan is plugged into only a molex (power) connector, or into a fan port on your motherboard, it could go either way. If it's plugged into the motherboard, there's a good chance the motherboard is controlling it thermostatically. A case fan venting out is always a great way to help improve airflow and keep components cool.
Hope this helps!
Sep 16, 2014 | Systemax Tiger (SYXS-DC-1000) PC Desktop
Sys fan nor cpu fan working and black screen
Try a known , good working PS. If that does not do it, you have serious mo bo issues.
Mar 27, 2017 | ASUS PTGD1-LA Motherboard
Voltage not going to cpu
Not sure just what you mean. If your computer is plugged into the wall and the power is turned on, the power supply should be on and the cooling fan turning. Also, the CPU fan should be turning and the hard drive should spin up.
Note that the power supply is the main component that must be supplying the power. If you don't hear or see the fan turning in the power supply and the little power light on the front of the computer does not light, replace the power supply.
If your power supply is running and nothing else is running, I would unhook all devices and leave just the CPU and video and memory in. If you get nothing, then the motherboard is probably bad.
Sep 22, 2011 | Computers & Internet
I have a kegerator. It's not functioning. When plugged in no clicking no sound nothing. Wondering if it's the overload switch or relay.
http://www.haieramerica.com/en/asset/product/1ffd77cfa0
This site has your product manual for your dispenser but it is very vague on trouble shooting the cooling system.
In general, the compressor is controlled by a thermostat that is usually located in the conditioned space. It cycles the compressor on and off based on the sensed temperature and the setting that it is adjusted to.
So, let's talk in general refrigeration terms. Where the compressor is located, is there a fan? If so, is it running? That fan is usually the condenser fan and is wired to come on anytime the compressor is supposed to be running. If the fan is running and the compressor is not, then there is an issue with the compressor. If the fan is not running and the compressor is not running, then there is an issue with either power or the thermostat. If the compressor is running and the fan is not, then there is an issue with the fan.
This is a good starting point. Let me know if I can be of further help.
Mar 24, 2011 | Haier HBF05EBSS Commercial Beverage...
I have a Lenovo 3000I have a Lenovo 3000 J115 7387-A32, I replaced the AMD athlon 64x2 Dual-Core 3600+ with a AMD Athlon X2 5000+ 3200mhz Scoket AM2+ CPU, when I turn on the computer the fan in the power...
I think the first thing to do is go back to the cpu Fan and check the plug and make sure you are on the pins as should be make sure that there isn't any Bent pins . Continue on to the next fan in question.If not then I would not continue Running this machine Until I had the fan problem fixed. It doesn't take long to mess things up. I am surprised that it will run . I would like to have faith in the hardware monitor to propely shut it down.then I would go to the power source Plug on the motherBoard . Check that it is connected good and try it for a short run on then off to make sure that the fans are running like they are supposed to.
Nov 19, 2009 | Computers & Internet
Fridge dont run
if all fan working check compressor call service
Mar 31, 2009 | Frigidaire FRS26R4A Side by Side...
Craftsman 20568N 85 Amp 120 Volt Gasless Wire Feed MIG Welder Logo
119 people viewed this question
Top Craftsman Welding Tools Experts
AZBen
AZBen
Gil Shultz
Are you a Craftsman Welding Tool Expert? Answer questions, earn points and help others
