Question about LG LMV1630ST Microwave Oven
How do you set clock lg 1630 st - LG LMV1630ST Microwave Oven
Microwave oven model lmvm2085st how do you set the clock
Good afternoon Chris.
To set the clock:
  1. Push the [Clock] Button
  2. Enter the time with the keypad. For 8:37, type 8 3 7 for example.
  3. Touch [Start/Enter]
  4. Press [1] for AM, [2] for PM.
  5. Press [Start/Enter] again to finish.
You can download the manual on this page at the LG website:
http://www.lg.com/us/support-product/lg-LMVM2085ST
Hope that helps, and good luck!
Nov 18, 2015 | Microwave Ovens
Need to st clock on panasonic nne281mm
follow the steps and fix it. God bless you
1) Press the "Stop" button on the microwaveicon1.png to reset the digital display to the clock setting.
2) Push the "Clock" button once. Locate the "Hour" button and press it once for each hour of time. For example, if the current time is 5:15 p.m., press the Hour button five times.
3 )Press the "Minute" button to set the second half of the time. For the example above, you would press the Minute button 15 times to set a time of 5:15 p.m.
4)Push the Clock button to saveicon1.png the time setting. Check the time on the microwave's digital display.
Feb 07, 2013 | Panasonic Microwave Ovens
I need I know how to set the clock on an lg microwave model ms1446sqp
The MS-1446SQP is the version of this microwave sold in Mexico. To set the clock, press the button labeled Parrar/Borrar (Stop/Clear on English microwaves) in case any cooking programs are running. Then press the button with the clock face (Reloj). Then press the touch pad labeled Inicio/Inicio Rapido (Start/Fast Start). Type in the 4 digits of the current time (24 hour format). Then press Inicio again. (Note: I have left off the accents.)
The manual for the LG MS-1446SQP is available here: http://www.lg.com/mx/soporte-producto/lg-MS-1446SQP . The directions for setting the clock are on page 12 (pictures of the control pad are included). This is the Spanish version of the manual and is a pdf. Thus you will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Nov 18, 2012 | Microwave Ovens
I have an LG Intellowave microwave model MS1942G and would like to know how to reset the clock please.
Push button that says 'clock' then use the '10min' button to set hour, '1min' to set 10 minute intervals, then '10sec' button to set minutes. Click 'clock' button again to save. The trick is to make sure the the colon like dot separator on the clock is flashing when you try to make changes. Did my head in working this out... in the end I had to ask my wife...
Sep 11, 2010 | Microwave Ovens
My LG LMV1630ST has an issue with the clock. The
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Is it a US model (made for 60HZ power) being used overseas
(50HZ power)?
* * * * * NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly for more FREE help & do-it-yourself advice.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 07, 2009 | LG LMV1630ST Microwave Oven
I cannot set the clock on my LG MS1949G Micro wave
After spending 25 minutes on hold while LG try to find out how their own product sets the clock, I now know that the LG MS1949G Microwave open does NOT have the ability to set a clock that shows the time of day.
Jul 11, 2009 | LG LTM9000 Microwave Oven
How do you set the microwave clock?
After setting the time push the clock button again and it should start working after a minute passes (on some models you have to hit the start button after setting thr time!
Please rate this response
thank you!
Jan 26, 2009 | Microwave Ovens
LG 1630 st is not heating!
I have the same problem and mine was manfuactured Feb 06. HMMMMM. Very interesting. I am going to E-mail LG. Anyone else have the manufacure date. The date on the inside to the left of the door frame
Mar 25, 2008 | LG LMV1630ST Microwave Oven
LG LMV1630ST Microwave Oven Logo
32 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
