Question about Microwave Ovens
Kenmore 721.66222 no power
How do you check the fuse?
    Champion:
  • 208 Answers
Find it and ohm it with multimeter
Posted on Nov 18, 2013
My Kenmore elite microwave model 401.88523011 has lost power. The electrical outlet still has power to it. Is there an internal fuse or circuit breaker that may be causing the power outage?
Your microwave has an internal fuse. Usually 10 to 20 amp. You can pick some up at home depot or radio shack. Make sure you get the same amps and volts as the original fuse. Will be printed on your microwave some where usually. And if its one that is part of a double oven deal make sure that you check you're circuit breakers for the kitchen. Good luck.
Dec 16, 2014 | Kenmore Microwave Ovens
How to locate the kenmore microwave 721.85033111 fuse?
You must open it up. There is no reset. If fuse is blown then check the door switches.
Aug 30, 2014 | Kenmore Microwave Ovens
Kenmore hood microwave door was slammed shut, now it won't power on. Fuse is good, door switches don't look damaged or dislodged. I haven't ohm'd the switches. They should not be the problem as the...
While the door was slammed it is possible that the connection to the main board was disconnected. so since there is no display I recommend that you check the power to the processor board, check if the LT circuit is working , if the board fuse has failed or if the power supply here is faulty.
Only if the display comes back will it confirm the working o the processor.
Apr 01, 2011 | Kenmore Microwave Ovens
I have a kenmore microwave model 721.80033700, it was working ok, but it stop sudently. Does it have a fuse that i can check.
Most have a fuse inside on the small panel that the main power cord first goes into. First you would have to remove the outside panel on some it's like 4-5 small screws then look where the power cord enters and is soldered onto a board the fuse should be close too this. hope this helps.
Sep 25, 2010 | Kenmore Microwave Ovens
Went to use and there was no power in unit. was
my kenmore 565 has gone out...no power. We have checked the power supply works. Can we check the internal fuse?
Nov 17, 2009 | Microwave Ovens
No Power
HI, there is a inline fuse located inside the microwave ion the power supply board. check for continuity. replace the fuse if necessary. if the fuse is OK, replace the power supply board.
Jun 01, 2009 | Kenmore 62702 Microwave Oven
Kenmore microwave model 665.61629100
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
May 29, 2009 | Kenmore 63792 Microwave Oven
Kenmore Microhood not working
I think it may be an internal fuse or a fusible link. You also have a series of contacts and switches inside that are set in place by the mfr. for safety. You could get it repaired for 50-75 dollars or a new one for 125-150 dollars. If you have checked the internal fuse, then just get a new one if the other one is older than 3-4 years.
Jan 11, 2009 | Microwave Ovens
Power outage now microwave won't work
Most likely blew internal fuse. Pull the top/side cover off and check the line fuse. It should be behind the control panel in that area.
Nov 08, 2008 | Kenmore 62622 Microwave Oven
Kenmore over the oven microwave
check high voltage section diodes and capacitor or high voltage circuit,
Nov 03, 2007 | Kenmore 62702 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
