Question about British Telecom Lands Phones
Turn ringer volume up
Where is the arrow to turn volume up on phone cant see one
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • British Telecom Master
  • 102,366 Answers
What model phone?
Posted on Nov 17, 2013
4 Suggested Answers
SOURCE: Ringer Volume
I am assuming this is on a DTU 16D nec phone. On the right side of the phone is a volume up and down button. If someone calls you, you adjust this while the phone is ringing. If you adjust it after you answer it controls the voice volume (what you hear through the ear piece) if you adjust it while the handset is down but there is no one calling you it adjusts the display contrast on the phone.
Posted on May 10, 2007
CORDLESSGURU
  • 106 Answers
SOURCE: Ringer off, need to re-install ringer. volume control does not put ringer back on
To turn your ringer back on, you do the following. For your handset, you push Menu, scroll to ringer settings, then push select, Press select again for ringer volume, then scroll up to turn on and increase the ringer volume. Then press Save once its at the desired volume. To change your base ringer, while it is not in use, push the ringer up button until you hear the desired setting. That should fix your problems.
Posted on Mar 23, 2008
AvioriX
  • 689 Answers
SOURCE: lowering ringer volume on handset v tech 5.8 digital phone
You didn't indicate exact model of your phone. However I have indicated the procedure used for common Vtech's 5.8Ghz phones
Ringer volume
• With the handset or base in idle (off) mode, press MENU then
press ▲ or ▼ until RINGER VOLUME is shown
• Press SEL. You will hear a sample of the ringer
• Press ▲,▼ or a digit (0 through 6) You will hear a sample of
the new ringer volume and the volume bar will be increased or
decreased each time the setting is adjusted At the lowest setting
the ringer will be turned off and the display will show:
- OR -
• With the handset or base in idle (off) mode, press or of the
volume control will directly go to ringer volume menu
• Press ▲ or ▼ to adjust the ringer volume
Good Luck
Posted on Nov 11, 2008
The ringer is turned off. How do I turn the ringer on? also can I buy another owners mannual
To set the ringer volume of the base unit, press FUNCTION/EDIT, scroll to Ringer Setting using the up or down arrow keys of the navigator key(lower right of base unit), press the right arrow key to select Ringer Setting. Press the right arrow key again to select Ringer Volume. Use the up or down arrow keys to choose the volume level, press the right arrow key to save the setting.
To set the ringer volume of the handset, press the CONF/FUNCTION button(lower left) on the handset, scroll to Ringer Setting using the up or down arrow keys of the navigator key(center of the handset), press the right arrow key to select Ringer Setting. Press the right arrow key again to select Ringer Volume. Use the up or down arrow keys to choose the volume level, press the soft key SAVE to save the setting. (There are three softkeys directly under the LCD screen of the handset whose functionality can change according to what is on screen)
The manual can be downloaded from the link below free of charge.
http://service.us.panasonic.com/OPERMANPDF/KXTG2770S.PDF
Mar 28, 2011 | Panasonic KX-TG2770 Phone System w/...
Message box says, "ringer off".
Ringer Settings
Handset ringer volume
4 levels (high/medium/low/off) are available. The default setting is HIGH.
1. Press "Menu."
2. Scroll to "Ringer setting" by pressing up or down arrows.
then press the arrow that looks like a play button arrow pointing to the right.
"Ringer Setting"
3. Scroll to "Ringer volume" by pressing arrow down or arrow up, then press the play button type arrow.
4. Press arrow down or arrow up repeatedly to select the desired volume.
5. Press "Save."
(To turn the ringer off, press down arrow repeatedly until "off?" is displayed, THEN PRESS "SAVE.")
Here's the manual:
http://service.us.panasonic.com/OPERMANPDF/KXTG2431.PDF
Please give me positive feedback if this helps you.
Thanks.
