Question about Hoover Washing Machines
Machines 510 Its an old machine (a 510, Model No. A6274). I've looked after it, replacing parts when needed. Has always run well. I do a yearly check/service - replacing belts and hoses etc as needed. Just lately the machine has been slow on spin. Normally it reaches full speed quickly and spins out okay. Now it seems to spin only at half speed. I've checked the belt for looseness and oil (the belt is okay). First I thought it was too much washing load, so just to check I ran the spin without water or washing and still slow. Now I wonder if it is the motor? I replaced it many years ago, but now wonder if there is a problem (motor) or maybe an issue with the clutch system (which as far as I can tell is working okay). Any help would be much appreciated. regards, Phil
    Champion:
  • 242 Answers
These machines can get seized bearings, which can stop the bowl from turning at full speed. probably the motor after this.the clutch should affect full spin speed only if it's worn. this fault can be a timer issue also.
Posted on Nov 18, 2013
SOURCE: Wash but no spin
1st of all is there a spin cancel buuton on this machine and has it been activated, or is there a spin speed selector knob and has it been turned down...is inner drum easily turned by hand.if it is ok then belt tension could be suspect (tighten)im sure there is an out of load balance detection circuit on the main circuit board....also is it draining ok because it wont spin until it cant dectect low or no water prior to final spin.....also if it has a programme dial the select a spin programme on another section of selector dial.........hope this is of some help...
Posted on May 08, 2007
  • 38 Answers
SOURCE: Hoover Aristocrat Front Load Washing Machine
i think you will find the carbon brushes r worn out they r mounted on the side of the motor held on by 2 5.5mm nuts or 2 screws 1 brush on each side of the motor switch off at the mains b4 you start work good luck
Posted on Aug 19, 2007
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
SOURCE: Hoover 550 MA Top Loading Washing Machine
I have 550 Hoover about 6 years old,just out of warranty period,
is currently noticed the problem of stopping during prewash rinse, start again it startsup but stopped immediately.And keep repeating it. If i skip to spin manually then it almost completes the cycle. THis problem starts few months back also then vanished by itself and now it starts again.can some guru tell me if its because of belt or drive belt etc.
Posted on Apr 28, 2008
  • 1214 Answers
SOURCE: I have a 12 year old whirlpool washing machine model lxr7144eq0
To determine if the transmission caused the belt to wear, then unplug the washer, and looking up inside toward the transmission, note the large diameter pulley that the belt goes around. See if you can turn it by hand. It should turn freely in both directions.
This isn't a 100% guarantee that the transmission is good, but will give you an indication. Make sure the washer is at the end of it's cycle when trying this.
If it turns, replace the belt and see what happens. If it doesn't, make sure none of the solenoids are engaging the linkage, otherwise, you'll be trying to turn the drum or agitator.
Posted on Feb 04, 2009
2011 washing machine broke November 20th and I'm still waiting for a part. Have Master Pro. Agreement need four qualifying services in a twelve month period to qualify for a replacement?
Suggest do some asking and looking around to find another similar model to use for parts.
Most cities have appliance part stores where you can buy the part locally.
Since your unit is 7 years old you might want to use your funds towards a new model since the rest of it is 7 years old too and could fail.
Jan 16, 2018 | Washing Machines
Washing machine is making a sound like electric arcing which I have experience before on other machines and think it's the carbon brushes that need replacing. I've done this on other machines but...
I ALWAYS advise replacing the motor! It might be suggested that just the brushes on the motor want changing; experience (of others) suggests that they may only last months rather than many years UNLESS the motor itself is refurbished. Refurbishment includes skimming the commutator on which the brushes run. Without skimming the brushes do not sit cleanly on the com, often causing excessive sparking and excessive wear on BOTH. Alternately a new motor! I changed the motor (and belt whilst I was at it!) on our 19+ year-old Bosch at a cost of GBP250 ;-0(
Spares Suppliers
You will need to type into your search engine/web browser '(make model number) washer spares' and you should be presented with a number of sources from which you can order. Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Aug 27, 2011 | Washing Machines
I need a new sewing foot as the lower part of mine has fallen off do you know where I can get one
Most sewing machines can use a universal foot, meaning you can buy the foot at nearly anyplace that sells sewing supplies. I'd suggest removing the foot from your machine and taking it with you to your local Joann's/Hancock Fabrics or small shop (check your yellow pages or Yahoo!Local) and ask them to give you a hand. They can look at the foot you have and help you see if a universal foot will fit.
