Question about Advent 4211c Notebook
Advent disassembly laptop - Advent 4211c Notebook
How to reset bios Advent Verona
If you can get into the BIOS there's a menu item to reset BIOS to defaults. If you cannot get into the BIOS you most likely need to open the laptop/disassemble and use the BIOS jumper if there is one or remove the CMOS battery for a few minutes.
Oct 30, 2013 | Computers & Internet
Advent 4211 screen to base connection problem
Video Cable
The Video Cable connects to the motherboard.
It then runs along under the Left Hinge, and connects to the back of LCD screen.
{LED backlighting. Does not use a screen Inverter]
Due to just normal opening, and closing of the laptop; the Video Cable may be pinched.
This can cause the connection of the Video Cable TO motherboard, to be loose; and/or LCD screen.
Solution is to partially disassemble the laptop, and PHYSICALLY make sure the connection at motherboard is tight.
Visual inspection will NOT do.
Connection at back of LCD screen needs to be Physically checked also. (Try to plug in tighter)
Also visually inspect the sheath of the Video Cable, for apparent signs of damage.
Any signs of damage to the sheath, may mean damage to the tiny wires inside the Video Cable.
(Stretched/Broken)
Also due to the age of the laptop, suspect cracking of the insulation, of the wires inside the Video Cable.
If you have a multimeter, set it to OHM's (1K), and check continuity of every wire in the Video Cable.
Or take it to a small computer store, and have the resident tech check it.
The Advent 4211 is just a rebadged MSI Wind U100, according to my findings,
Disassembly guide,
http://www.bit-tech.net/hardware/laptops/2008/07/05/breaking-wind/1
That's the problem, the Video Cable,
http://microdream.co.uk/advent-4211-c-lcd-screen-cable-k19-3030019-h58.html
[ In the photo, the large connector at bottom plugs into the LCD screen.
The smaller connector at the upper right plugs into the motherboard.
The separate black wire you see with the eyelet on it, is a Ground wire ]
For additional questions please post in a Comment
Regards,
joecoolvette
Dec 14, 2012 | Advent 4211c Notebook
Battery not holding charge and power lead has to be held in position for charging to take place
Use an ESD wrist strap with it's alligator clip attached to a good ground source.
Remove ALL power. Remove the AC adapter (Charger) and Battery.
Disassemble the laptop, remove the motherboard.
Replace the DC Power Jack. http://www.laptopdcjack.co.uk/product/Advent_6411_DC_Power_Jack_Socket_DC-ADV-6411
Information that may help to disassemble,
http://www.adventsupport.com/viewtopic.php?f=1&t=6770
http://www.uktsupport.co.uk/advent/laptop/6411v.htm
ftp://ftp.packardbell.com/pub/itemnr/7602080000/Disassembly_EasyNote_MZ_rev_100.pdf
(Advent 7211 series is like a P.B. MZ35 series. Just thought it may help)
http://www.youtube.com/watch?v=Im_n9K-14_I
Regards,
joecoolvette
Nov 25, 2012 | Advent Computers & Internet
How to replace thermal paste
You are going to have to disassemble the chassis in order to access the CPU area. Do this carefully and mark each part and you just may find this site very handy. Tick Here please John
Apr 17, 2012 | Advent Netbook
Advent disassembly
Checkout www.insidemylaptop.com for pictorial views.
Hope that helps.
Feb 01, 2011 | Advent Netbook
How do I replace the DVD drive on an Advent 7113 laptop
If you need to ask HOW, I highly recommend that you take your computer to a qualified technician for safe & correct replacement,
which involves a partial disassembly of the laptop.
Sep 27, 2010 | Computers & Internet
Broken lap top screen on a advent net book ,,,,,,,,,,,, how much would it cost and should i repair it ?
Some "small" computer-stores sell computer-parts on "consignment". So, go to one of those stores -- they may have an LCD screen available that matches your screen.
Expect to pay $100 for such a "previously-owned" screen,
versus paying $200 to $250 for a "new" screen.
Add $75 for "one-hour-labour" for disassembling your laptop, replacing the screen, reassembling, and testing.
Aug 31, 2010 | Advent Computers & Internet
My screen on the advent roma 1000 goes dark
The usual culprits are loose connections (this only happens when the lid is moved forwards or backwards). The other is the LCD inverter getting too hot.
In both cases you will need to disassemble the laptop lid to check the leads and the inverter itself for dry joints.
If you're not comfortable with disassembling the laptop yourself then i recommend that you take it to a reputable repair store to have it looked at.
Regards.
Apr 12, 2010 | Computers & Internet
White vertical line appears down centre of screen. Advent laptop
Could be loose VGA connection on mainboard connector. Disassemble and try wiggling connector.
Jan 03, 2010 | Compaq Presario M2000 Notebook
How to replace an Advent 7000 keyboard?
disassemble your keybr from laptop n using a tweezers to remove old pin n reassemble new pin. using it tool press new pin until "klik" sound.
Apr 05, 2009 | Computers & Internet
Advent 4211c Notebook Logo
Top Advent Computers & Internet Experts
Alun Cox
B.Th. Pluijm
B.Th. Pluijm
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
