Question about Brother Mfc-j270w All-in-one Inkjet Printer, Perfect Working Condition
Printer will not feed glossy card stock. Images will print on regular paper but printer won't feed/print glossy card stock.
    Habit-Forming:
  • 135 Answers
TRY TO CLEAN PICKUP ROLLER WITH IP ALCOHOL
Posted on Nov 19, 2013
4 Suggested Answers
bob_computer
  • 3153 Answers
SOURCE: The printer will not pull card stock paper
Usually the stock is too thick to process properly.
Go to a lighter stock or buy a more robust printer if you are going to do a lot of that type of work
Posted on Aug 08, 2009
jaylex
  • 417 Answers
SOURCE: I am trying to print double-sided copy on card stock
HI there sounds like there is a blockage in the duplex area that is not holding any sensors down. Check the duplex area for torn paper, failing this it maybe a sensor problem which will then need a engineer.
Hope this helps
Thanks J
Posted on Jan 30, 2008
Ajkill
  • 2035 Answers
SOURCE: brother laser printer wont print
If there printer is not able to print on card stock then check the recommend
card stock paper thickness, if the printer works with normal paper but not card stock then there is problem in the card stock and by using this paper may also damage the rollers on the printer and make the printer useless ...
Good luck...
Posted on Feb 09, 2009
Samsung CLP 510 - won't print on photo paper.
Have you changeed the PAPER type to (specialty or card stock) this always work for me. Your printer will have these setting
Aug 31, 2008 | Samsung Office Equipment & Supplies
Own three CP3525dn's (purchased new). Two have recently begun jamming [fuser wrap] when printing labels. If it doesn't jam then the paper usually "dog ears" coming out. New fuser did not...
Over time, printing labels builds up a light residue of the adhesive (due to heat pressing) used on the labels in the paper path. A thorough cleaning of all paper path parts with alcohol prep pads, or Glass Plus and quality paper towels, will reduce this gum build up.
You should regularly print standard paper jobs on a laser printer that will be printing labels. Rule of thumb is 4:1 - four sheets of regular paper print for each sheet of labels printed. This helps keep the adhesive cleaned out of the paper path.
Patience and a lot of scrubbing should do the trick, though you may have to install a printer maintenance kit early given the issues noted. Printing labels cuts maintenance kit duration in half, at a minimum.
Jul 06, 2011 | HP CP3525DN Color LaserJet Printer
When i got to print it does not feed in
could be your feeder, or it does not like the card stock, try feeding regular paper if the regular paper feeds then the stock your using might be to thick for the unit.
Let me know ether way
please do leave ratigns and fededback
May 08, 2010 | Canon PIXMA MP150 All-In-One InkJet...
HP 6940 rejects 8.5" X 11" glossy photo paper for printing
Is it a front feed and then the output is also goes out to the front? Coz if your glossy paper is to tough that it will not bend easily, this is what you get. Why not try to use a thin and more flexing photo paper if the outcome will be the same.
Usually when using thick paper the most desirable printer should be a top feed-front output with almost less than 90 degree bend.
Apr 24, 2009 | HP Deskjet 6940 InkJet Printer
Brother laser printer wont print on cardstock My brother printer won't feed teh card stock paper. It used to work but now it won't feed it, normal paper works fine. Even if i nudge the card stock paper,...
Good luck...
Feb 09, 2009 | Brother MFC-5840CN All-In-One InkJet...
HP 5610v states 'paper jam' and there isn't one - how to reset?
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 08, 2009 | HP Officejet 5610 All-In-One InkJet...
HP C4280 incorrect paper feed
Check your printer's capability.
Buy the card stock they recommend.
If all else fails, print on plain and take card stock to a copy shop and have them do it for you.
Walking there beats going nuts over stupid software or hardware problems
Dec 16, 2008 | HP PhotoSmart C4280 Laser Printer
My Printer works fine... except it won't feed business cards or card stock
You cant fix this because brother printers are limited to paper:
paper that weights more than 200g wont run through the paper feeder.
Mar 19, 2008 | Brother MFC 420CN All-In-One InkJet...
2600N: glossy paper
Is this HP glossy paper? I would think that laser printers have a hard enough time handling any glossy paper as it is because you run the risk of the gloss burning as the paper goes through the printer so you might have to use the paper recommended by HP.
Here are the specs of the accepted paper.
http://shopping.yahoo.com/p:HP%20Color%20LaserJet%202600n%20Laser%20Printer:1991823169:page=details
Good Luck!
Hope this helps!
Mar 07, 2008 | HP Color LaserJet 2600n Printer
Brother Mfc-j270w All-in-one Inkjet Printer, Perfect Working Condition Logo
91 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