Feb 23, 2011 | Panasonic KX-TG2431 Cordless Phone
The kx-tga510m phone displays "ringer off". How do I change it to get the ringer on?
To change the ringer volume, press the conf/ function button.
Scroll to ringer setting using the up and down arrow keys.
Press the right arrow key to enter.
Press the right arrow key again at ringer volume.
Press the up and down arrow keys to adjust the ringing volume
Press the save soft key to save entry.
Sep 30, 2010 | Panasonic KX-TG5100 Cordless Phone
Phone shows ringer is off..how do I turn it on?
Follow the steps
Press Menu--->Ringer setting--->Ringer volume----> press up button to ON the ringer.
You can reduce ringer volume by down arrow and increase volume by up arrow.
Thanx
Jul 24, 2010 | Panasonic KX-TG2343 Cordless Phone
Ringer off on line 2
To turn the ringer off (or on)
press the conf/ function key,
scroll to "ringer volume" using the up and down arrow keysand press the forward arrow key
press the down arrow key for line 1 and the up arrow key for line 2
select the desired ringer volume by pressing the up and down arrow keys or press the down arrow repeatedly till the screen says "ringer off?"
press the save key (right soft key) you will recieve a conformation beep.
you can exit programming mode by pressing the off key.
Jul 20, 2010 | Panasonic KX-TG2740 Cordless Phone
I cant turn up the volume on the second cordless phone. how is this done/
Do you want to turn up the ringer volume or the call volume?
To adjust the volume of the ringer press the UP or DOWN arrow on the pad to bring up the main menu. Move to the 'Handset setup' icon and press OK. Select 'Ringer Setup' and press OK. Now select 'Ringer Volume' and OK. (At this point if you have 2 incoming lines you will need to select the correct line). The display will now show the volume, use the UP and DOWN arrows to adjust the volume. When finished press the OK button, then press the CALL END button to return to the main screen.
Adjusting the call volume is easier. When you are on a call use the UP and DOWN arrows to alter the volume.
I hope this helps.
Jul 19, 2010 | Panasonic (KX-TG1032S) Phone
I just have a question. We have a Uniden 5.8GHz cordless phone. Is there any way to turn the ringer off completely. My elderly mother is living with us and when I'm not home, I would like to be able to...
My phone is a Uniden TCX905 model.
Ringer Volume
Choose from three ringer volume settings (off,
low, and high). With the phone in standby(normal display), use button on center of handset. Press up arrow or down arrow to adjust the ringer volume.
Jan 26, 2010 | Uniden Cordless Phone
Can't hear phone ringing
Adjusting the Ringer Volume (From the Uniden manual)
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
  1. With the phone in standby, press ArrowUp or Arrow Down on the handset or VOLUME + or VOLUME - on the base. The handset or base sounds the ringer at that level.
  2. Use Arrow Up on the handset or VOLUME + on the base to make the ringer volume louder.
  3. Use Arrow Down on the handset or VOLUME - on the base to make it softer or turn it completely off.
  4. When you hear the ringer volume level you want to use, stop pressing keys.
  5. The handset or base will use the new ringer volume starting with the next incoming call.
  6. If you set the ringer volume to Off, the handset or base won’t ring.
  7. Other handsets or base will ring according to their individual settings.
Jan 03, 2010 | Uniden DECT 6.0 Cordless Telephone...
How do you turn up the ringer volum
No way to change ringer type but you can press the arrow keys you use for volume while the phone is ringing and it will raise the volume. ldtsnj.com
Dec 19, 2008 | NEC DTU 8D-2 Corded Phone
How to turn on the ringer
While the phone is not in use, press the up arrow until you get the ringer volume you want.
Jun 28, 2008 | Uniden Cordless Phone
Lands Phones Logo
47 people viewed this question
Top British Telecom Lands Phones Experts
honeybun1986
David Burbee
David Burbee
Are you a British Telecom Lands Phone Expert? Answer questions, earn points and help others
