Question about Fujitsu PlasmaVision P50XHA40US 50 in. HD-Ready Television
Mount the television plug in power and the tv doesn't go on
I have pulled off power cable from my L32U20D wall mounted TV set how do I put it back without dismounting my tv
There are not any easy ways to insert the power cable to the TV while mounted. You can do so but be very careful. I suggest that you dismount the TV for safety reasons. The base of the TV should be stationery and mounted so that you can properly mount the TV back once you have plugged in the power cord.
Feb 20, 2015 | Televison & Video
Www magnavox com usasupport
fried power supply board replace it but first check power cord if ok check the fuse in the plug for the inside of the tv u will need the tech
Jul 07, 2013 | Televison & Video
Tryn to take tv off wall mount
Doesn't matter what brand TV, rather what brand mount what used. There are ussually retaining bolts or a release of some kind on the bottom of the bracket.
Sep 02, 2011 | Dynex Televison & Video
THE T V WILL NOT POWER ON
plug the cord into the outlet. If the wall outlet doesn't work find a different one. If the tv doesn't turn on with the remote take the plastic off of the batteries in the remote. if this all doesn't work, then there's something wrong with the tv and you should return it and get a new one.
May 16, 2011 | Tatung LD30HL Television
Tv has power in stand by mode but no power or blue led light when trying to turn on. it seems the tv has no power
Unplug the T.V. and hold the power button down for 30-60 seconds. Plug the T.V. back in and try powering on. If it still doesn't power on then you may need a firmware update, or something on the board has gone bad such as the power supply or capacitors. You can take off the back of the T.V. and look for any swollen capacitors on the board and see if the power supply looks ok.
May 06, 2011 | Hitachi 42HDT79 42 in. Plasma Television
When I turn on my set, light turns green, then after 30 seconds turns red won't come on
Sounds like there is a problem with the power supply. Try unplugging the T.V. and hold the power button for 30 seconds. Plug the T.V. back in and see if that helps. If it doesn't try switching to another outlet, and if that doesn't work then you may need to replace the power supply which would probably cost anywhere from 140 to 200 for one.
May 05, 2011 | Fujitsu PlasmaVision P50XHA40US 50 in....
Sanyo television doesn't turn off either by using the remote or by turning it off at the tv.All other fuctions work using the remote or directly on the set.Even using the sleep timer doesn't turn...
Unplug the set and hold the power button for 30 seconds. Plug it back in and see if that fixes it. If it doesn't then it sounds like there is a problem on the board underneath the power button. Something isn't allowing the circuit to be cut.
May 05, 2011 | Televison & Video
Please i need manual for norcent lt-3751 lcd 37" tv because this tv dont power on
Make sure the power cable is plugged into the T.V. and the wall outlet. If it still doesn't power on try a different outlet. If that still doesn't work then there might be a problem on the board that needs repaired.
May 05, 2011 | Norcent Technologies LT-3751 37 in. LCD...
Received a panasonic th-42pz80u from my father in law. He said it did not work. I plugged it up and it worked for a few hours. Now I get nothing when I plug it up. Is there anything I can do to restore...
Try using a different outlet, if that doesn't work see if you have another power cable that is the same power as the one on the T.V. and try that. If that doesn't work then there is probably a problem on the board near where the power plugs in. It could be fixed by a firmware update or it may need to actually be repaired.
May 04, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Fujitsu PlasmaVision P50XHA40US 50 in. HD-Ready Television Logo
27 people viewed this question
Top Fujitsu Televison & Video Experts
Electro Med Services...
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
