Question about Belize Spas Belize e480L Lounger Spa - PS8304
Over heating spa
Help
  • 1,631 Answers
Are Jets staying on HIGH?
Are your controls mechanical or digital?
Exact Information of the spa control system, not the spa manufacturer, will help us to help you. The box below with all the wires coming in & out. Name, model, code & serial #'s will help.
When jets stay on & don't turn off, water will heat up just by circulation causing "Friction".
If mechanical, your thermostat may have failed. If digital, your temperature sensor may have failed.
Dirty filter can cause this as well, if your flow sensor is failing.
Posted on May 03, 2014
Can you help me figure out why my spa stopped heating?
Without more diagnostic info or what you may have done in your troubleshoot, or what is or isn't happening...
Try cleaning your filter!
Most common reason a spa stops heating!
May 16, 2015 | Optimus Vertical Heater, Gatsby/blue...
Why does my pump want to shut off after I enable the heater?
before turning to spa dis able pool heat then try if same happens need new PCB control board
Jun 01, 2014 | Zodiac Jandy AquaLink RS All Button Wired...
My pump on my spa to go works but i get no heat
Does it even have a heater ? these portables used a scavenger to heat the spa. it's a cove around the motor that uses the heat from the motor to heat the spa. it takes about a day to heat the spa and the heat doesn't last long. sorry .. . good luck and vote if'n I was of help.. jay the pool pump motor repair guy longwood florida
Aug 08, 2013 | Comfort Line Spa 2 Go Portable Spa with...
SL display came on. Not heating.
If the SLP or SL Message is Alternating with the Water Temperature on the Display, the Spa is Operating in the Sleep Heating Mode.
If the SLP or SL Message is ON Solid (Not Flashing) on the Display, the Spa is Operating in the Sleep Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
Hope this helps.
US Parts Center
Aug 31, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
SPA WILL NOT HEAT PAST 94 DEGREES. i HAVE IT SET TO 103 AND IT HAS NOT MOVED PAST 94 DEGREES FOR OVER 1 HOUR EXACTLY WHAT BUTTONS SHOULD BE LIT ? IN OTHER WORDS IS THE AIR BLOWER LIGHT SUPPOSED TO BE...
if hook up to the firemans switch turn heater all the way to 104 degrees if using 4 pin connector for aqua link to heater set spa temp to 104 and make sure on aqualink spa heat is enabled and 104 degrees
Nov 30, 2010 | Jandy Aqualink Rs4 One Touch Control...
Hi! I have a Hayward Pro pool/spa system with Jandy valves and I'm trying to figure out how to switch them from pool to spa. Either I empty the spa or I'm heating the whole pool. Help please!
This is tough cause I can't see the valve setup. I have to assume they are manual valves. Normal operation probably takes some water out of the pool and spa than puts it back into both. To heat the spa, set the intake valves(the ones in front of pump) to take water from only the spa. Set the jets(valve(s) on output side of filter) to send water back to only the spa. The pool will be out of the loop. Normal operation usually has water taken out of pool and spa than put back into both. Make sure to put more water back into spa than you take out, (Adjust valve)
Apr 23, 2010 | Hayward SAND FILTER, PRO SERIES
I want to heat the pool from the spa. I have the spa and spa heat on but the spillover wont come on when I have the spa on. When I turn the spa off the heat goes off. What do I do
When your system is put into Spa mode the system draws water from the spa only to the heater to keep the spa at temp, this is why the overflow doesn't work and why you can not heat the pool in spa mode. If you could heat the pool this way it would take a very long time, since the spa is smaller then the pool. You can heat the pool and spa at the same time in pool mode. Water is pulled from the pool, heated and goes back into the pool and spa.
Mar 27, 2010 | Jandy AQUALINK RS TELELINK KIT
Just got a lay-z-spa, series II spa ...which works fine, but would like to increase the temp. Any suggestions?
It is dangerous to run your heat past 104 and by law cannot go past 106. If you want go past these I can't help. Other than that ck your heat sensor or thermostat.
Dec 02, 2009 | Pool & Spa
Belize Spas Belize e480L Lounger Spa - PS8304 Logo
151 people viewed this question
Top Belize Spas Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Belize Spas Pool and Spa Expert? Answer questions, earn points and help others
