Question about Mi T M Mitm 3500 Psi Hotcold Portable Gas Pressure Washer
Has no volume of water delay to build pressure
  • Official Brand Answer
  • 4 Answers
Pump issues, if your unit is under 2 years old you should consult MiTM directly.
Posted on Nov 19, 2013
My electric GPW 1600 doesn't stop running when I let off the trigger?
Mostly they don't.
In order to ensure there is no delay in building up pressure for the next spray requirement and to lighten and cheapen the design, the motor is kept running to keep maximum pressure in the line and surplus pressure is recirculated through the pump after being ejected through the unloader or regulator valve.
Jul 16, 2016 | Electric Garden
Tip
Well Pump Problems The Well Pressure Switch
If you have a water well pump then you also have a well pump pressure switch that controls the well pump. This little device can be very confusing. It also is known by many names. These may include pressure switch, well pressure switch, well pump pressure switch, water well pressure switch, well tank pressure switch, and many other variations. All of them refer to the same part that controls the on and off function of the water well pump whether it is a submersible well pump, a deep well jet pump, or a shallow well jet pump.
Some the problems that are most common with the well pump pressure switch.
  1. The contacts burn out and fail to conduct the current through them to the well pump. If you see the contacts are very black or even not there then you definitely have to replace the pressure switch.
  2. The contacts weld together and keep the pump on continuously. Sometimes after getting worn and dirty the contacts on the well pressure switch will just stick right together and not release when the pressure builds and then the pump will not shut off. Even if you can release them with a screw driver, after turning the power off of coarse, they will just do it again, replace the pump switch.
  3. Dirt will sometimes plug up the little pipe nipple that goes down from the bottom of the well tank pressure switch and delay the action of the well pump. This can happen even on shallow or deep well pump that have the pressure switch mounted right on them or sense pressure through a small plastic tube. Take everything apart and clean out so that the water pressure to the pressure switch is accurate.
This should give you a basic guide to the common problems you may experience with your water well pressure switch.
Also note that some well pressure switches have a small lever on the side that will need to be held up for a minute or so to start the well pump. This is a low water cut off protection device that will keep the well pump off if it runs out of water in the well or if it loses prime for some reason. Hold the lever up part way for a bit till pressure starts to build in the well pump pressure tank and then it can be released.
http://www.fixya.com/support/r3695577-jet_pump_jet_water_pump
http://www.fixya.com/support/r3691134-pressure_switch_adjustment_water
http://www.fixya.com/support/r3690698-pump_problems_water_tank
http://www.fixya.com/support/r3689163-water_problems_pump_problems
on Dec 22, 2009 | Plumbing
B&E pressure washer w/ comet 3540 pump
Things to check:
1) is water coming out of the bottom of the pump or is the oil in the crankcase high level and milky yellow. If so your seals are bad.
2) Your check valves might not be seating properly. A couple of fouled check vavles will cause either no pressure or pulsing pressure. A good inlet water strainer keeps foreign matter out of valves. But valves do wear out and get build up that keeps them from working right.
3) Your unloader valve might be worn or fouled. Bad unloader would usually show as low pressure ( but more than hose pressure) or low volume out the trigger nozzle.
Valves are your most likely problem.
Feb 17, 2014 | Comet Pressure Washer Hw3540s Triplex Pump...
My 1999 crown vic is still not building fuel pressure. I've changed the fuel pump and fuel pump relay still not building enough pressure. What else can i try
check or replace fuel pressure regulator. symtoms are. lack of fuel pressure, excessive fuel pressure, black smoke and engine running rich, instant drop of fuel pressure, when turned off delay building back up sufficient fuel pressure. also be sure fuel filter is not plugged. check the filter first !!
Oct 24, 2011 | 1999 Ford Crown Victoria
Have an Onga JJ400 jet water pump several years old, pump is working but delivering poor water flow
Is the pump building pressure and shutting off? If the pump keeps running but not building pressure than there is most likely a problem with the well (low volume). Also check for a water logged bladder tank.
RJ
Jun 29, 2011 | Plumbing
Washer ran all over the floor after filling up and didnt stop filling
Well, there are two main possibilities: Inlet valves and pressure sensor system. to test the inlet valves, turn off the machine, do they stop? Dirt can keep them open.
If power off stops the water, I suspect the pressure system. There is a component outside at the bottom of the drum that measures the water volume, using pressure. This collector component sometimes gets clogged with detergent. If it is open, test the transducer at the other end of the plastic hose. The system is designed to stop the power to the inlet valves when the pressure builds.
Jun 11, 2011 | Maytag MAV8557 Top Load Washer
I have a pressure washer that runs but no pressure, I was using it at the time and all of a sudden no more pressure.
when running your pressure washer, if your running it at home make sure other appliances are not running also like a dishwasher or washing machine. when their pulling water it decreases the volume of water going to your pressure washer. if this is not the case. check the inlet from the water hose to the pressure washer, make sure the filter is clean. also the tips on the wand, make sure there is no hardwater build up. good luck!
Nov 22, 2010 | Karcher 2500 PSI Pressure Washer
1983 fleetwood southwing fuel system schematic for diagnosing / repairing no fuel getting from tank to engine intremittently - plenty of fuel in the tank itself...
Lots of possibilities.
Could have corrosion build up and rust clogging fuel tank pick up. Usually reverse air pressure helps, but would help to remove tank sending unit to see if you can **** out any water or gunk.
Could have vacuum building up in tank. Make sure charcoal canister purge valve is working right, and no hiss when taking off gas cap.
Could be fuel pump. Check pressure and volume, leakage, etc.
Could be filter. If carb, remember there is a small filter in the carb as well.
If fuel injected, may have bad pressure regulator or safety valve in line.
The pressure test results will help.
Mar 02, 2010 | 1983 Chevrolet Chevy
FF-1800 HAS LOW HOT WATER PRESSURE AND DELAYED TIME TO GET HOT
Sometimes there is a lot of sediment released into the pipes (particularly hot water) when water lines are shut down and restarted as part of a remodel process.
Particularly with a pressure balanced faucet this can create all types of symptoms including those you describe...
Before you go to any expensive lengths, check any intake screens or strainers, both on the faucet and in the other components of the system. A lot of the time this will solve the problem...
Nov 24, 2008 | Plumbing
Mi T M Mitm 3500 Psi Hotcold Portable Gas Pressure Washer Logo
Top Mi T M Garden Experts
JOHN LAPIER
Are you a Mi T M Garden Expert? Answer questions, earn points and help others
