Question about Element Electronics Element 40" LED 1080P 60HZ HDTV - Black ELEFT405
Can't turn on spdif on element tv
Can access the menu for audio but the spdif is not accessable to turn on. the cursor just skips over it
How do I fix cursor. When I use my cursor some times it want respond to the location I need it to go.How can I fix it?
Instructions
    • 1 Close all application windows and restart the laptop. This will shut down any background processes that might be affecting your cursor. Rebooting often remedies cursor skipping problems.
    • 2 Run antivirus software to confirm that your misbehaving cursor is not caused by malware. If the cursor has changed to an unfamiliar shape without you initiating the change, your system could be infected by a virus or you might have installed unstable software. Run an antivirus scan and remove suspicious files and programs from your laptop.
    • 3 Adjust your touchpad's settings. In Windows, open "Control Panel," click on "Mouse" and then click "Tapping." On a Mac, access "Trackpad" and "System Preferences." Lower the tracking speed or sensitivity so that if you are accidentally touching the touchpad while typing, you are less likely to cause the cursor to skip. Save your new settings.
Oct 01, 2014 | Toshiba Computers & Internet
My laptop has a black screen with a blinking cursor
Blinking Cursor b> Laptops, especially models with a touchpad, occasionally experience issues with a skipping cursor. The cursor on the screen may skip or jump when you are using it or even when you are just typing and not actually using the cursor. This can be especially annoying when playing games or typing. Adjusting the sensitivity of your touchpad may remedy the problem.
Close all application windows and restart the laptop. This will shut down any background processes that might be affecting your cursor. Rebooting often remedies cursor skipping problems. Run antivirus software to confirm that your misbehaving cursor is not caused by malware. If the cursor has changed to an unfamiliar shape without you initiating the change, your system could be infected by a virus or you might have installed unstable software. Run an antivirus scan and remove suspicious files and programs from your laptop. Adjust your touchpad's settings. In Windows, open "Control Panel," click on "Mouse" and then click "Tapping." On a Mac, access "Trackpad" and "System Preferences." Lower the tracking speed or sensitivity so that if you are accidentally touching the touchpad while typing, you are less likely to cause the cursor to skip. Save your new settings.
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html microsoft security essentials your operating system must be registered http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information malware protection http://100-downloads.com/download.php?p=615 windows xp microsoft security essentials http://100-downloads.com/download.php?p=614 windows 7 microsoft security essentials b> All freeware
Mar 01, 2013 | HEWLETT-PACKARD Hewlett Packard G72B63NR...
Can't find the menu
if you pause the song that is playing the symbol next to the battery should change to a folder. when it does you press the mode button and it will bring up a menu called music mode. if select local folder at the top you can access all your music or delete the current song or delete all the songs
Jan 23, 2013 | GPX MW252S - 4GB MP3/WMA Digital Audio...
For some reason the piicture seems to have changed to a more of a green shade
u need to access the ad9883 sub menu in the ez main menu and enter the values as original and the colour will balance i have the same problem but am unable to activate the ad9883 sub menu cos the scoll/ cursor pointer cant select it for its not highlighted in white like the others hence the pointer skips it, but once u get in u will be able to balance the colour by keying the right values
Nov 13, 2010 | LG RE-44SZ21RD 44" Analog Television
Need to selct english on the ps2 box itself,its in asain can u help
Remove any disk and close the disk tray. Turn off your system and let it sit for a few seconds before turning it back on. Select the "Language" option from the main menu to open the language menu.
Move the cursor up using the directional pad on your controller until you get to "Language Select." Push the X button repeatedly until it lists "ENGLISH." This changes the audio settings from English to Spanish.
Scroll down to the "Subtitles" option in the language menu and change this setting to Spanish as well. The subtitles will appear in ENGLISH at the bottom of the screen every time a character in the game speaks. If you wish, you can skip this step and rely only on the audio settings.
Press the Circle button on your controller to move back to the main menu, which will save the settings. Select the correct time and date setting for your time zone, if the system asks you to do so. Push the Circle button again to access the main menu.
Place a PS2 game into your console and let the game load. You should now have ENGLISH, settings on your PS2, including subtitles.
May 05, 2010 | Sony PlayStation 2 (PS2) Console
Original remote lost. have universal remote. cannot program TV
On the right hand side of this television there are panel buttons. It appears that your son in law knocked the tv out of the correct input. Press the input button in order to cycle through the 5 inputs. Typically pressing the input button on the side panel of a television and pressing it again and again and again will make it change inputs. Universally the buttons on the tv panel function as follows: Channel up moves the cursor up. Channel down moves the cursor down. Volume + moves the cursor right. Volume - moves the cursor left.
Hope this helps
Apr 28, 2010 | JVC LT-42E478 42 in. LCD Television
I wish to create my own message on the answer-phone.
The easiest way to gain access into an answering machine is to use it's preset access code. This is the access code set at default by the vendor on the given device. The best thing about this is that most users don't bother to change the access code to their device, if they even know that they have such a feature. Even worse yet, some of the manuals given for the device by it's vendor even tells the user that changing the access code is optional, not necessary. So of course since most people only do what they feel is necessary, these access codes are many times if not usually set at default. So what I'm going to do for you now is list the different popular vendors out there, and include their preset access codes, how to use them, and controls to use after gaining access. Keep in mind that if there is no model number beside the vendor, then that means that the information given works on most of their models. Likewise of course if there is a model identification beside the vendor name (placed in parenthesis) then that of course means that the information provided is model dependant. So let's begin, shall we?
