Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
F3 beeping in self cleaning mode - Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
  • Official Brand Answer
  • 4,342 Answers
Hello Jane, thank you for allowing me to assist you!
If you are getting an error code F3, it is commonly referred to a faulty sensor probe or a wiring harness between the sensor probe and EOC (electronic oven control). You may try and reset your range by disconnecting the power or by flipping the circuit breaker off and back on after 10 minutes. This often clears most false error code. If the error code does not clear, most likely the EOC on the range will need replacing. I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Posted on Nov 18, 2013
My GE self cleaning oven won't turn on and I'm getting a F3 message
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
Mar 14, 2011 | GE Ovens
We are using self clean feature. continuous beep about 20 minutes into cleaning screen shows F# locked door and beeps nonstop. what can we do to stop beeping but still proced with self cleaning?
F3 is a bad oven temp sensor. The sensor fail F3 code will appear if during self clean that it senses temps above 915F, or there is an open / short in the temp sensor. The only thing you can do is replace the sensor. Just getting the oven door open can be a real pain as you have unlatch the oven door lock to get to the screws that are in the top lip above the oven door so that you can change the sensor. Depending on model you may have to reach through a burner to manually unlatch the oven door lock or remove the side panel of the oven to manually unlatch the door lock. On most units It will not continue to self clean with an F3 code detected. Once an F3 code is detected the ERC shuts off power to the bake and broil elements so that it does not catch fire from a run away temperature condition.
Thanks for choosing FixYa,
Kelly
Nov 25, 2010 | Ovens
Amana Self-cleaning Oven flashes F2 and F3 and beeps. It doesn't get real hot. Although it does heat up not the appropriate temperature.
Hi, F2 error code on the Amana Oven means "Oven too hot" You have to replace Oven temperature sensor to fix it.
F3 error code means "Open or shorted oven temperature sensor". Yo also have to replace Oven temperature sensor to fix it.
Summarily, both code has to do with the temperature sensor which you need to replace...
Oct 23, 2010 | Amana Ovens
Have a Kenmore electric drop-in range less than 2 years old. Turned on self-clean cycle but after an hour or so started beeping and F3 was displayed. Have lost manual.. What does f3 mean?
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Aug 04, 2010 | Kenmore 42161 / 42169 Electric Single Oven
I cleaned the oven and now I get the error F3 - I don't have a manual and I don't know what that means.
i recomend you not use the self clean function 90 percent of aour calls are after a self clean --temp sensor or stuck key pad generaly the latter but before replacing any thing turn off breaker for about twenty minuts and thaen reset do not use if oven starts to beep within 24 houres you have a stuck key pad you must replace
Aug 09, 2009 | Ovens
Self clean results in f9 and beeping
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
utut
Apr 07, 2009 | Frigidaire FEB27S5A Electric Single Oven
F3 Code and door remains locked
Pull range from the wall. Unplug from wall. Open the back side of the range exposing the wiring. You will notice a small motor that is connected to your locking device. Turn the shaft on the motor counter-clockwise and the door will be opened. Examine the shaft and you will see a small cam that pushes up against a small switch. Turn the shaft so the switch is pushed in but ready to be released. Plug in your range back in and do not touch any exposed lines (220 V). Once the range begins to beep, turn the shaft until the switch is released. That solved my F signal. Motor is getting old and lazy I guess.
Mar 29, 2009 | Ovens
I have a majic chef oven, when i turn it on it beeps and flashes
Self clean on some older models can cause some issues. F-3 is a sensor error. This could have been damaged by high heat or in some cases if the sensor is ok, the control doesn't know it's there.
Mar 14, 2009 | Magic Chef 9815 Electric Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
62 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
