Question about Blitz Bergan Stack-N-Store Dog Food Storage
Need a replacement door for blitz 100 dog food storage bin
Is it true that this dog food is harmful to your dog?
Better to make your own for sure.
  • Review: Is Beneful® Bad for Dogs? - Feeding Fido and Fluffy www.feedingfidoandfluffy.com/review-is-beneful-bad-for-dogs Review: Is Beneful® Bad for Dogs? August 31, 2012. ... Here is the actual list of ingredients taken from the Beneful® Dog Food Healthy Weight web page:
  • PetMD: Why Dog Food Is Not For Cats, And Vice Versa www.petmd.com > Blogs > The Daily Vet Video embedded · But you'd be surprised to learn just how many of my cat owners feed their precious felines dog food ... dangerous to dogs' health? What ... cats dog food. ...
  • Is it true that Beneficial Dog Food is harmful to dogs ... www.fixya.com > Forum > Dog Food & Treats Beneful Dog Food this is link to snopes who say it is unproven. However if you do not want to risk it just feed your dog something else. The best top of the line most ...
  • Toxic and Dangerous Foods Your Dog Should Never Eat pets.webmd.com > Healthy Dogs > Slideshows A-Z Dangerous Foods for Dogs. Who can resist those big brown eyes and cute doggie grin? ... In fact, there's a lot of "people food" your dog should never eat.
  • Dog Food - Pet Care - 10 People Foods You Shouldn't Feed ... www.kidspot.com.au > MySpot > life Some human foods are very dangerous to a dog's health and should never be given to them, slipped under the table, ... While this is true, ...
  • Dec 16, 2015 | Dogs
    What size gallon container would hold 17 pounds of dog food?
    This is a comparison of a pound of feathers OR a pound of lead.
    There are too many variations of food bit size to be accurate. Large chunks will have a LOT more space between parts. I suggest you check stores that have translucent, plastic food containers. Evaluate the food size and weight in them with the food you feed now. That should give you an educated guess at least.
    Also you may compare the size of a full container of your food choice to a known gallon size container. A store employee may be able to assist and not draw less unwanted attention,,,
    Its a volume problem solve.
    http://www.walmart.com/c/kp/dog-food-storage-containers
    Sep 15, 2015 | Dogs
    How to clean a scotsman icemaker
    WHAT SHOULDN'T BE DONE.
    Never keep anything in the ice storage bin that is not ice; objects like wine or beer bottles are not only unsanitary, but the labels may slip off and plug up the drain. Never allow the machine to operate without regular. The machine will last longer if it is kept clean. Regular cleaning should happen at least once per year,and preferable twice. Some water conditions will dictate even more frequent cleaning of the ice making section, and some carpets or pets will dictate more frequent cleaning or the condenser.
    WHAT SHOULD BE KEPT CLEAN?
    There are 5 things to keep clean:
    1. The outside cabinet & door.
    2. The ice storage bin.
    3. The condenser.
    4. The ice making system.
    5. The ice scoop.
    HOW TO CLEAN THE CABINET.
    Wipe off any spills on the surface of the door and handle as they occur. If anything spilled on the door of gasket dries onto the surface, wash with soap and warm water to remove.
    HOW TO CLEAN THE ICE STORAGE BIN.
    The ice storage bin should be sanitized occasionally. It is usually convenient to sanitize the bin after the ice making system has been cleaned, and the storage bin empty. A sanitizing solution can be made of 1 ounce of household bleach and two gallons of hot (95 deg F.-115 deg F.)Water. Use a clean cloth and wipe down the interior of the ice storage bin with the sanitizing solution, pour some of the solution down the drain. Allow to dry.
    HOW TO CLEAN THE CONDENSER.
    The condenser is like a radiator on a car, it has fins and tubed that can become clogged. To clean:
    1. Remove the kick plate.
    2. Locate the condenser surface.
    3. Vacuum the surface, remove all dust and lint.
    4. Replace the kick plate.
    CLEANING THE SYSTEM.
    HOW TO CLEAN THE ICE MAKING SYSTEM.
    1. Open the door and turn the ice machine control knob off.
    2. Scoop out all of the ice, either discard it or save it in a ice chest or cooler.
    3. Pour 4 ounces of Scotsman ice Machine Cleaner ( available from a local Scotsman Distributor or Dealer, ask for part number 19-0343-06- an 8 ounce bottle) into the ice machine reservoir.
    4. Turn the ice machine control to ON.
    5. Allow the machine to operate for about 2 hours.
    6. Pour hot water into the bin to melt the ice that has formed. That ice will likely be white and frosty looking.
    7. Clean the bin liner of mineral scale by mixing some ice machine cleaner and hot water, and using that solution to scrub the scale off of the liner.
    8. Rinse the liner with hot water.
    9. Sanitize the bin interior.
    10. Replace the ice removed in step 2.
    The ice scoop should be washed regularly, wash it just like any other food container.
    WARNING; Scotsman ice machine cleaner contains acids. These compounds may cause burns. If swallowed,DO NOT induce vomiting. Give large amounts of water or milk. Call Physician immediately. In case of skin contact,flush with water. Keep out of the reach of children. Always follow manufactures directions.
    May 16, 2014 | Scotsman DCE33PA1BC 15in Built-in...
    Frozen food in refrigerator
    Can you confirm your model number? I see what says that your model is a JFC2089HE above your post but knowing Fixya the model number there is automatically placed there and is most times incorrect, Thanks John Tripp Appliance 911
    Feb 18, 2014 | Jenn-Air JFC2089HE French Door...
    I need a new lid
    I Found it!!!! http://www.bergandirectdelivery.com/replacement-parts/stack-n-stor-lid
    Feb 25, 2013 | Blitz Bergan Stack-N-Store Dog Food...
    My dog weights 8 KG. I just bought Dogli for him. How much grams should I give him per day?
    Dogs weighing 6-9kgshould eat between 100-165 grams of Dogli per day.
    Jul 30, 2012 | Dogs
    What is dog food?
    Dog food isbasically food that's made specifically for the nutritional needs of dogs. Itincludes all the basic nutrients that humans need as well (carbs, protein,minerals, and fats).
    Jul 18, 2012 | Dogs
    Ice not dispensing from door. There is ice in the cabinet.
    look behind the ice storage bin---there is a c-bracket that the storage bin slides into --- the motor may have to be replaced that turns the spiral feeder inside of the storage bin
    Jan 02, 2011 | Maytag MBF2256H Bottom Freezer...
    Food freezing in refrigerator storage bins
    produce has more water in it to freeze. Try turning down the temp in the fridge part of the unit you may try putting a termometer in there to gauge where it should be adjusted to, about 38-41 degrees is a safe temp for keeping food.
    May 27, 2009 | Refrigerators
    Blitz Bergan Stack-N-Store Dog Food Storage Logo
    89 people viewed this question
    Top Blitz Pets - Others Experts
    Ross Keen
    Tom Chichester
    Ruth summersides
    Are you a Blitz Pets - Other Expert? Answer questions, earn points and help others
