Question about Nintendo DS Console
Nintendo DS Power On Fault
Hi, I recently replaced the shell on my sons DS after the hinge broke. The machine was working fine with the broken hinge but now it will not power up in the new shell! I have checked the ribbon cable connections a thousand times (Well it seems that many!) and I am now in the mood to take a sledgehammer to it!! When the power on button is pressed the green light coems on for 2 seconds and the bottom screen flashes. Then it turns off. I have searched the internet for a possible solution and so far have had no ideas. Any adivce would be appreciated.
  • kentguy Oct 15, 2007
    Hi and thanks for the reply. I had read that elsewhere and had already checked. I took a gamble last week and ordered a new cable and this w/e I replaced it and thankfully the DS burst into life! Also found that the fuse F2 (near the battery contacts) hadalso blown. A blob of solder fixed this :-)
    Initially when trying out the new cable i found the DS would only stay powered up when I kept the finger on the power button. However I soon realised that the new problem was due to the fact I was inadvertently keeping pressure on the battery at the same time (I had the DS fixed together with no screws at the time andwas holding together with my hands) After replacing all the screws, inc the battery cover, the Ds was fine..
    So the problem was a) the cable had gone faulty and b) the fuse F2 had blown. The latter was probably done when I was fiddling around in my previous attemtps to fix the DS.
  • angela dnn Nov 21, 2008
    When I press the power button on my ds lite it seems to be trying to power up.The top screen flashes on for a second then the ds dies. I have 2 consoles and have tried swapping batteries but it is still the same. Any ideas would be greatly appreciated. Cheers
I have a sd/tf card for my ds when i turn it on it comes up with a message sd/tf card error how can i repair this so all is well
Posted on Aug 21, 2009
Did you see this post? http://forums.cdcovers.cc/archive/index.php?t-184492.html
"When you take apart the unit to repair the top screen you'll notice some ribbon cables. The wide ribbon cables go into the clip only one way so there's no problem with them. There is a really small ribbon cable hidden under the wide one. When you put it back together, you have to push the cable in over top of the clip as opposed to underneath which you would normally think of doing. There is a small groove on top of the clip that the cable fits into perfectly. If you put it in underneath, you won't make a connection and the unit will immediately turn off after you turn it on. It's such an easy mistake to make. Of course I made it on two of them. I didn't pay close enough attention to how I took it apart. Hopefully this helps someone else out there that is going nuts over the same problem."
Posted on Oct 15, 2007
Try to charge it if that dosent work buy a new batery for it.
Posted on Oct 07, 2007
SOURCE:
Broken hinge
Replace the hinges yourself. Just order some from ebay and do it yourself. It's not hard!
Feb 20, 2009 | Nintendo DS Console
Nintendo DS hinge broke
You can find the info for replacing the shell here:
http://site.powergamingparts.com/RepairNdsl.html
Dec 22, 2008 | Nintendo DS Console
Hinge problem
There out it is nothing like a broken hinge only repair solution, the only way to get it repaired is to buy a new replacement shell and replace the broken parts or the whole shell, but some cheap shells wont last and will broke again so read reviews. And if you are not too skilled be careful when replacing or you can get your DS more damaged.
The best is to find a good case broken DS, like water damage etc. to get only the original plastic parts. I should love to have to buy only the broken parts needed but you have to buy the whole thing.
Nov 14, 2008 | Nintendo DS Lite Console
Top screen blank
yes you will need to replace the top lcd screen and the shell hinge
All parts found on ebay
Sep 08, 2008 | Nintendo DS Console
Nintendo ds broken hinge
need to replace the hinge (shell housing) about $25.00
Aug 22, 2008 | Nintendo DS Lite Console
Cracked hinge and chipped corner on DS LITE
yes the shell can be replaced, you can either check ebay or google nintendo ds lite shell housing, i have seen them, doing this yourself is no easy task, there is a repair service on ebay under repair service fix nintendo ds lite
Aug 05, 2008 | Nintendo DS Lite Console
DS hinge
yeah these kind of things can be a pain. we provide this service. if your interested [email protected]
May 19, 2008 | Nintendo DS Console
Broken Hinges
i suggest you buy a replacement shell from ebay and check out the u tube video on disassembling
Feb 26, 2008 | Nintendo DS Lite Console
Green screen
There is a ribbon that connects the top screen of the ds to the motherboard. It is possible that this ribbon became damaged when the hinge broke. A possible fix would be to replace the upper screen. Hope this helps.
Jan 07, 2008 | Nintendo DS Lite Console
Nintendo Lite
if you search ebay they sell new hinges
Nov 27, 2007 | Nintendo DS Lite Console
Nintendo DS Console Logo
530 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
