Question about ASUS P6T6 Ws Revolution Workstation Motherboard - Workstation Intel Chipset Socket B Lga 1366 ATX 1 x Processor Support 12 Gb DDR3 SDRAM Maximum RAM Crossfirex Support Floppy Controller, Serial Attached SCSI SAS, Serial ATA/300 RAID Supporte
I have a gateway atx 300 12 e psu i belive is dead,can I use a newer psu with 24 pins?
    Problem Solver:
  • 22 Answers
Yes, in almost all cases, a 24 pin PSU can still work on a 20 pin board, the 24 pin connector usually splits at the 20 pin point and will then fit the board socket. Just make sure whatever PSU you buy can do this and you'll be fine. The more important thing is to make sure all the other connectors are the correct style for your board.
Posted on Nov 21, 2013
LEDs on motherboard light up but computer won't start
It still may be dead. Go here and get a PSU tester:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=-1&IsNodeId=1&Description=psu%20tester&bop=And&Order=REVIEWS&PageSize=20
Apr 24, 2012 | Antec : True430 430W P4 ATX Power Supply...
I have a Compaq Presario SR1830NX desktop, I leave it on all the time, when I got up this morning, it was off, so I pressed the power button, but it doesn't power on, nothing happens.. I checked the power...
step 2 the TECH uses a voltmeter and checks all wires on PSU for correct voltage.
PSU in Desktop dead, my guess fans dead too right>
you never said, what it does inside PC ,except nothing
does nothing mean dead silence?
the fan must run for 1second, then goes off.
a 1 second run tells me the PC power switch told the MOBO to turn on and in turn it tells the PSU to turn on,
the PSU then turns on for at least 1second,and if the voltages are ok
then the PSU stays on, else off goes.
15 and 16?
the 20 pin older supplies those are both ground
but 24 pin ATX pins are correct there.
the voltages are here.
https://en.wikipedia.org/wiki/ATX
There are 2 causes, of dead power button.
1: the buttons 2 wire cable ends fell off. at button or PC mobo.
2: The PSU is bad.
3: the MOBO is bad.
The mobo can also shut off any PSU, if the PSU fails
or it sees the regulators in the MOBO fail.
the Desktop runs on many power rails.
some in the PSU, others on the MOBO.
THe mobo creates special low voltage for the CPU.
the power good pin, does that #8,
One way to see if the MOBO is overload
is to remove things from it, I start at RAM
lacking a voltmeter, this is very hard to fix any thing electric.
only guessing or pulling objects PC can find shorts.
pull all power cables there, hdd, power, cdrom.
all things that use red/yellow wires.
all SATA cables, all USB , then ram. even a fan can short
a good tech keeps an open mind, and finds why the PSU shut down.
in most cases, the PSU is bad. but not always.
This is a feature, of ATX it keeps you from blowing up say a
$300 microprocessor.... or fancy gaming Video card (have one)?
yes, pull the video card too.
Jun 25, 2017 | HP Compaq Presario SR1630NX PC Desktop
How to use ATX-250-12z SMPS with 24 pin
Chances are that 250w power supply is not going to power a motherboard with a 24 pin connector, but you can try.
You will need to purchase a 20 to 24 pin adapter cable.
Google Search Terms: 20 to 24 pin adapter
Oct 27, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
The PSU bestec atx-250-12e is dead, there is an easy fix for it
You can find the same psu at ebay with free shipping.
http://itemlistings.ebay.com/sdcsrp?fl=360131455504&product=bestec+atx-250-12e&sconstraints=PriceMin.Value%3D23.00%26PriceMax.Value%3D45.59
Aug 20, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
Hp compaq dc 7100 psu 24 pin SLIM LINE
why wont you buy a new power supply or a plug that converts from a 20 pin to a 24 pin
Mar 31, 2009 | HP Compaq dc7100 PC Desktop
Mother board servicing
Have you verified that the PSU is OK.
DO you have a voltmeter?
Check the voltages on the main connector to the board
HERE is the 24 pin ATX connector
HERE is the 20 pin ATX connector
If the voltages are not there then either the PSU ON signal is not there, the ON switch is faulty or the PSU is dead.
Post back results and I will try to assist furher
Jul 09, 2008 | ASUS P4S8X Motherboard
Redundant hot swap psu's to EPS 12V (24-pin) ATX Power Supply
rpi.jpgthis is the psu
zalman.jpgthis eps 24 pin
as u can see the matter at hand can be preformed, as long as the fitting is compatable
Jan 29, 2008 | Computers & Internet
P4T-E PSU
your connector is of two part.it has total of 24 pin, can be divided into 20 and 4 pins.connect  20 pin  in your mother board .switch on ur psu and connect 4 pins to another port.
Jan 19, 2008 | Powmax 400 Watt ATX Switching Power Supply...
No power
reg desktop computer ? 4 screw on back unplug it out buy new one atx style for latest computer sum use mini small power to fit in smaller cases micro atx let me know more info
Jan 06, 2008 | Gateway Media Center 610XL PC Desktop
ASUS P6T6 Ws Revolution Workstation Motherboard - Workstation Intel Chipset Socket B Lga 1366 ATX 1 x Processor Support 12 Gb DDR3 SDRAM Maximum RAM Crossfirex Support Floppy Controller, Serial Attached SCSI SAS, Serial ATA/300 RAID Supporte Logo
105 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
