Question about Radio Shack Pro-82 Scanner
Battery compartment how to convert black battery compartment into one that will charge ni ca batteries. Thanks to anyone who can help
Is the Dewalt DE9108 battery charger suitable for charging Ni-Mh batteries?
  • For Battery Type: Ni-Cd Ni-MH
  • Input Voltage: 110V-240V
  • Smart Charger for Dewalt 7.2V ~ 18V Ni-Cd Ni-Mh Li-ion Battery
  • For Brand: DEWALT
  • Color: Black
  • Brand New: A brand-new, unused, unopened, undamaged item in its original packaging
May 04, 2015 | Dewalt Drills
Tip
Low Power Warning For Full Charged Camera Battieres
<span> <p>I have noticed that, some users asked that, there old cameras always display low power warning for full charged new batteries, or there will be a low power warning after only taking 5-6 pictures.<br /> <p>If you have met this question (I wish not), I'd like to share the solutions.<br /> <p><span> <p>The this problem are so common for <a href="http://www.digital-camera-batteries.net/canon.htm">Canon PowerShot</a> A series cameras when you try to powered your camera by Ni-MH batteries. This is because that, the camera judge the battery is power off by voltage of the battery. And if you use Ni-MH batteries for your camera, the Ni-MH batteries' voltage is lower than the Li-ion ones and close to the camera's judge voltage of low power, so the camera will warn you to change a new battery.<br /> <p>So if you use <a href="http://www.digital-camera-batteries.net">Li-ion camera batteries</a> this questions will be solved simply.<br /> <p>From <a href="http://www.pda-battery.ca/camera-tips/digital-cameras-low-power-warning-for-full-charged-new-batteries/">http://www.pda-battery.ca/camera-tips/digital-cameras-low-power-warning-for-full-charged-new-batteries/</a><br /></span><br /></span>
on Apr 26, 2011 | Cameras
How to CHARGE CORDLESS DRILL
First, you should know your battery is a Ni-CD / NI-Mh or Li-ion battery. If it is a Ni-CD / NI-Mh battery, please fully discharged and fully charged it to prevent "Memory effect".
If it is a Li-ion battery, please charge it before you use it.
Please keep in mind that, please fully charge a battery when you store it. And, charge it again every two months.
If your old battery is dead, you can replace it with a new one. Ryobi Power Tool Battery
Oct 05, 2014 | Drills
How do I re-charge by Black & Decker 12v cordless drill?
Oct 04, 2014 | Black & Decker 12v Cordless Drill/driver...
Just purchased lithium batteries and indicator showing low battery
Are you sure you bought lithium cells? In your camera you should use Ni-MH batteries. The SNB-2512 could be very expensive, but normal Ni-MH from any brand should work fine.
Depending of what you use, always be sure all batteries are the same, charged and suited for your camera. Most of the time even new Ni-CD rechargeable batteries won't work, because the voltage is low, according to NiMH or alkaline batteries.
Always charge NiMH batteries before using them for the first time, or if they have not been used for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera.
Jan 09, 2014 | Samsung S860 Digital Cameras. 8-megapixel...
Low battery on a tk3202 two way radio
Hi Patrick,
Are you using rechargeable Ni-Cad batteries?
If so, buy Li-ion Batteries, Ni-cads have a memory and will recharge from last charge only, rather than fully charge.
Lithium Ion Li-ion batteries don't have memory issues, and therefore will recharge fully.
These are available as rechargeable types so, look for the rechargeable types.
I hope this has been helpful.
Best regards,
Peter
Jan 23, 2013 | Kenwood Tk-2202.tk-3202,tk-3207 Software...
Can you use 18v lithium battery in old 18v drill
Yes you can. On tools, 18 volts is 18 volts. Tools don't 'know' how the power is being created, either by Ni-Cad or Li-Ion means. Chargers are totally different. Most Li-Ion chargers can charge older Ni-Cad and some Ni-MH batteries but older Ni-Cad chargers will charge Li-Ion battery untill they overheat and sometimes start on fire because older chargers can't detect when the Li-Ion batteries are full.
Jan 14, 2013 | Black & Decker 18V Cordless Drill/Driver
Charging mp3 player
If your MP3 has an inbuilt Li-Ion battery (e.g. no compartment for a standard/Ni-MH AAA battery), then connecting the player to your computer will normally charge it - this is the case for the PD-6070 'stick' player. Your player will also indicate that it is being charged (or not charged!) via the battery level/power indicator which is located on the top RHS.
Hope it helps!
Dec 19, 2009 | MyMusix PD-6070 MP3 Player
I can't locate the 12 volt converter in my camper
They hide them under seats, in closets, in side storage compartments.
The unit is often a shoebox sized box with a power cable in and cables to the battery out. OFTEN the fuses are located centurally for the whole trailer.
While properly charging, you should see about 13.5 to 14 volts across the battery.
Aug 29, 2009 | Electrical Supplies
Kodak camera turns off everytime i zooom
This problem is normally due to either weak batteries or corroded battery contacts. First, make sure that you have the correct batteries in the camera (e.g. Ni CD batteries will not function properly if the camera calls for Ni-MH batteries), and that they are fresh/fully charged. If changing/charging the batteries doesn't solve the problem, remove the batteries and wipe the contacts inside the camera with a clean soft cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Once the contacts are clean, remove any specks that may have fallen into the battery compartment during the cleaning, clean the batteries, and reinstall them in the camera.
This cures the problem about 90% of the time.
Aug 25, 2009 | Kodak EASYSHARE M1063 Digital Camera
Radio Shack Pro-82 Scanner Logo
55 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
