Question about General Electric GSH25JSXSS Stainless Steel Side by Side Refrigerator
Ice maker does not work - General Electric GSH25JSXSS Stainless Steel Side by Side Refrigerator
  • General Master
  • 5,323 Answers
ICE MAKER not making ice
Inspect Water fill tube, Inspect the ice maker mold to see if there are ice cubes present. If there are no cubes or very small cubes, then you should look for issues with the water fill system. Inspect the fill tube and the fill cup area at the back of the ice maker to make sure that they are not frozen. If there is an ice buildup in that area, confirm no foreign objects have disrupted the flow of water into the fill cup. If nothing obvious has caused the ice buildup then suspect the inlet valve, tubing or low water pressure. Inspect the outlet tubing from the fill valve to the ice maker fill tube for any signs of restrictions and replace if necessary.
WATER INLET VALVE:
Check the water inlet valve for any restrictions. You will need to shut off the valve from the household water supply before you disconnect the inlet tubing. Some water inlet valves may have a screen to filter debris before it can enter the valve. If the screen is plugged, water flow will be restricted and the result will be small or layered ice cubes. Remove and clean the screen or replace the valve. If dirt has gotten into the valve it may not shut off completely and will continuously drip water into the ice maker fill tube and will eventually freeze up. Low household water pressure or a restriction at the manual shut off valve will also cause the water inlet valve to not shut off completely and create this same condition. Self piercing saddle valves are the most common shut off valve to cause this problem as the hole that is pierced in the water line is often too small and will more easily become restricted.
The water inlet valve is operated by line voltage supplied through the ice maker control. Power is applied for approximately 7-9 seconds during the harvest cycle and energizes the solenoid on the valve to allow water to flow.
You can check the solenoid for continuity with a multi-meter. On models with multiple solenoid inlet valves, you will need to determine which portion or portions of the valve are used for the ice maker. You can normally follow the inlet tubing from the ice maker back to the valve. Unplug the refrigerator and turn off the water supply to the valve before working with this part.
(HOW TO TEST INLET VALVE: Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear theclog, it will be necessary to replace the valve (the filter is not removable on most inlet valves). Test thewaterinletvalve for continuity using a multImeter. First, inspect the coil for an indication of it's ohm rating. If no information is printed on the coil, then use the range of 170 to 500 ohms. Set the multitester to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multitester should display a reading that matches the coil's rating or if you don't know the rating then it should fall into the range of 170 to 500 ohms. If the water inlet valve does not pass this test, it should be replaced. If the inlet valve has two coils, test the second coil in the same way (note that they may not have the same ohm rating). The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
Check the tap valve.A bad tap valve-the little device that connects the ice maker's water supply tube to the water pipe-may cause the problem where the ice maker's supply tube connects to the water pipe. If necessary, replace the inlet valve and the tap valve. For the tap valve, use the type that requires you to drill a 1/4-inch hole (as opposed to the "self-piercing" type). You can buy anice maker connection kitand do this yourself, or call a repair person or plumber to install an inline water filter when replacing the valve.
Lastly the ICE MAKER ASSEMBLY:
If there are no ice buildup issues or suspected problems with the water supply, then you may have a problem with the ice maker control. The most common type of ice maker used in modern refrigerators is the heat release ice maker. The ice maker uses heat to release the ice cubes.
If the water's route is blocked or the solenoid doesn't work-or if the bail wire is lifted-the ice maker won't make ice. (Also note that your home's water pressure may not be strong enough to serve an ice maker.)
If you have a heat release or modular ice maker it will have a removable cover at the front. Behind the cover is a series of electrical test points that can be used to diagnose the ice maker. The unit can be manually operated by inserting an insulated jumper wire into test points "T" and "H" to initiate a "test harvest". On other ice makers jumper at points N & M (neutral to Motor) The jumper should be insulated 14 gauge solid wire that has the insulation stripped back about 3/4 of an inch on both ends, and bent into a "U" shape. When inserted into the test points for 5 to 10 seconds, the motor should start and the cycle will continue on its own. You may have to manually close the freezer door switch for this to operate.
This test will simulate a real harvest cycle and will operate the ejector blades, shut off arm and the fill valve in the proper sequence, and will allow you to do a proper diagnosis. This is a live voltage test and should only be performed by a qualified person. If the motor does not start, you can verify that you have power to the ice maker at test points "L" and "N". If the ice maker is getting power and does not perform a cycle, then the module will need to be replaced
On component mode ice makers the testing is done differently.
