Question about Pioneer Premier DEH-P480MP CD Player
Hook up cellphone/mp3 to car stereo
I have a nokia 5300... and it's an mp3 player... When i connect it to the built in aux input in the back of the stereo... but nothing happens... I read in another problem that it was suggested that the initial settings needed to be change for the aux to be read by the stereo.. if this is a correct solution to this problem... how do i change the initial settings?
To change your intial settings turn off the stereo, then hold down source butten until clock starts flashing then press the function button which will allow you to turn on aux settings.
Posted on Dec 20, 2007
THANK YOU! Your instructions worked perfect!
Posted on May 26, 2008
Thanks this info missmis44. it helped a lot.
Posted on May 10, 2008
How can I hook my Sandisk Sansa Clip+ up to my stereo system if the stereo doesn't have a USB port?
Connect a audio from the headphone socket on the player and plug it into the AUX input on the stereo system. Set the stereo to AUX, turn on the player and adjust the volume level on the stereo.
Nov 28, 2012 | SanDisk Sansa Clip MP3 Player
Tip
How to connect your iPod to a Car Stereo
Many car stereos have more new connections that MP3 playerslike the iPod can be connected and played through the stereo. For new carradio, you only need to connect the device and the MP3 player. If you have anold stereo, connect your iPod or connect a 3.5 mm stereo cable or FMtransmitter. Connect iPod directly to the stereo with a stereo cable willresult in better sound quality on the FM transmitter, which can be interruptedor static signal.
AUX
1. Find an AUX port. The AUX is a hole, only small to belocated on your car radio face. (The size is perfect for connecting headphonesor an auxiliary cable.)
2. Connect the 3.5 mm stereo cable into the hole in front ofyour car.
3. Connect the other end into the hole stereo AUX jack /headphone jack on top of your iPod.
4. Connect your iPod.
5. Activate the AUX input. This will be different for eachcar. You may need to field through your input options (e.g., FM, AM, CD, etc.)to access the AUX. Or you may need for your stereo pressing the Menu button.Then, the options for auxiliary input field to the AUX input as possible.
6. Find a song on your iPod and press the Play button whenthe auxiliary input is activated. If you do not hear anything, make sure thevolume on the iPod device and radio. If the iPod is playing your song, you'llsee the song progresses on the iPod screen.
FM Transmitter
1. Find an FM transmitter that is compatible with the iPod.So let your FM transmitter near your car radio.
2. Connect the iPod to the FM transmitter.
3. Tune the radio to your car radio has a frequency thatonly static, then the vote of the same frequency channel using the buttons +and -.
4. Connect your iPod. Then a number and press"Play." Make sure to turn all your volume on your iPod. You should beable to use his music. If not, find a new frequency until you find one thatworks with the iPod and the transmitter.
on Aug 09, 2011 | Apple iPod touch
How to connect mp3 player to stereo
connect the audio lead into the head phone socket on the MP3 player and the other end of this audio lead into the Line in/Aux input on your stereo.
Switch the stereo to Line in/Aux and then turn on the MP3 plater.
Apr 09, 2012 | Computers & Internet
MP3 players shuts off randomly but only when hooked up to aux. input on car stereo.
Its own battery cell is weak or dead that it cannot stand on its own but works well when hooked with a car stereo. So you need to replace it.
Oct 16, 2009 | Samsung YP-K3 MP3 Player
I cant figure out how to get an MP3 player to play through my CD player....it has 3 different audio rca jacks in the back...i try all three none worked....is there an AUX setting that need to put my cd...
what kind of cd player do you have? you must make sure that your unit has auxillary inputs. some decks dont have them. if it is set up with aux input rca's, then you just connect those to the mp3 player, then you should be able to play it in the aux mode on the deck. if you cant find it by hitting the source button, then you may not have it. I know on my sony stereo, I actually had to turn the deck off with the ignition switch on. then I press the menu button, and there I can toggle the aux mode on or off. if that doesnt work either, then you either dont have aux inputs, or the inputs are bad on the stereo, meaning its not gonna work at all.
Jul 28, 2009 | Car Audio & Video
Auxillery in question
yes you can hook up your mp3 to an aux input on a stereo not sure what you mean by converter typically it is done through a 3.5mm - 3.5mm standard audio cable. and in order to do this your reciever must have an aux input of course and if so then you can toggle the mode of input by pressing the Mode or button that switches from radio to cd etc or consult with your users manual to find out how to switch and if aux input method is supported
Feb 15, 2009 | JBL MR-4 AM / FM / CD 180 Watts Marine...
Jensen cd 2610 aux input has little volume
first of all the rca jacks in the back of your radio are for plugging in an amp, not your mp3 player. there should be an auxiliary jack(looks like a headphones jack) in the front of the head unit. if there is no auxiliary jack in the front then you will have to go buy a new head unit with an auxiliary jack.
Jan 27, 2009 | Jensen CD2610 CD Player
Can I plug my MP3 player into the aux. socket on my car radio, with the appropriate cable and play the stored music?
You should be able to do that as long as you have the right cable.
Most of the mp3 players have a "mini-stereo" jack (3.5mm) and some car stereos have the same type of jack for "aux" input, and others car stereos have RCA jacks for the "aux" input.
Even if the jacks are not the same type, you can use an adapter cable that converts the mini-stereo jack to an RCA jack. You can find them at many places like Best Buy, Circuit City or Radio Shack.
Depending on the type of car stereo you have, you would normally press the source button to change between the tuner, cd player, aux or whatever you may have connected to the stereo. You may even have a seperate button to press for the "aux" input.
I hope this was helpful to you, if you need more information just ask, and please give more info on the type of mp3 player and the make and model number of the car stereo.
Jun 21, 2008 | Car Audio & Video
Stereo in my Fiat punto 2007 model has an AUX function. Can i connect cable to AUX Input to run MP3 player via ear peice output?
Hello, when I insert a CD (normally purchased) into my Fiat Punto Grande stereo it displays "CD ERROR", ejects the CD then displays "AUX" (the tuner still works). I would be grateful if anyone has any idea what the problem is, thank you.
Jun 17, 2008 | Blaupunkt Car Audio & Video
Aux wire?
Your query > ..."wire...to hook...mp3 player ...RCA RS2044 stereo..."
You need to connect the headset out of your MP3 player using a special cable to theInterfaces/Ports: AUX-in of the RCA RS2044.
One of the many technical name for the special cable is RCA Male Stereo to male baby phone stereo, the common name is MP3 to RCA and it is similar to the function and look of a Cygnett Groove Transit - MP3 Phone to R...
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 29, 2007 | RCA RS2044 Shelf System
Pioneer Premier DEH-P480MP CD Player Logo
491 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
