Question about HP 15C Scientific Calculator
Clear the grad mode on the screen - HP 15C Scientific Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • HP Master
  • 102,366 Answers
Press g DEG to switch to degrees or g RAD to switch to radians.
Posted on Jun 02, 2014
Deg rad grad
You don't.
Angles can be measured using three different units: degrees (360 degrees in a circle), radians (2pi radians in a circle), or grads (400 grads in a circle).
Pressing the DRG key cycles through the three modes. No matter which mode you select, one of the annunciators will appear on the screen to indicate the current mode.
Dec 09, 2013 | Texas Instruments TI-30XA Calculator
What does DEG on screen of TI-30Xa mean
It means your calculator is set to degrees mode. Angles can be measured using three different units: degrees (360 degrees in a circle), radians (2pi radians in a circle), or grads (400 grads in a circle).
Dec 07, 2013 | Texas Instruments TI-30XA Calculator
How can I clear my screen from 0,0000 GRAD to get 00.0000 ENG?
To change the angular mode, press the blue g key and then one of the 7, 8, or 9 keys to select Degrees, Radians, or Grads. To change the display mode, press the yellow f key, then one of the 7, 8, or 9 keys to select Fix, Sci, or Eng, followed by a digit to select the desired number of digits after the decimal point.
Dec 19, 2012 | HP 15C Scientific Calculator
On my TI 30 XA, I can not get it out of Degree mode.
Why do you want to get out od Degree mode. If you are doing trigonometric calculations, the angle unit is pertinent. If you are not doing trigonometry, it is irrelevant. You say you can cycle through DEG, RAD, GRAD. That is the way to set the angle unit.
However, there will always be an indicator on the screen (DEG, RAD, or GRAD).
Nov 18, 2011 | Texas Instruments TI-30XA Calculator
Activating the grad function?
Turn calculator ON.
If you see no icons, press MENU then 1: to enter the RUN screen. Press the SHIFT MODE key combination to enter (SetUp). Use down arrow to highlight the line Angle. Press the F3: key to activate the GRAD angle unit. Press EXIt to return to the RUN screen.
Sep 19, 2011 | Casio FX-9750GPlus Calculator
DEG is on the screen. How do I clear it?
The calculator has three angular modes: Degrees, Radians, and Grads. You're going to be in one of those modes at all times, and the calculator will light the appropriate indicator.
You can press the DRG key to cycle through the three modes, but one of those indicators will appear on the screen at all times.
Sep 14, 2010 | Texas Instruments TI-30XA Calculator
I need to change to mode to degress
Under the screen you can see atable of values at the right of which is written MODE followed by a small arrow.
If you want to set the degree as angle unit, you press the MODE key followed by 4 (as seen in the table I was referring to).
Similarly, if you want to set RAD as the angle unit you press MODE then 5; and MODE then 6 for GRAD.
However if you just want to convert a number displayed on the screen in RADs or GRADs into DEGs , you press SHIFT then MODE then 4. your number should be converted from the unit it was expressed in into degrees.
Same thing if you want to convert into RADs: SHIFT then MODE then 5.
Hope it helps.
Aug 02, 2009 | Casio FX-115ES Scientific Calculator
Problem with Casio FX 260 Calculator
Read the screen capture about the MODES of this calculators. DEG,RAD, and GRAD remind the user that the angle units in trigonometric function calculations and coordinate conversions are in degrees, radians or grads. They have nothing to do with the other calculations you are doing.
You can only remove DEG by changing the angle unit to RADians or GRADs. In so doing, the new unit indicator (RAD, GRAD) will be displayed instead. There is no point worrying about the angle unit indicator unless you are performing coordinate conversions or calculating trigonometric functions or the inverse trigonometric functions.
MODE 9 cancels the FIX display format: decimal are displayed with a fixed number of decimal places (set by the user). After this key sequence the decimal display format reverts to NORM(al).
Dec 03, 2008 | Casio FX-260 Calculator
How do i do "regular" math, calculator stuck on GRAD/DRG...
Pressing the DRG key toggles through using degrees, radians, grads
Instruction booklet page 9 explains...
http://education.ti.com/educationportal/downloadcenter/SoftwareList.do?website=US&tabId=2&paneId=18#27
Aug 07, 2008 | Texas Instruments TI-30XA Calculator
PROBLEM W/ CASIO fx-260 SOLAR
Sorry, but I think you misunderstood what the manual says. See the not on the screen capture.
True the sentence is not very clear, but what it means is the following:
All modes (except COMP) will have an indicator (with the appropriate labeling) displayed. When in COMP mode the COMP indicator is not displayed.
The truth of the matter is that computation- wise you have two MODES only : the general COMPutational mode and the Standard Deviation (SD Statistics) MODE. These two are incompatible because the key layout is different.
But to compute trig functions
  1. calculator must not be in SD mode, hence it is in COMP mode
  2. An angle unit must be shown on display.
Jun 04, 2008 | Casio FX-260 Calculator
HP 15C Scientific Calculator Logo
122 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
