Question about Weedeater 2 Speed Gas Blower FL1500LE ()
Run half choke carb weed - Weedeater 2 Speed Gas Blower FL1500LE ()
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,095 Answers
Dirty carburetor. clean it
Posted on Dec 29, 2013
My Weed Eater FL1500LE gas leaf blower will not run beyond the full choke setting. If I move the lever to half choke the engine will stop. Or if I move the throttle from full throttle to a lower speed...
This is a tell tale sign of a lean fuel mixture. By choking the unit you are manually creating a richer fuel mixture. I would purchase a compression tester from a local parts store and check compression. If that's ok, I'm willing to bet the problem is still carb related. Two stroke carbs are tricky to clean because of high/low ports that are one way and sometimes impossible to clean. Did you remove high and low needles when cleaning carb? Another trick is to mix seafoam with your gas, then mix two cycle oil to proper ratio. Use 2 ounces seafoam to one gallon of gas, then mix two cycle oil to proper mix. Hope this helps! Good luck and happy wrenching!
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Sep 22, 2013 | Weed Eater Fl1500 Le Leaf Blowers
My Weed Eater FL1500LE will only run on full choke and will stop when changed to half choke or throttle is moved from fast idle to any lower speed. I have replaced both fuel lines, thoroughly cleaned the...
It is obviosly fuel starvation, have you actually replaced the fuel filter on the end of the hose in the tank? try richening the fuel mixture by unscrewing the H and L screw on the carb 1/4 turn on each, you may need a special tool to grip and turn these.
Sep 22, 2013 | Weedeater 2 Speed Gas Blower FL1500LE ()
Craftsman weed wacker will start and run
Are you sure you have the right fuel mixture? Many of these require 2 Cycle oil to be added to the gas. If fuel is right, you may have a vacuum leak at the carb (or crack in base where it mounts to the engine). My weedwacker needed to be run on half choke for about 10 min before it got hot enough to run with choke off.
Apr 29, 2012 | Craftsman Weed Wacker Lawn Edgers
Only runs good on half choke - will not take gas on open choke.
sounds like a carb problem for sure the diaphragm in the carb has hole in it or the jets are clogged forcing it pull fuel at half choke and not fully open also make sure your gas lines are clear and free of trash but i would put a kit in the carb for sure.hope this helps.
Aug 26, 2011 | Poulan Weed Eater No Pp446t 952802025 31cc...
Blower only runs with full choke. When I switch to half choke, it dies and won't start.
it may simply need the high speed jet opening up a bit (2 screws near eachother on the carb and the high speed is furthest from the engine)
failing that it needs a carb kit.... this is a serviceable item changed regularly.
Mar 14, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
I have a ryobi weed eater clean carb change filter and spark plug wont run off choke
I have the same problem. It will run if I put it halfway between Half Choke and Full Choke. But, just dies if I put it on Run or Half Choke. Don't ever loan your WE to anyone, They might just try to run it on straight gas--That is what happened on another week eater that I had.
Mar 27, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
After rebuild only runs on half choke.Adjusting screw doesn't help
The rebuild you did is correct, but did you clean the small ports in the carb.? I use a Den Tek Brush (used for cleaning teeth). They work great for this job. You may also want to check the small screen in the carb. The smallest of particles can cause this problem.
Jim
May 25, 2009 | Poulan Garden
Weedeater 2 Speed Gas Blower FL1500LE () Logo
107 people viewed this question
Top Weedeater Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
Darrell
Are you a Weedeater Garden Expert? Answer questions, earn points and help others