I've never heard of a machine that doesn't use a universal foot-in my 30+ years of sewing, I'm still using the universal foots from my grandmother's 50+ year old tailoring machine! And I know have a computerized embroidery machine that's only 3 years old! But do be on the sure side and go into a store if you can.
May 19, 2011 | Sewing Machines
My Fisher and Paykel Smart Drive 501 toploading machine won't finish its cycle...it always gets stuck on the spin cycle and starts beeping. This happens every time not just occasionally. How can i fix...
need to have a look at the machine, how old is the machine 15 years roughly, Yes this is when the machine plays up, hard to find spare parts. If you are getting rid of the machine let me know. 0412676652 Since I want to learn fixing the machine, I did fix one of this model long time ago
Jul 01, 2010 | Fisher and Paykel Fisher & Paykel Washer
Washing machine getting hung on a cycle
If the machine is 14 years old, it probably is time to replace it.
Jun 06, 2017 | KitchenAid KAWS850L Top Load Washer
Bearings gone
All Indesit washing machines are aimed at the budget end of the market; as such the outer drum assembly is polypropylene instead of steel. This type of construction is common to almost all cheaper brands which are really designed to simply be thrown away when major parts fail.
Bearing replacement is often impossible as the outer drum inevitably cracks when the old bearing is driven out or when the new one is installed. Indesit do not normally even offer the bearing as a spare part, but if you do get the old one out a replacement can usually be supplied by a bearing shop if you take the old one along for comparison. If you then buy a new bearing and then crack the outer drum whilst trying to install it you won't be able to get a refund.
Your only realistic options are as follows:-
1. replace the entire drum assembly;
2. replace the outer drum complete with the bearing;
3. replace the entire machine.
The first option is not usually cost effective, the second option isn't always possible as it's not always available as a spare part (you didn't state which exact model you have).
The third option may be your only practical solution if you cannot put up with the noise or if the faulty bearing is causing other issues. You also need to consider that if your Indesit is used every day, then it will typically last only around three years from new before major parts start to wear out, so you might repair your machine only to find that it soon needs a new pump or has a sensor, switch or circuit board failure. Better quality (but more expensive) brands will typically last in excess of six years.
Avoid any used washing machines unless you get them for free and they just need a cheap fix like a new pump (or even better when they just need that errant sock pulled out of the tube leading to the pump: many perfectly good machines are thrown away with simple fixes like those). A bargain used machine is only a bargain if it lasts at least a year or two, and professionally "refurbished" machines normally only come with a less than reassuring ninety day warranty.
Mar 01, 2010 | Indesit Washing Machines
Poor frothing
You need to check (or replace) the air-intake nozzle which is located inside the coffee outlet. You will sure loose the good froth if that part is not clean or replaced. There should be proper amount of air input to produced the proper froth.
Rihel Calma Philippines
Aug 22, 2009 | Franke Saphira Espresso & Coffee Maker
Knocking sound in the spin cycle off balance.
The motor switch that is mounted on the motor may need replacing. The knocking could mean that the "run" winding is cutting off momentarily, and running on the "start" winding of the motor. I dont know about a 22 year old model, but in most "near modern" machines, the switch has a plastic actuator that is pushed when the motor obtains near-run speed, that plastic may be worn or the actuator part on the motor may be at fault. If you replace the motor, you usually get this switch as part of the deal.
Feb 05, 2009 | Maytag Washing Machines
Washing Machines Logo
52 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
