Question about GE JB640SRSS 30" Free Standing Electric Ranin Stainless Steel JB640
Replace Inner Hidden Bake Element
Hidden bake element needs to be replaced but there are no screws on bottom inner panel and would not lift. The opening looks like it is for removing he entire interior of the oven. Hmmm?
4 Suggested Answers
SOURCE: jp 989 switch replacement
not timely but no.
i have a dead switch, had to unhook it cause it kept tripping the breaker. 3 out of 4 work now.
can i buy 1 switch or do i need a whole new assembly. where to buy online ?
Posted on Oct 23, 2008
  • 37 Answers
SOURCE: large combination burner in glass top cooktop just
Yes it sounds as if you have control knob probs ..did it work b4 or is it a new cooker ?
Posted on Sep 06, 2009
SOURCE: stove top gas flow and gas oven bake cycle not igniting
This most likely is the solution for the bake problem you have:
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Posted on Jul 15, 2010
Dcs oven wos130 wont reach set temperature on bake
Good afternoon Steve!
The answer may depend a bit on what you mean by 'stops heating'.
  • One interpretation could be 'the heating shuts off, and the oven goes back toward room temperature
  • The other would be that it heats up, but it heats to a certain temp and then stays there. it's just not as hot as it's supposed to be.
If it's the former, that sounds like something is overheating and an interlock is engaging because it's interpreted as 'I'm too hot where I shouldn't be, and I should shut off before I cause a fire. I'd leave that to a better trained service tech.
If it's the latter, then it'll depend on how low it is. If it's way low, then there's a couple possibilities:
  1. The heater element is defective, and even at the full current draw the oven can run, it can't get any hotter than that upper temp. This would mean replacing the element.
  2. The temperature sensor in the oven is defective or mis-mounted. There should be a temp sensor inside the oven cavity. if it's disconnected, or, say, bent out of place and much nearer the bake element then it should be, then the heat coming direct off of the element may be fooling it into thinking the oven is hotter than it really is. this could mean replacing the temp sensor, or just re-mounting it to proper position.
If it's just a bit low, then there could just be a calibration problem. If you look at the manual here
DCS WOS 127 Use And Care Manual Child Safety User Option you can see how to adjust the calibration up or down in temperature to, hopefully, match the oven thermometer you're trying to use as a check.
Hope this helps!
Good Luck
D
Nov 18, 2015 | DCS Wot-130 30" Wide Single Electric Wall...
Where is the thermostat that keeps the bake element from working
Usually it will be on the back of the oven, behind panel, or on top. very rear on the bottom.
Jun 19, 2015 | Thermador Cooktops
Replacing hidden element frigadaire oven fpes3085kf
There are normally two options for this. There's either an access panel at the bottom of the oven, or a panel underneath the oven. It's best to have a certified technician do it, to be sure that it's accessed without hurting the range.
May 21, 2014 | Frigidaire Fpes3085kf Slide In Electric...
My frigidaire fef368gch was working fine and then the oven just stopped baking. It will broil but not bake. What causes this and how do I fix it?
Good Morning Shari,
I see that you are having trouble with your Frigidaire range, model# FEF368GCH, and the bake element not working while the broil element is. I suggest giving your appliance a hard reset, by shutting the power off at your home's circuit breaker, for 2-3 minutes. When power is restored, you will have to reset the clock by entering in the time and pressing start. Start a bake cycle, and if you notice that the bake element is still not working, I suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
WP
Apr 23, 2014 | Frigidaire FEF368GC
How do i turn the outer ring on for a dacor stove top
Pushing the button for the element will turn on the inner element at level 5. Before adjusting the level (so while the level indicator is still blinking) press the little circle on the right side of the controls for that element. The circle should light up. Now press the UP control for that element, and the level indicator should stop blinking. Now the outer and inner elements are both heating up. Adjust temp level to desired setting.
Jan 30, 2013 | Dacor Millennia ETT304 Electric Cooktop
Top burners work,broiler works,oven does not
check and make sure the bake element has continuity.If there is not continuity with your ohm meter then replace the bake element.
If it tests good the replace the main Electronic control board or the oven switch which ever the unit is equipped with
Feb 23, 2010 | Cooktops
Bottom element is not heating
bottom element need to be replaced,unplug unit,and open the oven and unscrew the screws that hold it inplace,pull it out slowly and detach the two wires and replace with a new one install in reverce order
Feb 16, 2010 | Cooktops
Frigidaire ES340 Range One element from Dual element doesn't work
The elements DO BURN OUT. Replace it.
Often you can see evidence of a hot spot on the element where the final failure occured, but not always.
Oct 27, 2009 | Cooktops
Bake and broil do not work
assuming that the worst case senario has taken place
first thing i would check is ensure i have proper voltage at the outlet, 120 from each side to ground
220 across L1-L2
the elements are the only thing on the range that uses 220v
if you know how to use a mutimeter
you can test both the elements
disconnect the range at teh breaker
take out the screws at the back wall that hold the elements in
pull out about an inch becareful they dont leave much slack on the wires
disconnect on element terminal and apply your leads your looking for continuity, your meter should beep
if not replace the element
if yes, let the element hang ensureing niether terminal touches anything, reconnect the other terminal
now turn the stove on bake if your doing the lower
turn you meter to ac voltage
you should read 220v
anything less than that, your problem is before that
Aug 02, 2009 | Maytag 30 in. Admiral LGC1330 Gas Cooktop
Sve47100 oven doesn't heat
Test the swtich w/ multi tester /connect tester as a jumper to the switch dettach one line on and off switch /if does not reponse / replace the switch.
Jan 03, 2008 | Jenn-Air JED8430 Electric Cooktop
GE JB640SRSS 30" Free Standing Electric Ranin Stainless Steel JB640 Logo
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
