Question about Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Door open message when door is closed - Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
    New Friend:
  • 3 Answers
The switch or button that the door pushes up against might be bad you can check this by holding in the button and turn on the dryer if it work than the door is loose if not you need to replace the door switch
Posted on Nov 27, 2013
I HAVE A SAMSUNG PRINTER SCX-4623 THE MESSAGE KEEPS ON SAYING DOOR OPEN CLOSE DOOR , TRIED EVERYTHING BUT NOTHING WORKS
Dear
The front door right side there is a lever found when it is opened the lever should close the micro switch inside and the door is locked with another short lock (near the long lever). If door lock broken then the micro switch push the lever and door not closed.
the basic problem with the micro switch and related mechanical alignment.
Thanks.
Feb 26, 2015 | Samsung SCX 4623F - Multifunction fax /...
Driver door open message is on even when door is closed
should be on the door post or maybe in the closer mechanism..most are faily close to one of the door hinges..
Dec 31, 2013 | 2010 Cadillac CTS
Konica DiALTA Di1611 error message 2nd side door open although the door is closed.
Check and clean the sensors and actuators,verify the cable connection,verify if 5V appaire to red cable.
Apr 09, 2013 | Office Equipment & Supplies
On a clx-6200 message says "paper jam 0-c=open/close door. what door is this?
It is telling you that there is a paper jam. Open the door, pull the jammed paper out, close the door, it should clear the message.
Apr 21, 2012 | Samsung CLX 3160fn All-In-One Printer
'user door open' error -where is the 'user door'? We have opened and closed all the parts we can find that open and close.
the door you open to put the cartridge. If the door is closed and you still get the message, it means the door is not activating the microswitch when the door is closed. There must be a tab on the door which presses the switch.
May 22, 2009 | Dell 1815dn All-In-One Laser Printer
My passenger's door open indicator is on but the door is closed. Where is the indicator located? 2005 freestar. Thanks
Normal Operation When any door or the liftgate is opened, the ajar switch provides a ground signal to the smart junction box (SJB). When the door or liftgate is closed, the ajar switch opens, removing the ground signal. The SJB uses the multiple inputs from the ajar switches to determine whether the doors or the liftgate are in the open or closed position. The SJB then provides a message to the instrument cluster over the communication network. The message center uses this information to display the door/liftgate ajar message.
I suspect your door switch is not closing all the way.
Mar 28, 2009 | 2005 Ford Freestar
Error message: "Door Open"
HI there,
Follow the steps below:
Step one: Close the print cartridge access door
1.Verify that the print cartridge access door is completely closed. It may appear to be closed, but if it is not completely closed, the error message will display. Verify that there are no obstructions blocking the door.
2.If you are unsure how to close the print cartridge access door on your model, consult your User Guide for more information.
Figure 1: Examples of closing the print cartridge access door (your model may vary)
f3e57be.gif If you have attempted to completely close the access door and the error still appears, there may be a problem with the door sensor and the unit may require service.
Step two: Service your product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Good Luck!!!
neo
Feb 28, 2009 | HP OfficeJet Pro L7580 Color All-in-One...
Door error message
you may have a broken cartridge lock or door sensor. remove all the toner cartridges. then open and close the door and watch for 4 white hooks that open and close on the right interior of the machine where the cartridges are installed. if three of the 4 open and close with door then the one that doesn't is your broken lock. if all 4 work then you have a broken door sensor. Good luck.
Aug 10, 2008 | HP Color LaserJet 2600n Printer
Error message-Close the back cover
It appears that you have a broken back door have a look on the door to see if there is a broken piece of plastic as when you shut the rear door a tab pushes against a push switch letting the machine know that the door is closed. if you cannot see a broken piece then the switch it faulty try this by push a flat screw driver on the switch and check if the message disappears.
Thanks J
Jan 07, 2008 | Brother IntelliFax-2820 Laser Fax
Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer Logo
80 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