1) AT&T - preset access code is 10 - when the answering machine picks up punch in the access code
7 - play messages
6 - play new messages
# - stop/pause
2 - repeat message
5 - skip message
4* - record announcement (push # to end recording)
41 - play announcement
* - record memo
33 - delete all messages
3 - delete selected
0 - turn system on
88 - turn system off
99 - change remote code
2) BellSouth - preset access code is 555, Mailbox 1: 555, 2: 666, 3: 777, 4: 888 - when the machine picks up hit * and then punch in the access code
0 - help (use this to get the commands available)
3) Freestyle - preset access code is 000 - when the machine picks up push in the D button and then punch in the access code
2 - play all messages
3 - play new messages
4 - skip back during messages
5 - delete during messages
6 - skip forward during messages
8 - play outgoing message
9 - record new outgoing message
0 - set answering machine on/off
1 - hear main menu
4) Vtech (VT650) - preset access code is 0000 - enter access code during announcement
#4 - repeat message
#5 - pause message
#6 - skip to next message
#7 - delete message
#8 - skip backwards
#9 - stop/exit any function
*8 - room monitor
5) Vtech (VT2650/VT2468) - preset access code is 50 - enter access code during announcement
#4 - repeat message
#6 - skips message
#5 - stops
#9 - delete message
#7 - review announcement (after beep press 7 to record an announcement and use #5 to stop)
6) Vtech (HK5886) - preset access code is 48 - enter access code during announcement
#1,2,3 - play new or old messages
#4 - repeat message
#6 - skip message
#5 - stop
#9 - delete message
7) Olympia (OL2410) - preset access code is 0000 - enter access code during accouncement
1,2,3 - select and play messages
4 - repeat message
44 - ignore message
6 - play next message
7 - delete current message
8 - record memo
9 - record announce (5 to stop)
0 - toggle answer on/off
* - play help menu
8) Doro - preset access code is 321 - enter access code right after outgoing message has played (or during)
1 - repeat/skip to previous message
2 - play/pause message
3 - skip to next message
4 - play current outgoing message
5 - record new outgoing message
6 - stop
7 - erase current message
8 - switch off answering machine
9 - switch on answering machine/select outgoing message
0 - (after playback) erases all messages
# - end playback
## - end call
9) Virgin Pulse cordless phone - preset access code is 123 - enter access code during outgoing message
1 - review current message
2 - skip to next message
3 - erase the current message
4 - play all or new messages
7 - repeat voice menu
0 - turn on/off TAD
10) Panasonic - preset access code is 11 or 1111 - enter access code during outgoing message
4 - new message playback
5 - all message playback
1 - repeat
2 - skip
9 - stop
7 - record new announcement (use 9 to end recording)
There are also a few random vendors that don't automatically preset an access code on the machine, forcing it's user to set one up him/herself. This is a small step forward as far as security is concerned, but every vendor I saw that did this still used a mere 2-digit access code. To test and see if your target has this type of setup press # when the machine start, and then press 0. If the machine returns to the annoucement then you know this is the kind of machine it is. Of course, in reality, this isn't all that bad of a scheme since you have 100 different combinations available for the access code. However, most users simply set these access codes as 11, 22, 69, etc. So yeah, just try it out. If it disconnects you after so many tries, call back from another payphone (which you should be using in this case).
Thanks for contacting Fixya
Jun 17, 2009 | Cell Phones
Grid surrounding cursor and desktop icons
You have accidentally enabled "Universal Access"
Open System Preferences from either the dock or the pull down menu under the Apple in the upper left hand corner of your screen.
In System Preferences the 4th line down should have icons for "System" one of those icons (usually the right most) will be a blue circle with a person in it. This is "Universal Access"
Open Universal access and turn voice over and zoom off.
Feb 28, 2009 | Apple iMac G5 Desktop
Cannot access PREFERENCE SETUP menu to reset to default settings
Remove disk from teh disk tray and try Setup after that.
Nov 01, 2008 | Amphion Mediaworks T-365 System
Lock access code
Just follow the steps carefully and you should be up and running again. Thanks for the model number.
1) To reset/change the SMART LOCK code, follow these steps.
Press the MENU button on the remote to display the on-screen menu.
Press the Cursor Up (also known as CH + button, above menu button) or Cursor Down (CH - below the menu button) to highlight SMART LOCK. Then press the Cursor Right (VOL + button to right of menu button) to display the SmartLock ACCESS CODE screen.
Using the numbers on the remote keypad, enter 0 7 1 1. " INCORRECT CODE" will appear on the screen. Enter the code 0 7 1 1 again.
Cursor Down to CHANGE CODE and enter 0 7 1 1 and then CONFIRM CODE and enter 0 7 1 1.
Press the STATUS / EXIT button (left of CH +) to save the new code in memory.
2) If the grandkids have locked out any channels, then you will have to perform the following steps:
Press MENU, highlight SMART LOCK, right arrow, enter 0 7 1 1, confirm by entering 0 7 1 1 again.
Cursor to BLOCKING OPTIONS, right arrow, and highlight CLEAR ALL, right arrow.
You should then see CHANNEL....ALL, LOCK....YES, ALL UNLOCKED.
3) To turn SMART LOCK off, follow these steps.
Cursor to BLOCKING OPTIONS, right arrow, and highlight BLOCKING OPTIONS, right arrow,
Aug 19, 2008 | Hitachi 51F500 51" Rear Projection...
Element Electronics Element 40" LED 1080P 60HZ HDTV - Black ELEFT405 Logo
70 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
