Question about Whirlpool Refrigerators
Cleaning the base under the slide out tray.
Model GT22DM - has a slide out tray in the freezer. It is attached to a base-with holes in it. The holes allow all matter of crumbs and debris to accumulate under it. How can I remove the base to clean under it?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 88 Answers
Pull tray part way out then lift up Cheers
Posted on Dec 13, 2013
  • 1122 Answers
SOURCE: drip/moisture tray inside base of kitchenaid superba refridgerator
need mor info,is there water in the bottom of your frig. or freezer,let me know more-mike
Posted on Oct 12, 2008
SOURCE: Cleaning drip tray.
I have just removed the drip tray from my fridge freezer and it was relatively easy.
Do not remove the compressor unit.
The drip tray is held in place by a metal clasp which is welded to the top of the compressor. The clasp is a flat piece of metal which must physically twisted to align with the key way in the plastic drip tray. I used thin pair of pliers to grip the clasp and twist it clockwise to line up with the tray key way. The tray then has to be carefully manouvred off the compressor so as not to cause damage or spill it foul smelling contents. This I managed to achieve fairly easily.
Clean out and install then twist the clasp to clamp the tray into position. I don't know what would happen if you didnt lock the tray back in position as it does not seem capable of falling off on its own and it would be easier to remove next time.
Hope this makes sense
Mark
Posted on Mar 05, 2009
SOURCE: How to place back the freezer trays for E522B refrigerator
Make sure to return the correct tray/bin in the right runners. All three freezer trays have different designs on each side, which means that the top tray must be returned to the top tray and cannot be interchanged with the second tray. What happened in my case is, I was trying to put the 2nd tray to the first tray that's why I had difficulty replacing it back and would not fit.
Posted on Mar 23, 2009
  • 78 Answers
SOURCE: Kenmore refrig model 10671182101 water leaking in the interior
iced up drain , clean and defrost drain
Posted on May 03, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Cleaning the base of a GE Profile with a bottom freezer drawer.
Click Here=> PDS22MHR and go to page 11 in the PDF. I believe that will answer your questions of removal. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Posted on Mar 19, 2010
Where can I access the defrost drain hole in my Kenmore model 253.74879404 Refrigerator? Disassembling the freezer did not work.
I've used used a compressor for that drain hole at the back of the fridge. A hanger wire will work too. I've never tried it but maybe a can of compressed air might work also.
The water drain line is plugged and that little catch tray is overflowing. That's why you're ending up with water under your bins inside the fridge. The problem is not in the freezer or else you'd have a skating rink on the floor of the freezer.
I don't recognize the photos exactly but they're all the same principle. Take everything out of the fridge , including the racks. It's far easier than o find the screws and disassemble the drain "catchall".
Good luck.
Dec 18, 2014 | Kenmore Refrigerators
Dripping water
Mine had the same problem today. I found the drip tray under the screwed on panels in the freezer was full.
There is an evaporative tray above the compressor in back, and feeding that was a drain pipe that was blocked with crud. Removing and cleaning the cap made it flow freely again. Hopefully that fixes it.
Jan 23, 2014 | Sanyo SR-1030W Top Freezer Refrigerator
Don't have the directions to put evenflo exersaucer together, need help. Is there somewhere I can get the directions? reg. number 07T-0538604
Instructions
    • 1 Place the large, round base on the floor. The outwardly curving edge should be facing downward.
    • 2 Attach the three pedestals to the base. To do so, insert your finger into each pedestal and loop the spring within around the hook found on the base in the appropriate holes. Insert the three plastic tabs on each pedestal into the base, locking them into place.
    • 3 Press the wider end of a lower leg assembly onto each pedestal piece. By wiggling the lower leg assembly side to side, you will eventually snap the pieces into place.
    • 4 Hold the seat ring in your lap with the open edge facing upward. Press each of the six wheels into the wheel holders around the edge of the seat ring. Each wheel will snap into place when positioned correctly.
    • 5 Insert the cloth seat into the seat ring, aligning the diamond on the cloth seat with the triangle on the seat ring. Each plastic tab lining the edge of the cloth seat attaches to a peg on the seat ring. Snap these connections into place.
    • 6 Hold the Exersaucer tray on its side and press the seat ring into the center. Once the seat ring snaps into place, it should be able to spin in place.
    • 7 Attach the three spring caps to the Exersaucer tray. These spring caps cover the three large holes in your tray, and are attached by a firm clockwise twist.
    • 8 Attach the upper leg assemblies to the upper leg crowns. These crowns act as the "socket" and the upper leg assemblies act as the "ball." By pressing them together with a click, the upper leg assemblies can twist and rotate in place.
    • 9 Turn the tray upside down and press each upper leg crown base into the round holes in the tray with a firm twist. Each upper leg crown features a height adjustment hole, which will face outward when properly attached.
    • 10 Turn over the tray so that the upper leg assemblies are facing downward. Insert each upper leg assembly into a lower leg assembly, being sure to pull away the height adjustment tab to allow the assemblies to slide together.
    • 11 Press each toy into its respective port on the surface of the tray. The toys each have a distinct base, which clicks into the correspondingly shaped tray port
May 10, 2011 | Toys
Water dripping from freezer into refrigerator
Just fixed my refrigerator last week that was doing the same thing. Water was dripping from the back top of the refrigerator and it was the drainage line in the freezer had frozen up and was plugged. Emptied the freezer and removed the bottom panel from the freezer and found large layer of ice. Turned freezer off and let everything melt. Then the hole in the back bottom of the freezer on the metal tray became visable. Contined to thaw until warm water would drain into the tray under the freezer. Was not hard at all and much better not cleaning up the water dripping all the time.
Jun 07, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Taking out trays for cleaning
Usually the holes are deeper than they appear in the side walls. Lift the shelves just a hair and then push them left...the right side should now be outside the hole and able to be moved upward until left side clears.
Reverse this process to reinsert. Good Luck.
Aug 21, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Water is dripping from the freezer into the fridge from above. Ice has formed under sliding freezer tray.( Whirlpool 21- Model# ET21DKXDN04 )
Sounds like the water produced from defrost cycle is the problem. There is a tube designed to carry the water to the compressor compartment where it evaporates. you will need to onclog the tube by taking the back off freezer compartment to access .Under the condensor is a tray that collects the water. There you should see the hole that needs to be blown out. Compressed air works great. Hope this helps.
Jul 28, 2009 | Refrigerators
Ice forming at base of freezer part
you need to urinate on the tray amanda it may smell but will solve the ice prob as the urine is heated
May 26, 2009 | Siemens Freezers
Water pooling in base of fridge
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 08, 2009 | Engel 43 Qt.Portable Freezer.
Kenmore 54246400 water on floor - from inside bottom freezer
check the drain hole in the freezer. must likely it is plugged. use hotwater and towel and slowly melt the ice to open the hole. also check the hose that leads to the drain pan. ((back or the buttom of the freg.) it may also need cleaning. use a soft wire (electric wire with small piece of towel tapped to the front).
appricated if you can rate the answer
Oct 15, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
52 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
