Toshiba 24z37b dislay problem
The channel display has suddenly appeard on the screen,but when i press the display button it does not go off.it only goes off for a short time if i press another button.also there is a small green light below this display which does the same.any help please.
  • Anonymous Jan 30, 2008
    Channel appears in upper right corner have tried every button and it just won't go!
    Champion:
  • 225 Answers
Check ineternal circuit of tv. may be dry soldero or any part intermiiat operation..check everything in circuit..
Posted on Oct 09, 2007
Buttons are lock on television
hi, try this Power Button Lock
This mode locks the power of the LCD dislay in the ON position.
• Power Button Lock: Press and hold [1] and the down arrow for 10
seconds. If the power button is pressed the message Power Button Locked
will display for 5 seconds. With or without this setting, after a power failure,
your LCD dislay's power will automatically turn ON when power is restored.
• Power Button Unlock: Press and hold [1] and the down arrow again for
10 seconds. hope it helps
regards
shaun
Apr 05, 2014 | ViewSonic N3735W 37 in. LCD TV
I lost the remote to my Toshiba cz27t31. I bought an RCA universal remote. The RCA manual says the tv should be set to channel 1. But I can't change the channel without the remote. So I am SOL! How...
  • You have to set the channel you want as a favorite first and you can do this from the TV. This is why the channels skip as you press up and down. Sometime or another those were someones favorite channels.
  1. Press "MENU" on the TV until "SET UP" appears on the screen.
  2. Now press ^ or v until "FAVORITE CH" appears in purple.
  3. Now press < or > to display the favorite channel FAVORITE CH menu.
  4. You will use < or > to got between "SET and "CLEAR."
  5. So now go to "SET" and press ^ or v until you get to channel 1.
  6. If you want to delete a channel first then select "CLEAR" and then add the channel you wish.
  • What your doing when you push the channel up and down on the TV buttons is going through the favorite channels. So make one of the favorite channels channel 1 and program your remote.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 20, 2011 | Toshiba CZ27T31 27" TV
How do i tune the channels on a toshiba rc3910
Hi
Before tuning the set to auto tune mode, make sure the antenna or cable, whatever may, connected to its appropriate sockets at the back of the set firmly. To make it autotune:
As new services are broadcast, it will be necessary to
re-tune the television in order to view them.
Auto Tuning will completely re-tune the television
and can be used to update the channel list. It is
recommended that Auto Tuning is run periodically to
ensure that all new services are added. All current
channels and settings, i.e. locked channels, will be
lost.
[1] Select the SETUP from the main menu by using
Up or Down buttons. Press OK and Setup menu
will be displayed.
[2] Select the Installation from the Setup menu
by using Up or Down buttons. Press OK and
Installation menu will be displayed.
]3] Select Automatic Channel Scan from the Installation
menu by using Up or Down buttons and press OK.
A screen will appear warning that previous digital
programmes and settings will be deleted. Select Yes
and press OK to continue with the Auto tuning.
The television will start to search for all available
stations.You must allow the television to complete
the search. When the search is complete the Auto
tuning screen will display the total number of
services found.
* After search is completed for digital channels, a
message asking whether to search for analogue
channels appears on the screen
** Press the OK button to search for analogue
channels. The following menu appears on the screen
for analogue channel search
OK.
Jul 10, 2011 | Toshiba Televison & Video
What is combination for entering service menu on LG M1962D?
1. Power off your monitor with POWER button
- Hold MENU button and keep it pressed while pressing POWER button
2. Press MENU button to enter Service menu
3. Change panel type
- Press SET button until PANEL text is yellow and press (-) two times to change it to LPL22W 4L
- Press MENU button to close the Service menu
- Press POWER button to power off your monitor and remove power cable for a minute and plug it in again
Jan 18, 2011 | LG M1962D Monitor
Have a toshiba 27df47 flat screen tv. how do you
First make sure the video inputs are not locked using these instructions:
To set up the video lock:
1. Press MENU, then press or to display the LOCKS menu.
2. Press  or to display the password entering mode.
3. Use the Channel Number buttons (0-9) to enter your password,
then press ENTER. The LOCKS menu appears.
4. Press  or to highlight VIDEO LOCK.
5. Press or to select:
• OFF: Unlocks all video input sources.
Then it appears that choosing Video 2 using the TV/VIDEO button should enable the front input.
An entire manual is avialable here that should closely match your tv:
http://www.tacp.toshiba.com/tacpassets-images/models/27DF46/docs/27DF46_om_E.pdf
Aug 29, 2009 | Toshiba 27DF47 27" TV
Screen blank. appeard to be motherboard.
Remove the AC power and the battery from the system. Press and hold the power button for 20 seconds to properly discharge the unit.
At the bottom of the laptop, find and open the placing of RAM. Unplug each RAM from its bank, clean each RAM Terminals with sand paper very politely. Plug them again in different bank. Lock your placing, now check.
If NO display, then might be something wrong with motherboard. Contact laptop repairing engineer.
Just remember to take your time and don't get nervous while working on the computer. Please report back to the thread with the results of your work.
Best of Luck,
Regards;
Hassan
Aug 04, 2009 | Gateway M-6843 Notebook
Frozen on health and safety screen, without words on bottom "press a button to continue"
Did you download the homebrew channel? or tried to?
if you did then that is probably why it freezes
May 22, 2009 | Nintendo Wii Console
Toshiba 42h82
1. ENTERING TO SERVICE MODE
MUTE
S
(Service mode display)
3) While pressing the MUTE button,
press MENU button on TV set.
2) Press MUTE button
again to keep pressing.
1) Press MUTE button twice
on Remote Control.
2. DISPLAYING THE ADJUSTMENT MENU
1) Press MENU button on TV.
Adjustment mode
Press
Press
Service mode
Item
S Data
3. KEY FUNCTION IN THE SERVICE MODE
The following key entry during display of adjustment menu provides special functions.
Screen adjustment mode ON/OFF: TV (ANT)/VIDEO button (on TV)
Selection of the adjustment items : Channel s/t (on TV or Remote)
Change of the data value : Volume s/t (on TV or Remote)
Adjustment menu mode ON/OFF : MENU button (on TV)
Initialization of the memory (QA02) : RECALL+Channel button on TV (s)
Initialization of the self diagnostic data: RECALL+Channel button on TV (t)
“RCUT” selection : 1 button
“GCUT” selection : 2 button
“BCUT” selection : 3 button
“SCNT” selection : 4 button
“SCOL” selection : 5 button
“TNTC” selection : 6 button
Convergence adj : 7 button
Self diagnostic display : 9 button
Oct 21, 2008 | Televison & Video
Mitsubishi tv
Without the code, you must get an original remote and press the "QV" and the "9" buttons together to unlock the TV.
Oct 16, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
