Question about Price Pfister Plumbing
How to remove cartridge retaining ring on Price Pfister 26 series kitchen faucet
This is a 26 series with separate handle for water control. The existing retaining ring is plastic with outer threads that secure the bonnet. If I use a wrench on the retainer ring the threads will be damaged and the bonnet will not screw back on. Price Pfister sent a new cartridge with a metal retainer ring. Can I use a pipe wrench or large pliers to remove the existing retainer ring and not worry about damaging the threads? It looks like there may be a special tool like a large spline with a hole in the center to correctly remove the plastic retaining ring. The metal replacement ring takes a large crescent wrench to tighten and the bonnet looks like it will screw on over the metal ring. If I don't have to be concerned about damaging the plastic ring then this project is less than 5 minutes. If damaging the plastic ring puts the sink out of order waiting for replacement parts then it will be 3-5 days in the outside dog house.
  • 9 Answers
SOURCE: Repair cartridge in Moen Monticello single handle lavatory faucet
After some additional experimenting, contrary to information I was previously able to gather, I discovered that the white plastic retainer doesn't (in this type of Moen faucet) actually screw off but rather is held in place by a spring clip inserted from the rear of the retainer (toward the wall side of the basing). Simply sticking a small screwdriver in the opening (approx. 45 degrees downward) and tipping the screwdriver toward the front of the faucet, snaps the spring clip out through the opening.
The plastic retainer than lifts off. Note: the flat sides on the retainer suggest that a wrench will be needed but such is not the case.
Posted on Nov 28, 2008
  • 148 Answers
SOURCE: Eljer slantback lavatory faucet
use baking soda to remove the corrosion mix a little in apaper cup and brush on with toth brush
I do not have a clear picture but can you not put two screw drivers under the lip of the chrome and pry up
One other thought is to tap the top adapter with a hammer to see if it will break loose
Posted on Dec 30, 2008
ffrn99
  • 6 Answers
SOURCE: Removal of single hole kithcen faucet.
There is a bracket that slides between the threaded shaft and the bottom of the sink. There is usually a nut which is tightened up against this bracket. When this nut is loosened, the bracket will slide out. Of course, you first have to unfasten the two water supply lines. Once the bracket is removed, the two water lines which are made into the faucet are gently bent and the whole thing is removed from the top of the sink. Hope this helps.
Posted on Mar 09, 2009
SOURCE: Replacing Cartridge Valve in Kitchen Faucet
A little WD-40 was all it took, although it was quite difficult to remove using lock wrench pliars.
Posted on Sep 15, 2009
ultrat
  • 500 Answers
SOURCE: My price pfister single handle shower/bath control
There may be 2 pins if under ring the collar has multiple holes.remove pins & unscrew ring... or it could be just stuck from age..
Posted on Mar 31, 2011
How do I disconnect a price Pfister quick connect?
There is a tool that presses on the collet at the tend of the fitting. It look like an open ended wrench.
https://www.youtube.com/watch?v=dCbXw5bP9I8
Price Pfister Quick Connect Sprayer Hose Removal - YouTube
? 1:50
Feb 1, 2014 - Uploaded by brianmcdrummer
In a few easy steps I'll explain how to remove your sprayer hose from your diverter. ... Pfister Faucets 17,981 ...
trick to removing price pfister quick connect sprayer hose - YouTube
? 0:23
https://www.youtube.com/watch?v=vTJefezIvwg Aug 14, 2012 - Uploaded by Biren Patel
This shows you how to remove the price pfister "quick connect" hose on the end of the kitchen sprayer head ...
Pfister - How To ' Remove a Sprayer Hose Connection
www.pfisterfaucets.com/support/faqs/sprayer ... Order Parts, FAQs. FAQs. Resources. Step by step instructions on how to remove a sprayer hose connection for the Price Pfister 529 Series faucet.
Pfister - How To ' Remove a Diverter Tee Connection for the 26 Series
www.pfisterfaucets.com/support/faqs/diverter ... Information · Order Parts, FAQs. FAQs. Resources. Step by step instructions on how to remove a diverter tee connection for the Price Pfister 26 Series faucet.
Pfister - Removing quick connect HELP ' Terry Love Plumbing ...
terrylove.com > Home > Forums > Plumbing Forum, Professional & DIY Advice Dec 13, 2006 - 6 posts - ‎5 authors
Purchased a replacement sprayer (with hose) for a Pfister Contempra faucet. How the heck do you remove the old hose from the handle assy? How do disconnect price Pfister quick connect Google Search
Jan 08, 2017 | Price Pfister Plumbing
How do you remove the handle to replace valve?
Unscrew top button.
Using a phillips screw driver remove handle retaining screw and work off handle.
If it leaks under the handle you need to unscrew the top cap, use a strap wrench to hold the body and tighten the brass retainer ring with an adjustable wrench. Or remove the ring to replace the cartridge.
Nov 23, 2011 | Price Pfister Marielle Kitchen Faucet with...
I have a two handled price pfister kitchen faucet and replaced the cartridges and now have low water pressure what did i do wrong?
probably the diverter, order from mfg & replace or you can disassemble diverter and replace internal white part and O ring which is what I did and worked great
Oct 04, 2010 | Price Pfister Plumbing
Dripping faucet price pfister kitchen
Very nice kitchen faucet. I like Price Pfister's products. To repair it you will need a phillips screwdriver to remove the handles and crescent wrench to remove the cartridges. If it is dripping then one of the faucet cartridges need to be replaced. Its best to replace both cartridges as inevitably the other one will start to leak after you've replaced the troublesome one. Your local hardware store or plumbing supply store should have a replacement cartridge for this model. Remove one of the cartridges and take it with you to ensure you get the correct part. There is an exploded diagram of your faucet on the Price Pfister site at that shows the part number for the cartridge. Good luck and let me know how it turns out.http://www.pricepfister.com/www/ImageAssets/mirror/model/kitchen/savannah/savf8h6-85/ex-036-01.pdf
Jul 25, 2010 | Price Pfister Savannah Two-Handle Kitchen...
I have a price Pfister Marielle kitchen faucet. The valve body leaks when handle is in off position.
There is an o-ring around the valve body inside the outer shell. This needs replacing -- sometimes you can match these at hardware stores.
Shut water off, remove handle, pull up outer shell, you'll see the o-ring.
More info, let me know.
Charlie
Aug 28, 2009 | Price Pfister Marielle Kitchen Faucet with...
Parts came out of diverter, need help putting them back
The valve went in with the flat brass end showing and the o-ring on top of that. I went to the store and found the same model so I could see the part and how it was assemble.
Jun 13, 2009 | Price Pfister Marielle Kitchen Faucet with...
New Pfister Avalon Install: Spray Hose Works, Faucet doesn't
sounds like your diverter is stuck or improperly installed ,try tapping at diverter location to free up diverter the other thing to try is remove the little device on the end of spout make sure its not clogged with debri
May 04, 2009 | Price Pfister Marielle Kitchen Faucet with...
Handle on faucet shuts off on its own
I had the same problem. The Price Pfister web site recommends removing the handle (unscrew the dome cap, then remove the phillips screw to get the handle off) then tightening the retaining ring (I used channel lock pliers on largest setting. It worked. However the retaining ring is plastic on some models, and they recommend replacing it with a brass one. I haven't taken that step yet, we'll see how it goes (mine is plastic).
Dec 01, 2008 | Price Pfister Marielle Kitchen Faucet with...
Plumbing Logo
242 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
