Question about Dryers
I have a maytag model mde508dayw dryer that just stopped working or turning on. Has power light is on with door open. Light turns off when pushing in button. Dryer still won't turn on when holding in button. Found small magnet inside. Don't know if the magnet was in clothes or came from dryer
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Be sure to reset your circuit breaker it could be a power problem the magnet must have caome out of laundry
Posted on Nov 26, 2013
Jimster
  • 240 Answers
SOURCE: Kenmore Dryer stopped running
This sounds like you may have blown the thermal fuse.  If you turn the dryer around facing the back, remove the screws holding the back panel on (be sure to unplug the pigtail from the wall!!!).  When you remove the back panel, down towards the bottom, you will see a plastic piece (could be long and square, or rounded type.  Do believe it will be the long type) with 2 wires going to it.  It has a screw that holds it it.  This fuse protecs the unit and motor from excess heat and electrical issues.
THERMAL FUSE
Part Number: 3392519
Posted on Oct 14, 2007
watugot
  • 290 Answers
SOURCE: GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Posted on Nov 25, 2007
dinomb
  • 16 Answers
SOURCE: Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
Posted on Mar 30, 2008
docjohn174
  • 943 Answers
SOURCE: Kenmore Dryer 80 series will not turn on.
HI thanks for your question. theres a belt break switch on the dryer so that if the belt breaks it wont allow the dryer to start. check that. thanks the appliance doc. please rate my answer .thanks
Posted on Oct 09, 2008
Testimonial: "excellent, that did the trick"
  • 1122 Answers
SOURCE: kenmore dryer series 70 won't turn on
most of the time it is the door switch that goes bad,also you can check the main fuse inside the dryer on the blower box,and always make sure your dryer vent and wall vent are clear to vent,let me know what you find-mike
Posted on Oct 29, 2008
THE LIGHT WILL NOT COME ON WHEN THE DOOR IS OPENED AND THE DRYER WILL NOT STOP WITH THE DOOR OPEN
The dryer has a switch in the door that is activated when the door is opened/closed, replace this switch or check the connector to it or the wiring.
Oct 25, 2016 | Kenmore Dryers
My Dryer is a Maytag MGD5570, just under 4 years old. The dryer has power (light is on), but when I push the Start Button, nothing happens. I checked the Thermal Fuse with a continuity tester and it is not...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Feb 03, 2011 | Maytag Dryers
My maytag dryer model LDE7304ADE stopped working. I stopped it mid-way through, closed the door, pushed the "on" button and it made a weird noise. I tried again and now it doesn't make any...
Door switch broke???
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 27, 2010 | Maytag Dryers
Dryer just stopped working. the light doesn't even come on when door is open. this is a maytag dryer model hye3460ayw.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jul 06, 2010 | Maytag Dryers
Dryer will not turn on. makes slight buzzing sound when button is pushed. Light goes on, power is on.
Sounds like the motor is gone. Try opening the door and pushing the door swithch inside the dryer door cavity.This may take two people but while holding the door switch, push the start switch and turn the dryer drum at the same time.(in a clock direction) If the dryer starts it means the moter is shot.
Dec 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I have a maytag dryer that has power, but the light doesnt work(but it is not burned out) and the dryer will not start. timer works, can anyone tell me what could be the problem
You probably have a bad door switch. When the door is open, the switch should turn on the light. When the door is closed, the switch should allow the dryer to start.
Jun 15, 2009 | Maytag PYE2300AY Electric Dryer
Maytag dryer sdg515daww stopped working.
I assume this is Gas dryer from the model number having a G.
The door switch may cause the problem. If its not running the dryer thinks the door is open? And the light will also stay off. You can jump around the wires on the door switch and see if it works then if so its switch time.
I don't think a thermal fuse should have anything to do with the light. But that's not a bad idea for quick trouble shooting if a manufacturer would do it. Use a volt meeter to verify the voltage you may have enough for the timer to make noise but not enough to make it turn and the dryer to run.
If there is power then try rotating the tub slightly. The motor may have stuck. Don't turn it too far unless you know which way the drum turns. and try alkways to turn it that direction. Keeps your belts on.
If this helped you please rate me accordingly and good luck.
Mar 13, 2009 | Maytag MDG2706A Gas Dryer
Magtag Electric Dryer
Did you check the breaker closely. Dryers work on 220 volts, usually 30 amps and that means TWO 110 breakers attached together must be good and putting out 110 volts each. One may be burnt or disabeled and the other working. Also check at the  dryer receptacle and make sure you have 220 or more volts.
Mar 11, 2009 | 2001 Yamaha V Star 1100 Classic
Mar 30, 2008 | Dryers
Dryers Logo
71 people viewed this question
Top Dryers Experts
