Question about Eaton Fuller Roadranger Transmission Ta-d67-11x Fr-9210b 10-spd
I Need an air diagram eaton roadranger 18 speed transmission
I Need the diagram for the airlines that go from the shift knob to the transmission
My eaton fuller transmission wont shift past 5th when it tries to get into 6th gear it just makes a grinding noise
how many gears in this transmission remembering that Eaton make from 5 speeds up to 21 speeds in their range of transmissions
so if you have a 9 speed box and attempt to select 6 gear without using the range change you will be selecting probably first again
Don't assume that everybody knows what box you have so include all make , model year , equipment application in your posts as they are not linked
Sep 08, 2017 | Cars & Trucks
Shifter for low and high range won't switch from high to low 10 speed eaton fuller manual transmission
the small air valve at the box will be suspect as they tend to seize up and not move
check that the plastic air lines to the switch or box are still intact
check that the gear knob is operational
some knobs are where you move the lever sideways to change the ratio and others have a pull up knob under the lever handle
the flick switch sometimes develops problems in the rubber"O" rings
May 04, 2016 | Cars & Trucks
Transmission not shifting into high gear since abs/4x4 code
answer to any 4l60e trouble ' GMT400 - The Ultimate 88-98 GM Truck ...
www.gmt400.com > Street and Track > Transmissions
Mar 5, 2011 - Before guessing at transmission problems, check the fluid level (car warmed up, ... that do not show up as PCM codes (like shift A&B solenoid failures, for example). ... 1-2 shift is delayed and harsh, may not shift into OD: Check TPS for ...goes into 3rd gear: Reaction planetary is worn out due to high miles or ...
GMC Jimmy Transmission Problems - Edmunds
forums.edmunds.com > GMC > GMC Jimmy
Dec 20, 2013 - 1998 Jimmy After truck warms up shifts hard between 1st and 2nd gears. any ideas ... The ABS light stays on,the engine light stay on, the speedo doesn't work, .... I have a 1990 S15 4x4 Jimmy with a manual 5 speed transmission that went out. .... While driving it will only shift into 2nd gear and 3rd no overdrive. and usually ... Ford F-Series Transmission Problems - Edmunds
Dec 18, 2013
Buick Rendezvous Transmission and AWD Problems - Edmunds
Dec 18, 2013
Dodge Dakota Transmission Problems - Car Forums at Edmunds.com
Dec 18, 2013
Ford Transmission Problems - Edmunds
May 14, 1998
More results from forums.edmunds.com
Automatic Transmission May Not Shift Correctly at High ...
repairpal.com > Problems > Toyota > 4Runner
Feb 03, 2016 | Cars & Trucks
Transmission wont shift from high side too low side/ fuller 9speed
Have you Checked your Vacuum Line ? This is the most common issue with the High / Low Problems,....
Apr 08, 2013 | Ford "c" Cabover Semi Tractor-disalvo...
How to change 18 speed eaton fuller gear knob
You Just Take It Off And Put It On
Feb 04, 2012 | Cars & Trucks
Why the high / low shifter on a eaton/fuller won't shift right?
Check the Air pressure regulator, it should be putting out 62.5 psi
Oct 20, 2009 | Ford "c" Cabover Semi Tractor-disalvo...
Volvo roadranger transmission
check air to range piston if it grinds going into low range will need a synchronizer
Oct 23, 2008 | 1991 Chevrolet Camaro
Eaton Fuller Roadranger Transmission Ta-d67-11x Fr-9210b 10-spd Logo
134 people viewed this question
Top Eaton Plumbing Experts
Donni Steen
Tom Chichester
Are you an Eaton Plumbing Expert? Answer questions, earn points and help others
