Question about Polaroid FLM-323B Television
Tc18813f tv comes on and displays logo for about one minute then picture goes sound ok red light comes on power supply
SOURCE: polaroid flm373b
Try several different inputs.
Posted on Sep 09, 2008
  • 718 Answers
SOURCE: OK,I've replaced the Power Control Board and the
Polaroid TLA-04011C
You can get a service manual from;
http://www.polaroidsupport.com/polaroid/docs/TLA-04011C_TLXB-4011_TLXB-4241_ServiceManual_20070613.pdf
This will give more diagnostic flowcharts etc. Could be useful in the future also.
Posted on May 07, 2009
  • 187 Answers
SOURCE: will not come on
It will be the mainboard but not 100% sure because I need a more detailed description of the sympton.
But by the look of your description if it is not fixed with a mainboard it will be the powerboard for sure.
Posted on May 27, 2009
  • 19 Answers
SOURCE: Polaroid 19" TV TLA-01911C has no picture. Powers up, see logo
To add to this solution above - I had the capacitor replacement and there was still an issue. Turns out the solder connection to the lamps themselves was very very poor causing an electrical arc (the scratching noises people are hearing) - then the inverter shuts the lamps down as it should. Fix lights!
Posted on Dec 10, 2009
TV picture goes out after 10 minutes of viewing with popping sound
It can be a couple things. Something bad on the power board. Or the vertical output circuit. How long ago did you purchase the television. Your best course of action is to have it serviced.
If you need any information or other assistance let me know.
Thanks,
Lee
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
No Picture, but sound for a minute, then shuts off
I think your Display card not proper work so please contact LG Technician.
Thanks.
Feb 17, 2014 | LG RU-44SZ61D 44" TV
FLX3211b when plugged in the red power light comes. Then when the TV is turned the red light turns blue and stays on. The Element logo appears for a couple seconds then the screen goes black. There is a...
the transformer for the backlight is usually what fails on the elements especially if the logo comes up briefly then the screen goes out. I would check the transformers.
Apr 04, 2012 | Element Electronics FLX-3211B 32 in. LCD...
Red light is on in front and have no picture
Good day..
That problem is usually cause of bad capacitors on the power supply section..
As you stated your TV works fine and after a minute the red light comes on...
That symptoms is cause of bad capacitors..Normally bad capacitors can check visually if the capacitors look like leak/bulged on the top that is the indication of bad one but not all bad capacitors are bulged some are not so in that case you have to used a special meter called capacitance meter..
This is the sample picture of bulged capacitors:
Dec 06, 2011 | Televison & Video
Turned tv on 2night had picture and sound for approx 3 minutes then tv turned itself off had 2 flashing red lights turned tv back on no picture or sound then turned itself off again
B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Mar 16, 2011 | Sony Televison & Video
No Picture & No sound. Red LED, Green LED, Red LED.
If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
Jan 14, 2009 | Akai LCT2660 26 in. HD-Ready LCD...
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
No picture or sound. Red light comes on then goes off.
I had the same problem with my LTP227W and it is also about 4 years old. Took it in to be fixed and they found it was two capacitors in the power supply. Parts for this TV are not available anymore but they were able to repair the power supply. The TV works fine now. Hopefully I can get another four years out of this. Repair cost was $150.
Oct 24, 2007 | Samsung LT-P266W 26 in. HD-Ready LCD...
Polaroid FLM-323B Television Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
