Question about LG Studio Series LSDF795ST
IT SAYS LE IT WONT DRAIN - LG Studio Series LSDF795ST
    Prodigy:
    An expert who has answered 500 questions.
  • LG Expert
  • 536 Answers
The water circulation pump motor can cause the LE error code to be displayed.
Posted on Apr 23, 2014
LE error code has popped up & suddenly the control lock is on, I have pressed the control lock & it counted 3,2,1 & nothing happens, won't unlock & LE is still there
if the door locks and wont unlock
LE error
then your machine still has water in it from the last spin/ wash
i think its a blocked up waste outlet
or the pump is blocked up
you need to check the machine is draining correctly and in a timely manner.,..
or it will fail
you need to fully drain the machine then turn off the mains
wait 5 mins and the door will then open
then check the drainage...
Feb 08, 2015 | Washing Machines
Door light wont go off will it drain battery?
yes it will drain your battery pull bulb out
Feb 23, 2013 | 2007 Toyota Corolla LE
My clothes were in the washer and when I went down to check there was an error code. LE The clothes were still wet, and appeared to not have gone through the rinse cycle.
The LE is caused by over sudsing OR clothing trapped between the tubs. The LE: hall sensor shorted/destroyed from sudslock or clothes between tub. Correct the issue and party on.
LG errors:
IE: Water level (246) was not reached in 8 minutes
UE: Imbalance: Load too, small too large
OE: Drain problem took longer than 10 minutes to drain
FE: Overflow issue drain pump running to comp
PE: pressure sensor (sensor out)
dE: door error. open door. switch is out
LE (with a a slash in the
middle of L. Upside down F) Thermistor out
CE: Over amping Too much soap wrong soap
bE: Ball sensor loose connection/out of order
EE: eeprom out test mode only
PF: power failure momentary interuption of shocktricity
LG service manuals and repair notes.
Apr 17, 2011 | LG WM2487H Front Load Washer
LG washer WM 2277HW Wont spin LE on control panel
LG error codes:
PF: power failure momentary interruption of shocktricity
LG washer notes:
Problem:
An occasional LE error but always a slow or no spin.
Solution:
A Red wire going to the Hall sensor was intermittent. You can test this from the main board connector down to the connector on the hall sensor by checking continuity. There is an intermediate connector down by the motor/hall sensor so you can isolate the problem even more. Problem was in the short wire harness that connects directly to the motor and hall sensor. Could not find the open point of the wire so added a new red wire and integrated it into the harness.
Your service manual and more LG washer notes HERE
Mar 07, 2011 | LG WM-2277HW Front Load Washer
LG WM0642HW ALWAYS HAVE (LE)
Unplug the unit from main outlet.Then drain the water from the machine.By disconnecting the drain pump ,There will be too much water so be care full.If you disconnect the drain pump from drain hose to drain the water it will flow on you,so keep towels ready to soak the water. Also clean the water filter. ----------------- In most of the case LE error is solved by just disconnecting the washing machine from main power outlet for 30 minutes.But if the problem is still the same then try cleaning the filter and draining the water from drain pump.This error occurs when motor stops functioning and water does not drain. --------------Also another cause of LE error is Regarding the LE ERROR CODE. This code is also caused by having a residue on the sensors in your unit. You have to use a HE liquid detergent.If you use fabric softener use half of the recommended amount and dilute if it is concentrated. Once a month (for a family of four) put 3 cups of white distilled vine-ager directly into the drum and select sanitary cycle or the hottest cycle you can. This prevents residue from forming in your unit and causing the LE ERROR CODE. ---------------- This should help.Thanks.Helpmech,.
Jan 25, 2011 | LG Washing Machines
LE code
IE: Water level (246) was not reahed in 8 minutes
middle of L. Upside down F) Thermister out
WM-2277HW service manual and more HERE
Thanks for using FixYa
Jan 07, 2011 | LG WM-2277HW Front Load Washer
Bonjour , nous avons un Asko D-3120 j'entend le moteur fonctionner mais rien ne se passe a l'interieur et la lumiere de la tasse avec une assiette clignote sans arrêt . J'ai essayé...
le drain est boucher et la panne de reserve est pleine d'eau solution sort le lave vaisselle de sont emplacement et enleve le panneau arriere ensuite éponge l'eau et débranche le tyau de drain place le tuyau de rain dans un sceau et demarre un cylce de rincage et verifier si il ne coule pas lors du cycle dans la panne
Nov 01, 2010 | Asko Dishwashers
After i start my l g dishwasher it stops and flashes l e on the start button , and the water wont drain
The LE error is saying that water is "leaking" out of the dishwasher before it is being intentionally pumped out. If you have checked underneath the unit for a real leak, then 99% of the time, your problem is related to a law of physics.
Follow the drain hose from underneath the dishwasher over to where it connects to the drain (normally the disposal) I bet you will find that the dishwasher is connected directly to that drain and not connected through an air gap. The hose is probably routed along the floor with no high point.
The drain hose must have a high point in it somewhere in the run so that a natural siphon does not get created and "pulls" the water out of the dishwasher while it is running.
Best way to fix it is to install a dishwasher air gap (almost free at any real hardware store) but you can also lift the hose and attach it somewhere to (under) the counter. That will prevent the LE error.
Sep 12, 2009 | LG Dishwashers
LE error after machine fills with water
LE error means level error (the d/w fills up but the water drain out at the same time somehow). I had a case once where the drain hose at the back of the d/w was resting on the floor to drain underneath the cust house. problem is like any drain hose it has to GO UP FIRST and then down to the ground otherwise the gravity will push the water out as the d/w fills up hence the LE error.
take care.
Jul 19, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LE error code
The LE error code can be an indication of several different issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire or a dislodged ball sensor. Good luck!
Aug 19, 2007 | LG WM1812C Front Load Washer
LG Studio Series LSDF795ST Logo
41 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
