Question about Kitchen Appliances - Others
Find testie fly larvae - Kitchen Appliances - Others
Margellones
What are you talking about. Nothing to do with washing machine faults!
Sep 24, 2017 | Washing Machines
Who will believe I have Morgellones Disease so that I can get help?
Locate any eggs, larvae, pupae, and worms that you can. Put them in jars and freeze them (so they don't change). Call an exterminator and show your bugs to them, so they know what they are trying to treat the house for. Find a new doctor, bring your bugs, in the jars, in sealed plastic baggies, to show him/her.
GOOD LUCK!!!
Apr 01, 2017 | Miscellaneous
Dozens of delicate,webby circular creatures hhave suddenly begun to appear on our clothes and other articles which aren't in wardrobes or covered. They appear to have no means of propulsion
if they appear to be grey fuzzy things that tend to gather in clumps in areas , this sounds to be a form of mold , and yes mold spores do use the air as there form of propulsion , and it only takes a few to start a colony , once they start there hard to stop from growing
Feb 03, 2017 | The Computers & Internet
What eats slugs
Hedgehogs, newts, toads and some birds, such as song thrushes, love to eat slugs and snails, so it is a great idea to attract these beneficial creatures into your garden. Probably the best way to attract them into the garden is to make a pond or boggy area, which they will use for drinking or as a place of refuge.
WHICH NATIVE ANIMALS EAT SLUGS AND SNAILS
Nov 24, 2016 | Miscellaneous
What larvae hatched in a closed kitchen container? There are hundreds of .75 inch long black things crawling quickly.
Fly spray or household bleach will help. Probably roaches or some thing from an unfinished meal that a fly has had a go at.
Oct 27, 2014 | Cars & Trucks
What do jellyfish eat
Some eat other jellyfish, other types eat plankton, or small fish, or larvae of crustaceans
Jun 23, 2014 | Toys
Vivitar 40 piece microscope set shrimp hatchery instructions
1. To hatch the eggs, first prepare a brine solution. Pour the entire contents of a vial containing sea salt into a quart of
tap water. Add the brine shrimp eggs into the
solution. Allow the solution to stand at room
temperature (70 - 80F or 21 - 26C) for 24
to 48 hours and the eggs will hatch into nauplius larvae (this is the first stage of development after leaving the eggs).
2. Place some of the larvae into one of the compartments of the shrimp hatchery .
3. Place some fresh brine solution in another
compartment. Add a small amount of yeast to
this new solution. Then, using the eyedropper, transfer some of the larvae into this compartment as well. The yeast will
serve as food and produce oxygen for the larvae as they develop into maturity. Without food and oxygen, the shrimp cannot develop
and will die. Mature brine shrimp are known
as Artemia Salina.
Note: Using an eyedropper with just the right
pressure to get a desired amount of liquid
onto a slide can be harder than it looks. Take
out a clean slide and practice squeezing a
drop of water onto the slide until you feel
comfortable that you can control the size of
the drop that you're squeezing out.
4. Observe the life cycle of the shrimp as they
grow: the dried eggs, the hatching eggs, the
developing larvae, and finally, the mature
shrimp.
5. The mature shrimp may be fed to fish in an
aquarium if you so wish. However, first
remove the shrimp from the brine solution
and place them into fresh water. An increase
in salt may harm the fish in the aquarium.
NOTE: Use the color filter especially when looking at clear or dim specimens.
Jan 20, 2013 | Vivitar 40 Piece Microscope Set
Help. I shut down my refrigerator when I moved. When I opened the door, I found the refrigerator full of maggots. I used clorox to clean it but I heard there could be eggs that I could not reach. Is...
Maggots are the larvae that have hatched from insect eggs. Yes, there might be eggs somewhere still in your refrigerator. I would suggest that you locate an insecticide (a bomb type perhaps) and set it off in your refrigerator BUT UNPLUG THE REFRIGERATOR FIRST. Close the doors and let the refrigerator stand for a week. After that time, you will need to carefully wipe down all surfaces with a mild soap solutions. Then rinse well. If there are still lingering odors you can wipe again with baking soda solution or you can place activated charcoal in the refrigerator to absorb the pesticide odor. I had this same thing happen in a foods lab with a microwave oven. I used this procedure and never had maggots again. You don't have to be a dirty person to have problems like these! I hope this helps. If it does, please come back to Fixya and rate my advice!
Jul 28, 2011 | Refrigerators
I have discovered small white larvae (probably moth larvae) creeping out of the Panasonic bread machine (SD-253) when it is on (no activity when it is off) and I don't know whether the eggs were laid in...
I would recommend running a sacrifice loaf through and letting the cook cycle finish. It would be very surprising if any moth larvae could survive the ambient heat. Then give the bread to some ducks or inlaws:) Those areas of the machine are not really intended to be opened, so that is my best advice.
Bon apetite!
Farmerbear
Sep 10, 2010 | Panasonic Kitchen Appliances - Others
Trouble changing wiper blades on 2005 Dodge Caravan
Very simple solution, indeed, as expected. RainX wiper blades come with a small device designed to replace the snapping mechanism on the existing wiper blade. Once you get the existing mechanism off (which can be a little testy), you snap the new in place and it fits perfectly. Rear blade just requires a little patience. Once you get it off (which can also be a little testy), the new one snaps in place perfectly. Although I was able to solve my own problem, this is a really nice service that you provide, thanks.
Mar 18, 2009 | 2005 Dodge Caravan
Kitchen Appliances - Others Logo
79 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
