Question about Garden
Pull cord in Kawasaki FB460V - Garden
How to remove fb460v engine
the Kawasaki engine removes pretty straight forward (bolts out , cable off, wires unhooked, etc) , the only difficult part is removing a well worn in power take/off clutch from its shaft , this will take some care if you need to reinstall it
but I will say unless its a total loss (cracked) ive rebuilt enough of them while still in the tractor , the only part you cant replace doing it that way is the bottom oil seal and the crank shaft (its stuck into that clutch I was telling you about )
Sep 14, 2015 | John Deere Original 130 160 165 175 180...
Toro 52" walk behind with Fb460v kawasaki has no spark
Sounds like your off on switch may be grounded.
Oct 07, 2014 | Garden
I have a John Deer riding lawn mower SX95 with a fb460v kawasaki engine that only starts with fuel dropped into carburetor I have a good spark , I had changed the oil and filter , I also took the carb...
in the carb did any of the screws have any micro bored holes for gas to go through like in many small engine iv found . clogged with goop. does it have a gas bowl an a screw on bottom take it out if does an look it over close.
Jul 25, 2014 | John Deere Garden
Kawasaki fb460v overcharging battery???
It sounds like the voltage regulator is bad. It may be located on the blower housing which covers the flywheel. Should have a large plastic plug connecting to it. If you don't see anything like this then give me the engine spec number so I can look it up. It would be something like "AS09" and should be located where the engine model and serial numbers are.
Aug 20, 2012 | Garden
I have a kawasaki engine fb460v-cs00 in my John Deere Riding Mower and I am trying to find a diagram for the gas tank, lines and connectors. Where can i find that info?
You can get this information at any John Deere dealership or at your public library. I don't really understand your problem. All fuel tanks have a port on their bottom side where a fuel line is attached that runs directly to your carburator, with possibly a filter in between.I hope this will make things a little easier for you. GOOD LUCK.
Jun 17, 2011 | kawasaki Garden
My mower has a kawasaki fb460v and it just quit while mowing and I can't restart. I've replaced the spark plug and air filter and I've sprayed started fluid in the carb, without a hint of a hit. I used...
There are three reasons for a mower to stop while running.
1. Out of gas.
2. You hit something with the blade and either snapped the pin or bent the shaft.
3. Out of oil, and the engine seized.
I'm assuming it wasn't #1.
#3 means buy a new mower.
#2 can be fixed if it was the pin and not the shaft.
Jul 07, 2009 | Garden
Fb460v kawasaki will not start
check your camshaft to see if exhaust loab has been worn off. have seen this before
May 01, 2009 | kawasaki Full Suspension Mountain Bike Men
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
