How to Change the power supply on my vizio tv
  • 3,904 Answers
Find something soft to lay the television flat on its face. Remove the back of the unit. about 15 screws. locate the power supply board and unscrew it from its position and remove all connectors plugged into it. Mark the wires/connectors or take some pictures so when you get the new supply you can get it back together correctly.
Posted on Nov 18, 2013
3 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: the vizio light comes on as if the tv was turned on / the vizio light does not go dim to bright when the power switchis applied / tried changing power supply board / no change
frankly having it posted as a Sony does not help. Aside from changing a board you did not need to change what other simple steps have you taken? Vizio model number?
Some of the simple things (if you can see Vizio logo and it stays set is on) does it work via a DVD player etc, does it have audio etc.
It is here up to each expert to choose if they want to answer a question or not, with wrong model etc many may have just passed on your question.
If you get the Vizio logo and or OSD let us know that, the more clues the better.
My reaction would not be power supply but maybe just maybe a main board.
I would of course try other signal sources first, remove a cable or sat box and the set from power to see if things change or not.
Up to you how you word the question and what information you provide but up to us to decide if we want to try to help or not.
I personally answer over 400 questions a week so want to help if there is enough info for me do at least try to do so.
It says here zero views of this question which is why I took another look at it.
Posted on Dec 11, 2012
  • 7 Answers
SOURCE: vizio Tv stuck on splash screen
It may be Broken, Or Its power supply Might only have enough to do the splash screen but not continue
Posted on Aug 26, 2013
Vizio tv E470VL. Replaced power board and no change. Front vizio light will glow at bottom but tv will not come on. Please help.
Power board isn't the issue. Its the digital board and/or bad panel. As much as I love to repair things, Vizio is one company who isnt worth it. I have seen 14month old TVs with bad panels. The E470VL is a known problem TV. The panel is probably shorted and its keeping the digital board in protection which is keeping the power supply from starting. Its really frustrating. I wish Vizio would stop making such sub-par equipment.
Dec 20, 2017 | Vizio Televison & Video
My Vizio Tv will not come on with the Tv bottom or by using the remote.
Check the power supply voltages, could be the main or power board, you will need to see if you have PSON voltage or PON, depending what its labeled on the power supply board legion. If you see a change there then its the power board
Dec 10, 2017 | Vizio Televison & Video
Vizio tv no sound or picture?
Could be the capacitors going or have gone out. This is a common problem with Vizio TVs...including mine recently. Check out YouTube for tutorials on how to change the capacitors.
May 09, 2016 | Vizio Televison & Video
What are the symptoms of a bad psu for vizio m550nv
Vizio 0500-0612-0030 Power Supply / LED Board for M550NV
www.shopjimmy.com/vizio-0500-0612-0030-power-supply-...
ShopJimmy
$77.42 - ‎Out of stock
This Vizio 0500-0612-0030 Power Supply / LED Board for M550NV (0500-0612-0030) works for these ... The odds we'll get it soon: Bad (What does this mean?).
Vizio 55" M550NV 0500-0612-0030 LCD Power Supply ...
electropartsonline.com/vizio-55-m550nv-0500-0612-0030-lcd-power-su...
Vizio 55" M550NV 0500-0612-0030 LCD Power Supply Board Unit Motherboard. ... Any tears or bad connections between boards must be replaced FIRST. 2.
EASY HOW TO FIX LED Vizio TV- no power - YouTube
? 6:13
https://www.youtube.com/watch?v=9xZcTWr2yV0
Nov 5, 2013 - Uploaded by Tampatec
DiY How to Fix led / lcd Vizio TV service repair - no power service repair ... I can not get it to power on so I ...
Jan 17, 2016 | Vizio M550NV 55 in LCD HDTV
How do I fix my lcd tv that won't turn on? It does not appear to be the powerboard.
Vizio logo is an indicator that the tv is live n changes to white that the screen is on meaning if no change to white the smps switch mode power supply board ain't switching the mother board....diagnosis is its MOSFET transistors need replacement or the smps board n ya tv will be fine
Sep 22, 2015 | Vizio XVT473SV 47 in. LCD HDTV
Vizio vw42lhdtv10a 42" vizio will not turn on the vizio light is orange when tv not on and white when tv is on it turns white but i get no video or audio the screen doesnt change like it even wants to come...
check out the power supply board! Look for popped capacitors. They either leak or swell up. They are the can shaped things on the board with the plastic coverings on them...you can usually see a swollen cap sticking up over its covering as a telltale sign.
Good luck and be careful
Mar 16, 2010 | Vizio VW42LF 42 in. LCD HDTV
No Sound, No Picture
I had the same issue on my Vizio and fortunately it was still covered by the Costco extended warranty from where I purchased my tv. The service tech came out yesterday with a power supply and main board which is what I understand is usually the issue with your and my symptoms. He replaced both boards although he felt the issue was in the main board 3647-0072-0150 and not the power supply. Tv is working just fine now and actually may be even a little clearer after the board switch. I understand you can purchase the boards and from what I've seen the tech do, it is no more difficult to replace than if you were building a computer if you are comfortable with that. The most time consuming part of the repair was removing and replacing the screws.
Apr 30, 2009 | Vizio VO47L 47 in. LCD TV
Vizio P4 Plasma TV, won't turn on
if your vizo p4 blinks red 10 times its your power supply board ckeck your two fuses on the board,if those are not bad change your power supply board if you can find a board for that model vizio p4 .the phillips tv uses the same board
Oct 11, 2008 | V, Inc. Vizio P4 Plasma Television
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
