Question about Hitachi P50H401 50 in. Plasma HDTV
Everything in system works except video on DVD player, get message no sync signal
  • Hitachi Master
  • 3,904 Answers
Usually when to devices like this won't sync is when they are not compatible on the resolution side.(ex. dvd can display 720 p and the tv cannot do anything below 1080 p. I would say that unless you have a new commercial plasma it is the opposite problem. The DVD won't go backwards to match the TV. Check that the DVD Works on another set and vice versa and repost what you find out.
Posted on Nov 18, 2013
Testimonial: "There hasn't been a change in the equipment. None of the components have changed including a new Logitech Harmony Remote. For no reason I can think of, I lost video when I tried to play DVDs. The only change I can think of is that I updated my Mac OS to Lion 10-7"
Car DVD Player Blue Screen with "Rear No Signal" message
Most likely its the ignition wire.. That 12 volt line let's it know when the switch is turned.. If the radio is cutting on it may simply be interfering either that or its too much with the control wire this is why its better to get the one in the dash and run the video moniter off the aux video out instead of trying to run 2 separate units
Dec 30, 2014 | Car Audio & Video
Memorex MVUC821 TV/DVD. Everything works except the TV.
Just bought the Memorex MVUC821 & the DVD Player will not open using the remote or front panel button!!!
Mar 23, 2010 | Memorex MVUC821 Player
Kenwood DDX512 problem with IPOD
I had the same problem. Updating the firmware for the Kenwood resolved it.
Jun 25, 2009 | Kenwood DDX-512 Car DVD Player
S-video connection of a DVD to 40" sony bravia
I need to know if you see a no signal message on tv or just a blank screen. Please provide this information so that I can assist you.
Thanks,
Sai.
Feb 01, 2009 | Sharp DVMX1U DVD Player
How to disable the vcr on emerson dvd vcr combo?
Hello sjz4923,
I understand your frustration, however you are not going to want to hear this so what I'll do is just come out and explain why what you are asking is almost impossible, and I'll offer a solution that will help you possibly repair this problem.
The term tv/dvd/vcr combo is a misnomer. The term implies that there are three components in this TV set (TV, VCR, DVD) when in reality there are 1 and 1/2 components in this unit. The TV section of this set is actually the VCR section (RF tuner, IF processor, Video and audio, sync section) what is added to make the TV part of this is the deflection, and High voltage section to power and control the signal to the CRT. As far as the DVD section this basically is a DVD player without the video output, but rather the analog video plugs into the VCR video out. You do have aux ports for DVD video out but these may or may not be amplified video. In a nut shell The TV and the VCR are the same electronics except for the deflection and HV circuits, and the DVD and VCR are separate except for the audio and video main inputs.
So what you are asking is almost impossible since the TV and VCR are the circuit.
Now to repair your problem. What is happening is that the signal that the circuit uses to tell that the VCR carriage is connected properly is not being sensed, what this could mean is the the signal processor is bad or the position control is malfunctioning. The first thing I would do is to make sure that the position control (a wheel on the circuit board which the carriage sets on top of and a peg from the carriage sets into a hole on the wheel) is in sync with the carriage wheel.
Also if you have the equipment you can check the sync signal created by the control and compare it with the signal on the schematic of the TV.
Now having said all of this, if you don't have a background in electronics I would suggest that you get a TV repair technician to work on this problem.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 21, 2009 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Waiting for input signal
It's a protected video. The VRD-MC5 will not burn a VHS or input that has been protected.
Jan 09, 2008 | Sony DVDirect VRD-MC3 DVD Recorder
Atapi pioneer dvd-rom 115
you need to install a dvd player in orfer to play dvd. you can download the software total video player, and many others
Dec 19, 2007 | Computers & Internet
Jumping Picture
Does the Sony surround upscale the signal from normal RCA to Component video? If so I have found that sometimes there can be signal sync issue. Meaning the signal that the component video convertor (inside the surround sound unit) sometimes struggles to give a clean component video signal. The TV then struggles to filter the signal correctly resulting in a jumping picture. Try plugging the DVD video only (yellow RCA lead) straight into the plasma and see what happens. You can also try playing with the signal frequency of the plasma, from 50 - 60hz. This will found in the menu of the plasma. Hope this helps. ST
Oct 29, 2007 | Sony DVP-NS530 DVD Player
NO VIDEO
It sounds like the video signal is being routed to a different out put. Search the menu for "Source" kinds of settings. Often you will have Vid 1 and 2 and maybe HDMI 1 &2 etc. Try what looks right and keep trying all combinations (usually less than 6). Take your time, it often takes them numerous seconds to recognize the signal. The fact you see the settings means the Video is working if it just had the signal. Also, if there is any wiring involved, check the cables and maybe swap them for known good ones if possible.
May 20, 2017 | Pyle PLDINTV7 Car DVD Player
Hitachi P50H401 50 in. Plasma HDTV Logo
67 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
