Question about Amana ALW480DA Top Load Washer
Amana washer at final rinse and stop want continue
2 Suggested Answers
tomcassidy84
  • 1585 Answers
SOURCE: Amana front load washer works fine until the last rinse. It won't stop filling before it goes to rinse.
check pressour switch
Posted on Apr 16, 2015
Amana washer will not go through rinse cycle
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
Mar 28, 2015 | Amana Washing Machines
How to add fabric softner to the amana washer with locking lid
Check and see if there is a cup in the top of the agitator. Some machines have you put it there, turning back and forth during wash doesn't bother it, but the spin to empty the wash water causes the softener to go out through slots in the top of the cup and be held in the agitator. when it stops the softener drains into the tub, ready for the rinse cycle.
May 30, 2012 | Amana Washing Machines
SOAP NOT RINSING OUT OF FINAL RINSE. CHECKED DRAIN NO OVER FLOW OF WATER THIS IS A WHIRLPOOL NEW WASHER
sounds like a case of over soaping especially if your water is soft. this is usually a front loader problem but..
Epsom salts added to the final rinse usually does the trick as it breaks down the oxygen loaded foam.
Very common problem in Launderettes.
Feb 21, 2010 | Amana ALW480DA Top Load Washer
Final spin /rinse cycle won"t stop
It's usually a control board problem. sorry for the bad news :(
Jul 07, 2009 | Maytag EPIC MFW9700S Front Load Washer
Washer will not advance in the rinse cycle,water just runs continuely.
check the drain hose it should be only 6 to 8 inch in your drain line if drain hose is all the way in the drain line correct it and you will be fine.
May 21, 2009 | Washing Machines
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Smoking washer Amana NAV8800AWW
Ok, that's a different scenario. Generally, when a washer is agitating and develops an overload that stalls or overheats the motor, the problem could be caused by:
1. Too many clothes for the amount of water level selected. If clothes don't have enough water to circulate in properly, it can put excess pressure on the agitator which transfers to the gearcase, drive belt, and finally the motor. The motor is thermally protected and stops running until it cools down, then it will try to restart. In the process the drive belt could burn slightly to completely,so you may want to inspect the drive belt for burned areas.
2. Transmission malfunction, where something inside the transmission breaks due to an overload and jams a gear. End results can be the same as above.
I suspect a clothes overload may have caused the problem and once the overload is alleviated, the washer should operate normlly if the belt didn't burn,
May 27, 2008 | Amana NAV8800E Top Load Washer
Washer stops dead immediately prior to final rinse
this sounds like the conditioner solenoid, this is the cold water valve that works as the final rinse is suppose to work, just before the final spin, check valve connections for open circuit electrically, work safe unplug from power supply first, if i have helped please rate me
Oct 02, 2007 | Candy AQUA1000T Front Load
Amana ALW480DA Top Load Washer Logo
23 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