Testing a thermostat in a component ice maker:
The thermostat is located near the bottom ofthe support box. The thermostat is connected by two or three wires.Label the wire placement before disconnecting them. Remove thethermostat by loosening the clamp, by pushing back the retainerclips, or by removing the retaining screws.
Test the thermostat forcontinuityusing amultitesterset to the ohms setting X1. Start by testing the thermostat whenit has come up to room temperature (about 20 minutes after removing it from the freezer).
If the thermostat has two wires touch one probe to each wire. You should get a reading of infinity.Chill the thermostat in the freezer for about twenty minutes andretest. This time you should get a reading of zero (continuity).
If the thermostat has three wires, number them 1, 2 and 3. Test combinations 1 & 2, 1 & 3and 2 & 3 and write down the results. Two of the combinations should yield a reading of infinity and one should yield a readingof zero. Now chill the thermostat in the freezer for about twenty minutes and retest. The combination that had a zero reading before, should now have a reading of infinity. One of the two other combinations should now yield a zero reading.If the thermostat fails this test, it should be replaced.
Testing a modular ice maker 'sthermostatcan be tested and replaced individually.
Test the thermostat forcontinuityusing amultitesterset to the ohms setting X1. Start by testing the thermostat when it is cold (10 degrees). Insert one probe into the hole labeled "T" and the other probe into the hole labeled "H". The meter should indicate zero resistance (continuity). After the ice maker has warmed up, repeat the test and this time the meter should indicate infiinity (no continuity).If the thermostat does not pass both tests, it should be replaced.
God is the reason I give you free advice so God is good!
Posted on May 06, 2015
Is it OK for ice thickener sensor touch water on ice maker
Yes, it has to touch the water. As the ice builds up the thickness sensor moves up and turns of the refrigeration and turns the heater on.
  • How Icemakers Work ' HowStuffWorks home.howstuffworks.com/icemaker.htm How Icemakers Work. ... we'll look at the cycle an icemaker goes through to make ice. ... Get the best of HowStuffWorks by email. Keep up to date on:
  • How Does The Ice Maker On A Refrigerator Work ... - YouTube www.youtube.com/watch?v=x4YDWUK0jv8
    • BY REPAIRCLINIC.COM
    • 4 MIN
    • 347K VIEWS
    2012-05-15 · Video embedded · This video provides information on how a refrigerator icemaker works and offers troubleshooting tips ... How Does a Refrigerator Water and Ice Dispenser Work?
  • How Ice makers Work - ApplianceAssistant.com applianceassistant.com/.../Ice-Makers/How-Ice-Makers-Work.php How Ice Makers Work! Learn How Ice Makers Work, ... How Ice makers Work. The Ice Maker Cycle ' Ice Maker Components ' Cube Size Replacement Ice Makers . They Don't Make
  • How Does an Ice Maker Work? - Reviewed.com Refrigerators refrigerators.reviewed.com/features/how-does-an-ice-maker-work Here's how your ice maker works. BACK TO . Best Right Now; How To s; Award Winners; How We Test; ... How Does an Ice Maker Work? It's more complicated than ...
  • Refrigerator Icemaker Repair How It Works
    May 12, 2016 | Refrigerators
    GE Profile Model PSS26LGSC Ice maker not working
    Did the ice buildup appear to resemble the water overfilling the top of the ice maker? The only thing that I believe that may work is removing the ice maker, clean the excess ice buildup.dry and reinstall the ice maker and see it works. If the ice is above the normal level the ice can cause the motor that pushes the ice out of its slots to strain more than the gears or motor can handle stripping the gear or damaging the motor beyond repair, When harvest takes place the first thing that happens is a heater below the ice maker warms the cubes a little just enough to allow them to slide out of their slots and fall into the ice bin. The ice make for your model does not have replaceable parts and if bad or damaged it is less expensive and time consuming to by a new ice maker. If the water fills above the top of the ice maker it is usually the fault of the water control valve not closing all the way once it fills the ice maker after each harvest. Did water refill the ice maker when you cleaned it? Did the water overfill after you cleaned out the ice maker? What I am asking is water over filling ice maker again after you cleaned out the excess ice? If the water continues to flow from the WR57X10032 Water Inlet Valve
    Apr 07, 2013 | GE Refrigerators
    Ice maker
    Before going to buy any parts directly.
