Question about Abit VA-10 Motherboard
Usb front audio connection
    Brigadier General:
  • Abit Master
  • 3,400 Answers
Crosely won't play usb
If it's a turntable with a usb connector, those connections are usually outputs only. USB on a turntable is used to output the audio to a computer to rip albums to digital audio.
Jun 17, 2013 | Crosley Audio Players & Recorders
Plugigng of wire in board
Hello there,
Below is an image of *********** Board with number indication and wiring explanation. From your manual page 1-6 you can see the image below and 1-7 for the connector, jumpers, slots. as indicated in your problem I will only answer problems related to the wirings.
  • For the Front Panel
1. There are 8 wires from the front panel's casing, excluding USB connectors and front audio cable.
2. Just plug the front panel switch headers to the F_Panel main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note:The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with Intel® Front Panel I/O Connectivity Design Guide.
  • For the USB connectors
1. If your casing has a USB header on the front bezel you can put it on any connector. You can also purchase a USB module cable or an internal card reader and plug the headers to any of those connectors.
Note: Observe Polarity, do this Vcc, -Data, +Data, Gnd ,(NC) ground is always near to NC.
Plug it at your own risk, reference image are already shown.
  • Front Panel Audio connectors
1. Look for FP_Audio header from your casing and plug it to the connector.
*Asus recommend you connect a high definition front panel audio module to this connector to avail of the motherboard's high-definition audio capability.
Hopefully this information helps.
Thank you for using FixYa.
Aug 19, 2011 | ASUS P5KPL-AM SE Motherboard
I have an xw9400 board on a normal case,after connecting usb on board with the front panel,board still cant recognize front USB,i need to change wires in the connector to match the board,same thing with...
The front USB header on the XW9400 board has a ground connected to pin #10. The USB standard #10 pin has nothing connected to it, so HP uses it to sense whether a connector is attached to the header.
Apr 01, 2011 | Computers & Internet
I HAVE A NEW CASE, & NEED TO CONNECT THE FRONT UBB & AUDIO LEADS. CAN YOU HELP, CHEERS
Hi there, first check the image below. You've got USB 3 and 4, and AUDIO section. For the USB, pins 1 and 2 represent front panel USB power on both 3 and 4. As for AUDIO connection, pin 1 is Front Panel Microphone input signal, pin 3 is Microphone Power, pins 5 and 6 are for Right Channel audio signal to Front Panel and pins 9 and 10 are for Left Channel audio signal to Front Panel.
You can find more details in the motherboard's manual, page 23 and 24.
Jan 23, 2011 | EliteGroup P4M800PRO-M478 Motherboard
How to connect front audio and mice cable jack with motherboard
Sorry, it has no front audio system! U have to connect at the rear and have to buy a speaker system w/ long cable wire! Use MOBO's USB outlet for the FRONT usb PLUG in using usb type mice! Taah!
Nov 12, 2010 | Mercury P4VM800M7 Motherboard
How to connect front usb and audio cable on gigabyte mother board
The USB pinout on all motherboards is as follows >>>>>>
As for the audio you can visit Gigabyte's support website for the schematics for the front audio.
Regards.
May 24, 2010 | Gigabyte GA-8I865GME-775 Motherboard
GA-8S650GXM FOR USB FRONT AUDIO PANEL
You will need the motherboards manual to help you with connecting USB_1, USB_2 and F_PANEL audio to you're case. If you do not have you're manual for the GA-8S650GXM you can download it from Gigabyte; http://america.giga-byte.com/FileList/Manual/motherboard_manual_8s650gxm_series_e.pdf
You will also need Adobe reader installed to view the manual.
Gigabyte GA-8S650GXM main web site; http://www.gigabyte.com.tw/Products/Motherboard/Products_Spec.aspx?ProductID=1658
Turn to page 18. Number 17, F_USB1/F_USB2. Use the link provided below to help you connect you're front case USB wires to the motherboard; http://www.directron.com/installusb.html
Turn to page 24, for front audio connections. Keep in mind once you configure you're audio to function from you're cases front audio port you will not be able to use the rear audio port. Caution, most people find bumping any front case USB or audio cords break far too easely. To avoid breaking the front audio port, consider using a Y splitter for the rear audio port as shown in the next link; http://shopping.yahoo.com/p:StarTech.com%20MUY1MFF%20Audio%20Video%20Cable:1991733360;_ylt=Ah94ikZN9zDbTi2.arc45BkbFt0A
Hope you find this helpful.
Mike
Jan 22, 2010 | Gigabyte 8S651MP-RZ (GA-8S651MP-RZ)...
I have pront panel audio and usb port but am not able to connect the pin can you please explain me the pin diagram to connect my front pannel usb and audio
depends on what board you have?
majority have the same pin outs tho,
http://www.vistax64.com/attachments/sound-audio/8065d1227471405-realtek-audio-jack-mixup-capture.jpg
there is link to a page that explains both F_USB (Front usb ports) and F_AUDIO (front audio connections)
Aug 31, 2009 | Computers & Internet
Connect
The MB has 2 USB plugs just forward of the floppy connector, and the audio connector for the front panel should be at the back near the corner below the PCI slots near the CD audio plug.
May 28, 2009 | Asrock 775i945GZ Motherboard
Abit VA-10 Motherboard Logo
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