    Go through this troubleshooting help links.
    This is list of refrigerator problems, which is normally faced in refrigerator.
    You can go through the details, by clicking the link below:---
    Refrigerator is not cooling properly?
    http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
    Both refrigerator and freezer not cooling properly in refrigerator?
    http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
    The ice maker not working: ---
    http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
    Compressor not running on refrigerator?
    http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
    Water dispenser not working on refrigerator?
    http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
    Ice maker stopped making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
    Water Overflows in Ice maker and freezes inside?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
    How to replace Ice maker assembly?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
    other ice maker related issues and solutions:---
    Ice maker dispensing ice with black or white plastic pieces in ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-ice-with-black-or.html
    After replacing ice maker assembly, ice is not getting made?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/after-replacing-ice-maker-assembly-ice.html
    Ice maker is leaking water and causing the ice to freeze?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-leaking-water-and-causing.html
    Ice maker is noisy and not making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
    Refrigerator ice maker stopped making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/refrigerator-ice-maker-stopped-making.html
    Ice maker leaks water into ice bin causing a glob of ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaks-water-into-ice-bin.html
    Amana Refrigerator leaking water from ice maker?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/amana-refrigerator-leaking-water-from.html
    Ice maker leaking?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaking.html
    Ice maker is dumping the ice cubes out before frozen solid.
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-dumping-ice-cubes-out.html
    Water overflowing ice maker?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflowing-ice-maker.html
    Ice cube is getting stuck up hard in ice maker
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-cube-is-getting-stuck-up-hard-in.html
    Icemaker quit working?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/icemaker-quit-working.html
    Quit making ice
    http://alltypesofpartsreplacing.blogspot.com/2011/10/quit-making-ice.html
    Water leaking into ice tray, frozen glob of ice
    http://alltypesofpartsreplacing.blogspot.com/2011/10/water-leaking-into-ice-tray-frozen-glob.html
    Not making ice, and water leaking in freezer?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/not-making-ice-and-water-leaking-in.html
    The ice maker stopped making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice_20.html
    Ice maker not making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-making-ice.html
    Ice maker quit working?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-quit-working.html
    Ice maker dispensing black pieces of plastic in the ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-black-pieces-of.html
    Replaced Ice maker but its still not making ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/replaced-ice-maker-but-its-still-not.html
    Ice maker leaked creating an ice block?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaked-creating-ice-block.html
    Ice tray leaked?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-tray-leaked.html
    Ice maker stopped functioning?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-functioning.html
    Ice maker stop working?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stop-working.html
    Ice maker failed
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-failed.html
    Old ice maker stopped working?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-stopped-working.html
    Old ice maker started leaking?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-started-leaking.html
    Ice maker not working?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-working.html
    Ice maker overfills and cause water to flow into ice dispenser and freezes?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-overfills-and-cause-water-to.html
    Ice maker didn't make ice?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-didnt-make-ice.html
    Ice maker was leaking?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking.html
    Ice maker was leaking after it filled up with water?
    http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking-after-it-filled.html
    These will help.
    Thanks,.
    Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
    The ice maker appears not to be working can not
    Here is a tip that I wrote about the reasons why ice makers do not work.
    Ice Maker Problems and Ice Maker Troubleshooting
    heatman101
    May 31, 2010 | Liebherr KIKNV3056 Bottom Freezer...
    heatman101
    uiouio67
    May 24, 2010 | KitchenAid Architect 25.3 Cu. Ft....
    heatman101
    fdfdfs43
    Apr 19, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    Ice maker is not working. I hear water running to ice maker but no ice is being produced
    heatman101
    kjjhfkj
    Jul 02, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
    Ice maker will not make ice, water dispenser is working
    heatman101
    oypyiooiyp
    May 27, 2009 | Amana 22.6 cu. ft. Side-By-Side...
    ICE MAKER NOT WORKING
    heatman101
    Jan 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
    Refrigerator ice maker stopped working
    heatman101
    mnnmbnm
    General Electric GSH25JSXSS Stainless Steel Side by Side Refrigerator Logo
    130 people viewed this question
    Top General Refrigerators Experts
    John Tripp
    John Tripp
    Shehu Pro
    Shehu Pro
    Joseph Mueller
    Joseph Mueller
    Are you a General Refrigerator Expert? Answer questions, earn points and help others
